Hi, In Oversampled Sigma-Delta A/D Converter, which is in the demo, why did they use three decimators (4*4*4) rather than one decimator of 64? Is there any particular theory behind this for the gradual process of decimation?
Started by ●April 30, 2007
Reply by ●April 30, 20072007-04-30
nanimerc@yahoo.com wrote:> Hi, > > In Oversampled Sigma-Delta A/D Converter, which is in the demo, why > did they use three decimators (4*4*4) rather than one decimator of > 64? Is there any particular theory behind this for the gradual > process of decimation? >Which demo? Decimating by four, then four, then four again requires storing 11 past values rather than 63, and has each stage running successively slower which eases the timing requirements considerably. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
nanimerc@yahoo.com wrote:> Hi, > > In Oversampled Sigma-Delta A/D Converter, which is in the demo, why > did they use three decimators (4*4*4) rather than one decimator of > 64? Is there any particular theory behind this for the gradual > process of decimation?Analyze how sharp the filters need to be for each plan. Remember: aliases that appear only in the part of the spectrum that will later be filtered are allowed. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
nanimerc@yahoo.com wrote:> In Oversampled Sigma-Delta A/D Converter, which is in the demo, why > did they use three decimators (4*4*4) rather than one decimator of > 64? Is there any particular theory behind this for the gradual > process of decimation?Cascaded decimator is efficient: it requires at the order of N*log(N) operations per output sample, whereas the direct decimation takes about N^2. This is the same divide and conquer principle, as in the FFT. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●May 1, 20072007-05-01
Jerry Avins wrote:> nanimerc@yahoo.com wrote: >> Hi, >> >> In Oversampled Sigma-Delta A/D Converter, which is in the demo, why >> did they use three decimators (4*4*4) rather than one decimator of >> 64? Is there any particular theory behind this for the gradual >> process of decimation? > > Analyze how sharp the filters need to be for each plan. Remember: > aliases that appear only in the part of the spectrum that will later be > filtered are allowed. > > JerryIn other words, if the cutoff frequency of all three filters starts at the same absolute frequency (in Hz), the first stages can be quite a bit more relaxed that subsequent stages. They only have to knock down the frequencies before they alias into the final band of interest. This makes them far less burdensome computationally. The last stage will need some steep skirts, but it will operate at 1/16th the original sample rate. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 The real fun of living wisely is that you get to be smug about it. - Hobbes
Reply by ●May 7, 20072007-05-07
On 30 Apr, 19:41, Tim Wescott <t...@seemywebsite.com> wrote:> nanim...@yahoo.com wrote: > > Hi, > > > In OversampledSigma-DeltaA/DConverter, which is in the demo, why > > did they use three decimators (4*4*4) rather than one decimator of > > 64? Is there any particular theory behind this for the gradual > > process of decimation? > > Which demo? > > Decimating by four, then four, then four again requires storing 11 past > values rather than 63, and has each stage running successively slower > which eases the timing requirements considerably. > > -- > > Tim Wescott > Wescott Design Serviceshttp://www.wescottdesign.com > > Posting from Google? Seehttp://cfaj.freeshell.org/google/ > > Do you need to implement control loops in software? > "Applied Control Theory for Embedded Systems" gives you just what it says. > See details athttp://www.wescottdesign.com/actfes/actfes.htmlThank you for the reply, the demo is in MATLAB/SIMULINK.
