glen herrmannsfeldt wrote:> Jerry Avins wrote: > > (snip) > >> Miles/hour/second is a pretty common unit. Of course, an hour-second >> equals a square minute. :-) > > One of my least favorite units is the one power companies like > to use to describe usage: Kilowatt hours/day. Kilowatt seems > like a fine power unit, without an extra factor of 24.I think you mean that a KW-hour is a unit of energy. It is also (indirectly) a unit of revenue. Hence the usage. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
In Praise of Dimensional Analysis
Started by ●April 24, 2007
Reply by ●April 29, 20072007-04-29
Jerry Avins wrote:> glen herrmannsfeldt wrote:Glen, Your timestamp seems to be a bit into the future. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jerry Avins wrote:> glen herrmannsfeldt wrote: >> Jerry Avins wrote: >> >> (snip) >> >>> Miles/hour/second is a pretty common unit. Of course, an hour-second >>> equals a square minute. :-) >> >> One of my least favorite units is the one power companies like >> to use to describe usage: Kilowatt hours/day. Kilowatt seems >> like a fine power unit, without an extra factor of 24. > > I think you mean that a KW-hour is a unit of energy.No, you meant that KW-hr/day is a unit of power. My mistake. ... Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On Sun, 29 Apr 2007 18:09:45 -0400, Jerry Avins <jya@ieee.org> wrote:>Jerry Avins wrote: >> glen herrmannsfeldt wrote: > >Glen, > >Your timestamp seems to be a bit into the future. > >JerryBut are the units right? ;) Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
glen herrmannsfeldt wrote:> Jerry Avins wrote: > > (snip) > >> Miles/hour/second is a pretty common unit. Of course, an hour-second >> equals a square minute. :-) > > One of my least favorite units is the one power companies like > to use to describe usage: Kilowatt hours/day. Kilowatt seems > like a fine power unit, without an extra factor of 24. > > -- glen >Unfortunate for technical people, but good for 'normal' customers. Everyone knows what a day is, and we all get billed in KW-hours. I doubt that very many people could tell you that a KW-hour/day is a hair under 42 watts, and even fewer could do it in a blink without a calculator. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●April 30, 20072007-04-30
On Sun, 29 Apr 2007 14:29:36 -0800, glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:>Jonathan Kirwan wrote: >(snip) > >> A venerable approach. Galileo used it, in fact. Algebra, at the >> time, he felt was not yet rigorously founded while ratios had been for >> quite some time. > >I had known that Galileo's first experiments with rolling balls >were an attempt to slow down the fall of gravity, and allow him >to understand the effect. I hadn't known why he decided to do it >that way, without the algebra to show what the result would mean.Galileo probably began considering motion like this at least as early as 1586, I think, having written a dialogue on problems of motion that year. He must have considered inclined plane experiments as early as 1591, since he added them to his De Motu that year. But I seem to recall that his immersion into building them would have been around 1601-1602. The details about his thinking, as well as copies of some of his folios, can be found in Sillman Drake's "Galileo: Pioneer Scientist." I recommend it. Jon
