BTSC/MTS Specification Clarifications
Started by Randy Yates ●May 2, 2007
On May 2, 4:50 pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:
> Randy Yates wrote: > > (snip) > > > For those who may be curious, BTSC/MTS is the specification for the > > old analog TV audio, the key point of which is to accept two channels, > > a stereo main channel and a second audio program (SAP) channel at the > > transmitter, encode it into the NTSC signal, and recover it at the > > receiver. > > As well as I know it, the stereo signal is very similar to FM stereo, > except with the subcarrier at two times the line rate, which is about > 15734kHz. The pre-emphasis is probably also different, I don't > know the time constants for it. > > SAP is a dbx (2:1 full band) compressed FM subcarrier > with center, I believe, at five times the line rate. The dbx > compression allows for reasonable quality in what would otherwise > be a noisy signal. Other than the compression and frequency it > should be similar to the FM broadcast SCA subcarrier. > > It might be that the FCC references the existing standards instead > of writing new ones, with only the changes needed documented. > > -- glen
The stereo signal is not very close to FM stereo. It is similar in that it splits the signal into L+R and L-R components that are modulated. However, L-R is dbx compressed and AM modulated first.
glen herrmannsfeldt <gah@ugcs.caltech.edu> writes:
> tony kirke wrote: > > (snip about television sound) > >> The stereo signal is not very close to FM stereo. It is similar in >> that it splits the signal into L+R and L-R components that are >> modulated. However, L-R is dbx compressed and AM modulated first. > > I had remembered that SAP was dbx compressed, but forgot the > stereo subcarrier was. It makes sense, though, since you have > to have the chip in there, anyway. > > But what do you mean by AM modulated first? In addition to the > AM suppressed carrier usually used for the stereo subcarrier?
No. You were right the first time, Glen. It is very similar to FM. The L+R sum signal is transmitted on the old mono main channel, and the L-R difference signal is "encoded" and then DSB-SC modulated on a subcarrier at 2 times the pilot subcarrier. The pilot subcarrier is the horizontal scan rate (15734 Hz or so). -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
> The stereo signal is not very close to FM stereo. It is similar in > that it splits the signal into L+R and L-R components that are > modulated. However, L-R is dbx compressed and AM modulated first.
I had remembered that SAP was dbx compressed, but forgot the stereo subcarrier was. It makes sense, though, since you have to have the chip in there, anyway. But what do you mean by AM modulated first? In addition to the AM suppressed carrier usually used for the stereo subcarrier? -- glen
Jerry Avins wrote:
> glen herrmannsfeldt wrote:
(snip)
>> As well as I know it, the stereo signal is very similar to FM stereo, >> except with the subcarrier at two times the line rate, which is about >> 15734kHz. The pre-emphasis is probably also different, I don't >> know the time constants for it.
(snip)
> Isn't the deviation 75 KHz instead of broadcast FM's 150?
I believe 25kHz instead of broadcast FM's 75kHz. (That is, +/- 75kHz for a total width of 150kHz.) Analog FM tuners will usually reach the sound carrier of TV channel 6. But I consider that as a separate question from the content of the audio signal, with its own subcarriers. -- glen
> Jerry Avins wrote: > >> glen herrmannsfeldt wrote: > > (snip) > >>> As well as I know it, the stereo signal is very similar to FM stereo, >>> except with the subcarrier at two times the line rate, which is about >>> 15734kHz. The pre-emphasis is probably also different, I don't >>> know the time constants for it. > > (snip) > >> Isn't the deviation 75 KHz instead of broadcast FM's 150? > > I believe 25kHz instead of broadcast FM's 75kHz. > (That is, +/- 75kHz for a total width of 150kHz.)
The deviation depends on the mode. For mono-only signal, the peak deviation is 25 kHz. For MTS (Multichannel Television Sound), the peak deviation should not exceed 73 kHz. -- % Randy Yates % "So now it's getting late, %% Fuquay-Varina, NC % and those who hesitate %%% 919-577-9882 % got no one..." %%%% <yates@ieee.org> % 'Waterfall', *Face The Music*, ELO http://home.earthlink.net/~yatescr
On May 3, 2:46 pm, Randy Yates <y...@ieee.org> wrote:
> glen herrmannsfeldt <g...@ugcs.caltech.edu> writes: > > tony kirke wrote: > > > (snip about television sound) > > >> The stereo signal is not very close to FM stereo. It is similar in > >> that it splits the signal into L+R and L-R components that are > >> modulated. However, L-R is dbx compressed and AM modulated first. > > > I had remembered that SAP was dbx compressed, but forgot the > > stereo subcarrier was. It makes sense, though, since you have > > to have the chip in there, anyway. > > > But what do you mean by AM modulated first? In addition to the > > AM suppressed carrier usually used for the stereo subcarrier? > > No. You were right the first time, Glen. It is very similar to FM. The > L+R sum signal is transmitted on the old mono main channel, and the > L-R difference signal is "encoded" and then DSB-SC modulated on a > subcarrier at 2 times the pilot subcarrier. The pilot subcarrier is the > horizontal scan rate (15734 Hz or so). > -- > % Randy Yates % "Rollin' and riding and slippin' and > %% Fuquay-Varina, NC % sliding, it's magic." > %%% 919-577-9882 % > %%%% <y...@ieee.org> % 'Living' Thing', *A New World Record*, ELOhttp://home.earthlink.net/~yatescr
Yes. I should have simply said that L-R is DBX compressed. I wasn't aware that FM stereo had a pilot though.
tony kirke <tkirke@gmail.com> writes:
> On May 3, 2:46 pm, Randy Yates <y...@ieee.org> wrote: >> glen herrmannsfeldt <g...@ugcs.caltech.edu> writes: >> > tony kirke wrote: >> >> > (snip about television sound) >> >> >> The stereo signal is not very close to FM stereo. It is similar in >> >> that it splits the signal into L+R and L-R components that are >> >> modulated. However, L-R is dbx compressed and AM modulated first. >> >> > I had remembered that SAP was dbx compressed, but forgot the >> > stereo subcarrier was. It makes sense, though, since you have >> > to have the chip in there, anyway. >> >> > But what do you mean by AM modulated first? In addition to the >> > AM suppressed carrier usually used for the stereo subcarrier? >> >> No. You were right the first time, Glen. It is very similar to FM. The >> L+R sum signal is transmitted on the old mono main channel, and the >> L-R difference signal is "encoded" and then DSB-SC modulated on a >> subcarrier at 2 times the pilot subcarrier. The pilot subcarrier is the >> horizontal scan rate (15734 Hz or so). >> -- >> % Randy Yates % "Rollin' and riding and slippin' and >> %% Fuquay-Varina, NC % sliding, it's magic." >> %%% 919-577-9882 % >> %%%% <y...@ieee.org> % 'Living' Thing', *A New World Record*, ELOhttp://home.earthlink.net/~yatescr > > > Yes. I should have simply said that L-R is DBX compressed. I wasn't > aware that FM stereo had a pilot though.
Yes - it's at 19 kHz instead of 16.75 kHz. -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
Randy Yates <yates@ieee.org> writes:
I meant 15.75 kHz. -- % Randy Yates % "How's life on earth? %% Fuquay-Varina, NC % ... What is it worth?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://home.earthlink.net/~yatescr
> I meant 15.75 kHz.
Except that it is closer to 15.734 kHz, unless you can find a black and white show with stereo sound. -- glen
> Randy Yates wrote: > >> Randy Yates <yates@ieee.org> writes: > >>>Yes - it's at 19 kHz instead of 16.75 kHz. > >> I meant 15.75 kHz. > > Except that it is closer to 15.734 kHz, unless you can find > a black and white show with stereo sound.
I was rounding to the nearest 50 kHz. -- % Randy Yates % "She has an IQ of 1001, she has a jumpsuit %% Fuquay-Varina, NC % on, and she's also a telephone." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
