I am working on a project to demodulate SSB signals using software defined radio on a blackfin DSP. We are required to design and build a lower sideband SSB communications-quality speech receiver which will tune the band 7.040MHz�7.100MHz. We are using a softrock 40 board which multiplies the signals by a sin and cosine wave at 7.055MHz to generate the I and Q branches. I was just wondering if anyone can give me some pointers as to where to start. I am a bit confused about how to do the fine tuning to different carrier frequencies. Thanks _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
Demodulation of SSB LSB
Started by ●May 2, 2007
Reply by ●May 2, 20072007-05-02
On May 2, 7:49 am, "benzini1985" <benzini...@yahoo.co.uk> wrote:> I am working on a project to demodulate SSB signals using software defined > radio on a blackfin DSP. We are required to design and build a lower > sideband SSB communications-quality speech receiver which will tune the > band 7.040MHz-7.100MHz. We are using a softrock 40 board which multiplies > the signals by a sin and cosine wave at 7.055MHz to generate the I and Q > branches. I was just wondering if anyone can give me some pointers as to > where to start. I am a bit confused about how to do the fine tuning to > different carrier frequencies. > > Thanks >Hello, To do the fine tuning, just multiply your I,Q signal by another quadrature oscillator whose frequency is the last little bit of shifting you need. I.e., treat your radio's I,Q signal as a complex number and treat the oscillator's output also as a complex number and then do a complex multiply. (A+jB)(C+jD) = (AC-BD)+j(AD+BC) IHTH, Clay
Reply by ●May 6, 20072007-05-06
Thanks, Clay. Just to clarify things i have my signals I and Q components and then i set A = I, B = Q, to give me A+jB. And then C = D = sine waves at the frequency of the last little shift? _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
benzini1985 said the following on 06/05/2007 13:21:> Thanks, Clay. > > Just to clarify things i have my signals I and Q components and then i set > A = I, B = Q, to give me A+jB. And then C = D = sine waves at the frequency > of the last little shift? >C and D represent the in-phase and quadrature components of exp{2j.pi.f}; therefore C will be a cosine, and D will be a sine. -- Oli
