Hi all, I am not so new to DSP but I would still like to bounce an idea off the experts just to check that I have all my ducks in a row. A very large FFT say 1M points is to be done on a real sequence. Am I correct in saying that if I treat this 1mill points as a 1024*1024 matrix and first do 1024 FFTs of length 1024 (1 FFT on each row), then transpose the matrix, then again 1024 FFTs of size 1024(1 on each row) and then transpose the matrix again, that I will have done my 1mill point FFT ? The answer can be read out row by row. Ignore the following to simplify the discussion for now: -phase information -complex values Transposing the matrix is only to ease the memory usage so that I do not have to jump around in the memory to make FFTs down the columns. Thanks in advance. Adriaan _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
Very large FFT
Started by ●April 26, 2007
Reply by ●April 26, 20072007-04-26
AdriaanB wrote:> A very large FFT say 1M points is to be done on a real sequence. Am I > correct in saying that if I treat this 1mill points as a 1024*1024 matrix > and first do 1024 FFTs of length 1024 (1 FFT on each row), then transpose > the matrix, then again 1024 FFTs of size 1024(1 on each row) and then > transpose the matrix again, that I will have done my 1mill point FFT ? The > answer can be read out row by row.I don't believe so, but it might not be a bad way to do it for the speed up of faster cache access. Well, if you leave out phase then it probably works, but phase is an important part of the FFT, so you can't leave it out. Numerical Recipes has a pretty understandable (by non-experts) explanation of FFT. -- glen
On 26 Apr, 16:01, "AdriaanB" <adriaan.bredek...@vibro-meter.com> wrote:> Hi all, > > I am not so new to DSP but I would still like to bounce an idea off the > experts just to check that I have all my ducks in a row. > > A very large FFT say 1M points is to be done on a real sequence. Am I > correct in saying that if I treat this 1mill points as a 1024*1024 matrix > and first do 1024 FFTs of length 1024 (1 FFT on each row), then transpose > the matrix, then again 1024 FFTs of size 1024(1 on each row) and then > transpose the matrix again, that I will have done my 1mill point FFT ? The > answer can be read out row by row.Nope. A 1M FFT is *formally* equivalent to multiplying a 1M x 1M matrix with a 1M vector. The matrix is known, though, so all the coefficients are computed on the fly, and you don't actually use more than 2M or maybe 3M elements in memory. Rune
> I am not so new to DSP but I would still like to bounce an idea off the > experts just to check that I have all my ducks in a row. > > A very large FFT say 1M points is to be done on a real sequence. Am I > correct in saying that if I treat this 1mill points as a 1024*1024 matrix > and first do 1024 FFTs of length 1024 (1 FFT on each row), then transpose > the matrix, then again 1024 FFTs of size 1024(1 on each row) and then > transpose the matrix again, that I will have done my 1mill point FFT ? The > answer can be read out row by row.Here is a link of a presentation I did a few years back about this: http://www.dilloneng.com/documents/DE_HPEC2004_Posters.pdf The basic steps are: 1. 1M points stored in row order 2. Column FFTs (1k 1k ffts) 3. Complex multiply each point by complex phase factor 4. Row FFTs (1k 1k ffts) 5. Results are in column order Tom
Rune Allnor wrote:> A 1M FFT is *formally* equivalent to multiplying a 1M x 1M matrix > with > a 1M vector.That't mathematically true. But it is not the way how FFT works. FFT uses symmetries in this matrix introduced by the prime factors of it's size. Only if the size is a prime number, there is no redundency.> The matrix is known, though, so all the coefficients are > computed on the fly, and you don't actually use more than 2M or maybe > 3M elements in memory.That's true anyway. Marcel
Hi again, I looked at http://www.jjj.de/fxt/fxtbook.pdf on page 329 where the guy explains a method for a 1D FFT of arbitary large size and started to implement it with Matlab around an hour before going home. That is then work to be continued tomorrow. He seems to follow the general thing that was also mentioned here of splitting it in a row * column and then doing FFTs row wise, then transpose and repeat the rows again (in effect on the columns) and then transposing it again. New question is: Why is the extra twiddle factor multiplication needed halfway through the algorithm? Some quick answers to comments from previous posting authors: -Yes phase will have to be taken into account but I can handle that easily. -I am not worried about speed since my application does a 256 - 8k point FFT(depending on config for that channel) every 6.25ms as part of a larger signal chain (integrations, averaging band extraction etc.) and the VERY large FFT is done when the timeslot has some extra free time available. Obviously the small FFT channels have more free time available. Since the very large one is done in the background, it is finished when it is finished. The background FFT is anyway processed in SDRAM which means it is slow. R>Rune Allnor wrote: >> A 1M FFT is *formally* equivalent to multiplying a 1M x 1M matrix >> with >> a 1M vector. > >That't mathematically true. But it is not the way how FFT works. FFT >uses symmetries in this matrix introduced by the prime factors of it's >size. Only if the size is a prime number, there is no redundency. > >> The matrix is known, though, so all the coefficients are >> computed on the fly, and you don't actually use more than 2M or maybe >> 3M elements in memory. > >That's true anyway. > > >Marcel >_____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
AdriaanB wrote: (snip)> He seems to follow the general thing that was also mentioned here of > splitting it in a row * column and then doing FFTs row wise, then > transpose and repeat the rows again (in effect on the columns) and then > transposing it again. New question is: Why is the extra twiddle factor > multiplication needed halfway through the algorithm?There is no extra twiddle factor, it is the same one that comes on any step of the FFT. It just looks extra because of the way you are separating it. I wondered some time ago about an FFT of a whole CD, so maybe 44100*60*70 = 185220000 samples (per channel). -- glen
Reply by ●April 27, 20072007-04-27
HI Yes it is clear to me that this is the same Twiddle array that I previous calculated that for increasing the speed of the FFT calc, but why is he making it then again ? It looks like - FFT with twiddle -Twiddle again (???) - FFT with twiddle -final answer I noticed the same in a PhD thesis on radio astronomy in the appendix C where the author made an extra Twiddle step. In the referenced presentation from Dillon Engineering there was also this step. What is the purpose of it? Is the 1D FFT calculated as 2D matrix really that much different to the image processing 2D FFT ? R>AdriaanB wrote: >(snip) > >> He seems to follow the general thing that was also mentioned here of >> splitting it in a row * column and then doing FFTs row wise, then >> transpose and repeat the rows again (in effect on the columns) andthen>> transposing it again. New question is: Why is the extra twiddle factor >> multiplication needed halfway through the algorithm? > >There is no extra twiddle factor, it is the same one that >comes on any step of the FFT. It just looks extra because of >the way you are separating it. > >I wondered some time ago about an FFT of a whole CD, so maybe >44100*60*70 = 185220000 samples (per channel). > >-- glen > >_____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
> Yes it is clear to me that this is the same Twiddle array that I previous > calculated that for increasing the speed of the FFT calc, but why is he > making it then again ? > > It looks like > - FFT with twiddle > -Twiddle again (???) > - FFT with twiddle > -final answer > > I noticed the same in a PhD thesis on radio astronomy in the appendix C > where the author made an extra Twiddle step. In the referenced > presentation from Dillon Engineering there was also this step. > > What is the purpose of it? Is the 1D FFT calculated as 2D matrix really > that much different to the image processing 2D FFT ? >Without it you don't get a 1M FFT when you are done. It would be nice not to have to do it, but if you don't do the extra twiddle multiply you would have a 2D FFT 1k x 1k FFT and not a 1M FFT. Tom
... a more mathematical answer to that please ? It is clear that when the recipe says you add salt and two eggs it is best to add exactly that. I would just rather like to know the why without having to follow it blindly. In the jjj.de .pdf file on page 329 and some pages before where J�rg shows a Image processing 2D FFT, the difference is exactly the extra Twiddle factor you have to make to get back to a 1D 1M point FFT. R>> Yes it is clear to me that this is the same Twiddle array that Iprevious>> calculated that for increasing the speed of the FFT calc, but why ishe>> making it then again ? >> >> It looks like >> - FFT with twiddle >> -Twiddle again (???) >> - FFT with twiddle >> -final answer >> >> I noticed the same in a PhD thesis on radio astronomy in the appendixC>> where the author made an extra Twiddle step. In the referenced >> presentation from Dillon Engineering there was also this step. >> >> What is the purpose of it? Is the 1D FFT calculated as 2D matrixreally>> that much different to the image processing 2D FFT ? >> > >Without it you don't get a 1M FFT when you are done. It would be nice >not to have to do it, but if you don't do the extra twiddle multiply >you would have a 2D FFT 1k x 1k FFT and not a 1M FFT. > >Tom > >_____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
