"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message news:2nMXh.436$HX7.430@newssvr19.news.prodigy.net... : : : Tim Wescott wrote: : > So why is dimensional analysis so cool? : : Because it is generating so much traffic! It is trivial, so anyone can : add his two cents. : : Vladimir Vassilevsky Yes, this made me laugh. Everyone has an opinion but few have answers,. Fewer yet have right ones. Peter Nachtwey
In Praise of Dimensional Analysis
Started by ●April 24, 2007
Reply by ●April 26, 20072007-04-26
On Apr 24, 6:17 pm, Tim Wescott <tim@seemywebsite> wrote:> After six and a half years, I still get email about my article "PID > Without a PhD" > (http://www.wescottdesign.com/articles/Sampling/pidwophd.html) from > people who are asking for clarifications, or are asking questions that > go beyond what I could say in the 5000 word limit that Embedded. You raise some good points. . One of the problems with the modern unit system (Pascals, Siemens, etc) is that the fundamental meaning of the unit is lost. For example: Pressure X Area = Force. Pascals X Square meters = Pascal Meter^2. So what? You must first convert Pascal to its fundamental definition, which is Newtons/Square Meter. Now dimensional analysis makes sense: (Newtons/square meter) X (Square meter) = Newtons, which is consistent with a unit of force. . Another example is characteristic impedance of a transmission line. We've all learned that the equation is R = SQRT(L/C), where L = inductance/unit length, C = capacitance/unit length. Resistance = (Henries / Farads)^.5? You need to get back to the fundamental relationships among voltage, current and time for inductance, and the fundamental relationships among current, voltage and time for capacitance. v = Ldi/dt. i = C dv/dt. From these fundamental equations, you can get the fundamental units of L and C: L=VoltSeconds/Ampere, C= AmpereSeconds/ Volt. Now the equation for characteristic impedance makes sense, in terms of its fundamental units: R = SQRT([(VoltSeconds/Amps)/ (AmpsSeconds/Volt)] R = SQRT(Volts^2/Amps^2) = Volts/Amps = Ohms.
Jon wrote: (snip)> Another example is characteristic impedance of a transmission line. > We've all learned that the equation is R = SQRT(L/C), where L = > inductance/unit length, C = capacitance/unit length. Resistance = > (Henries / Farads)^.5? You need to get back to the fundamental > relationships among voltage, current and time for inductance, and the > fundamental relationships among current, voltage and time for > capacitance. v = Ldi/dt.Capacitance is in cm, resistance in s/cm, inductance in s**2/cm. Capacitance per unit length is dimensionless, inductance per unit length s**2/cm**2, so sqrt(L/C) is s/cm, just like resistance! I used to be able to do it in MKS and CGS units about equally, and sometimes Heaviside-Lorentz units. (Similar to CGS, but without so many 4pis around.) -- glen
Jon wrote: ...> Another example is characteristic impedance of a transmission line. > We've all learned that the equation is R = SQRT(L/C), where L = > inductance/unit length, C = capacitance/unit length. Resistance = > (Henries / Farads)^.5? You need to get back to the fundamental > relationships among voltage, current and time for inductance, and the > fundamental relationships among current, voltage and time for > capacitance. v = Ldi/dt. > i = C dv/dt. From these fundamental equations, you can get the > fundamental units of L and C: L=VoltSeconds/Ampere, C= AmpereSeconds/ > Volt. Now the equation for characteristic impedance makes sense, in > terms of its fundamental units: R = SQRT([(VoltSeconds/Amps)/ > (AmpsSeconds/Volt)] > R = SQRT(Volts^2/Amps^2) = Volts/Amps = Ohms.So what is that in meters, kilograms, and seconds? Does it matter? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
glen herrmannsfeldt wrote:> Jon wrote: > > (snip) > >> Another example is characteristic impedance of a transmission line. >> We've all learned that the equation is R = SQRT(L/C), where L = >> inductance/unit length, C = capacitance/unit length. Resistance = >> (Henries / Farads)^.5? You need to get back to the fundamental >> relationships among voltage, current and time for inductance, and the >> fundamental relationships among current, voltage and time for >> capacitance. v = Ldi/dt. > > Capacitance is in cm, resistance in s/cm, inductance in s**2/cm.That's CGS absolute, with volts in abvolts (1 abvolt = .01 microvolt) and current in abamps (1 abamp = 10 ampere) I'd rather use MKS units; so would you! :-)> > Capacitance per unit length is dimensionless, inductance per > unit length s**2/cm**2, so sqrt(L/C) is s/cm, just like > resistance! > > I used to be able to do it in MKS and CGS units about equally, > and sometimes Heaviside-Lorentz units. (Similar to CGS, but > without so many 4pis around.)Maybe you wouldn't rather. :-) Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jerry Avins wrote: (snip)> That's CGS absolute, with volts in abvolts (1 abvolt = .01 microvolt) > and current in abamps (1 abamp = 10 ampere) I'd rather use MKS units; so > would you! :-)One professor, when explaining the unit system he expected in answers, explained that his house power line was 1/3 of a statvolt. -- glen
Reply by ●April 27, 20072007-04-27
Vladimir Vassilevsky <antispam_bogus@hotmail.com> writes:> Tim Wescott wrote: > > ... >> ... > BTW, in the theoretical physics, they use the dimensionless units to > avoid the heavyweight dimension constants: > > e = c = h = 1 > > How about that?I knew someone who claimed to be a professor of theoretical nuclear physics--- oh no, he really was --- who wildely objected against this. My scientific origins are in theoretical physics but I mostly worked as a softwareengineer--- now lurking here to learn about DSP. What baffled me again and again is how engineers (in Germany) approach a problem: their question is ``where is the applicable formula''. I was trained to ask: ``what is the mathematical modell that allows me to handle this kind of problem.'' From studying mathematical modells, the physicist is probably just much more trained to handle long symbolic calculations as the average engineer and from this he has a stronger ability to analyze such formulas ``at a glance''--- w/o inserting units. To him the essential thing is the physical quality that is measured, like length or time, not the units that someone happens to use. Measured values just tell us how often some well defined object will fit ``into'' the measured object; the sole purpose of units is to pass along what object the one who measured happened to use for reference. Thus I like to claim: all those units were completely superflous, hadn't things been hopelessly messed up, starting at beginning of the world, by merchants and engineers. Comparing any speed to the speed of light in vacuum is perfect--- might even have some advantages, when on speed-limit signs a non-zero digit does not appeare until the 9-th (or so) position after the decimal point ...> ... >> ... >> So I thought I'd write a little bit about dimensional analysis, why >> I like it, and why you should use it, even if you think it is >> tedious and trite. > > C++ allows you defining the explicit types like "VOLTAGE", "CURRENT" > and such, so the dumb mistakes are avoided. However, this approach is > seen by many as the counter productive and resulting in the > inefficient code.Strongly typed languages were designed to support this style of programming. They come in two flavours: ``static typing'' and ``dynamic typing''. If you want to see powerfull representatatives of both paradigms, just look at ML and Scheme. Static typing gives you strict compile-time type check at no run-time overhead; dynamic typing gives you strict run-time type-check . -- hw
On Apr 25, 8:07 pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Tim Wescott wrote: > > (snip) > > > So I thought I'd write a little bit about dimensional analysis, why I > > like it, and why you should use it, even if you think it is tedious and > > trite. > > This reminds me of something that has occurred to me in the past, and > that I would like to see if people here agree. > > It seems to me that in calculations physicists usually give variables > quantities with dimensions, where engineers usually factor out the > dimensions. For example, > > A physicist might say: > > F = m a, where the variable m might have the value 3kg or 5g. > > An engineer might say: > > F(Newtons) = m(kg) * a (m s**-2), such that m has the value 3 or 0.005. > > That is, the dimensions belong to the equation, but not to variables. > > It might be because most programming languages don't keep units with > variables, so that one must factor them out before assigning a value > to a variable. > > I would be interested to see if others agree or disagree.i disagree, i guess. when i was teaching EE classes (circuits) and as a grad student in EE, i would be pretty hard on any engineering student that did it the latter way. i think Jerry's little proverb said it best: "Mathematicians routinely ignore units, but engineers do so at their peril." the cumbersome method you ascribed to engineers, Glen, is almost as bad as ignoring the unit. (because your root algebraic equation is dimentionless. in the latter case, F = ma is actually expressed as the dimensionless F is the product of the dimensionless m and the dimensionless a, as long as you express all three in their base SI units. r b-j
On Apr 27, 3:48 pm, Heinrich Wolf <hwmu...@willis-werkstaette.de> wrote:> Vladimir Vassilevsky <antispam_bo...@hotmail.com> writes: > > Tim Wescott wrote: > > > ... > >> ... > > BTW, in the theoretical physics, they use the dimensionless units to > > avoid the heavyweight dimension constants: > > > e = c = h = 1 > > > How about that? > > I knew someone who claimed to be a professor of theoretical nuclear > physics--- oh no, he really was --- who wildely objected > against this.why would a theoretical nuclear physicist have a problem with that? these are one example of "Natural units" (look that up in Wikipedia) and i think these are called "electronic units" if the "h" is replaced with "hbar". but qualitatively, the are electronic units. they can be compared to Stoney units (but i think Stoney normalizes G instead of hbar), Planck units (but Planck normalizes G instead of e), or Atomic units (which normalize the mass of the electron instead of c). personally i like Planck units the best because they have no prototype particle, object, or "thing" that needs to be sorta arbitrarily chosen as a base unit. it's better, in my opinion, to normalize these parameters of free space, before introducing any special particles or objects, to define your base Natural units. i which Planck would have normalized 4*pi*G instead, that would have been more natural. other good Wikipedia articles that are related is Planck units Physical constant Dimensionless physical constant Fundamental unit i had something to do with those articles, including Dimensional analysis. r b-j
Cj4gT3VyIGVkdWNhdG9ycyBzaG91bGQgbWFrZSBtb3JlIG9mIGEgYmlnIGRlYWwgb2YgdGhpcyB0 aGFuIHRoZXkgZG8uCj4gVGhhbmtzLCBUaW0uCj4KPiBKZXJyeQo+IC0tCj4gRW5naW5lZXJpbmcg aXMgdGhlIGFydCBvZiBtYWtpbmcgd2hhdCB5b3Ugd2FudCBmcm9tIHRoaW5ncyB5b3UgY2FuIGdl dC4KPiCvr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+vr6+v r6+vr6+vr6+vr6+vr6+vr6+vrwoKSGVsbG8gSmVycnkgZXQgYWwsCkkgY2FuIGFzc3VyZSB5b3Ug dGhhdCBteSBzdHVkZW50cyBhcmUgZm9yY2VkIHRvIHNob3cgdW5pdHMgYWxsIG9mIHRoZQp3YXkg dGhyb3VnaCB0aGVpciBwaHlzaWNzIGNhbGN1bGF0aW9ucy4gSSBhbHNvIHNob3cgdGhlIHV0aWxp dHkgb2YKZXhwcmVzc2luZyB0aGluZ3MgYXMgcmF0aW9zLCBzbyB0aGUgdW5pdHMgY2FuY2VsIG91 dC4gU3VjaCBhcyBnaXZlbiBhCnBlbmR1bHVtIGNsb2NrIHRoYXQgcnVucyBub3JtYWxseSBvbiBF YXJ0aCwgaG93IG11Y2ggZmFzdGVyL3Nsb3dlcgp3aWxsIGl0IGJlIG9uIHRoZSBNb29uPyAgKGdf bW9vbiBhcHByb3ggMS82IHRoYXQgb2YgdGhlIEVhcnRoJ3MpCgpDbGF5CgoKCg==
