On 15 Mai, 13:27, "gkn" <gei...@ii.uib.no> wrote:> Hi again. You said that the discretized filter becomes unstable when using > the bilinear transform on the new zero (by the differentiation). What I > then find confusing is that there are many analog prototypes which have a > zero like this. And the BLT of a stable filter is also a stable filter, so > what's wrong here?Your last statement is wrong. You have the counter-example. To be more specific: the BLT maps the left-half complex plane (excluding the imaginary line) into the unit circle. The pole of the continuous time differntiator at infinity gets mapped onto the Nyquist frequency. For analog designs, the pole at infinity is usually countered by some kind of (possibly system inherent) lowpass. Regards, Andor
Differentiating impulse response
Started by ●May 8, 2007
Reply by ●May 16, 20072007-05-16
