Hi This is regarding usage of chebyshev polynomials for function approximation. I work on this problem during my spare time. The Chebyshev polynomial coefficients are obtained from unequally spaced zeroes of the function. But, if we use the same Chebyshev polynomial to approximate a periodic finction, is there a certain way to model (a mathematical equation) the error involved, assuming infinite precision (or double precision floating point). Eventually, I would like to translate this to fixed point. If there are any books that I should refer to, please let me know. I have got experimental results for various functions using double precision floating point format but need a way to mdel it. I apologize if this is the wrong group to post this question Regards Nithin
polynomial approximation
Started by ●May 16, 2007
Reply by ●May 16, 20072007-05-16
nithin.pal@gmail.com wrote:> Hi > This is regarding usage of chebyshev polynomials for function > approximation. I work on this problem during my spare time. > > The Chebyshev polynomial coefficients are obtained from unequally > spaced zeroes of the function. But, if we use the same Chebyshev > polynomial to approximate a periodic finction, is there a certain way > to model (a mathematical equation) the error involved, assuming > infinite precision (or double precision floating point). Eventually, I > would like to translate this to fixed point. > > If there are any books that I should refer to, please let me know. > > I have got experimental results for various functions using double > precision floating point format but need a way to mdel it. > > I apologize if this is the wrong group to post this questionIt may not be the best group, and I'm certainly not the best respondent to answer it, but I can recommend a book. "An Introduction to the Approximation of Functions" by Theodore J. Rivlin. Dover reprint ISBN 0-486-64069-8. My copy cost $3.50; I'm sure it's more now. http://tinyurl.com/32w6uj Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On May 16, 11:38 am, nithin....@gmail.com wrote:> > The Chebyshev polynomial coefficients are obtained from unequally > spaced zeroes of the function. But, if we use the same Chebyshev > polynomial to approximate a periodic function, is there a certain way > to model (a mathematical equation) the error involved, assuming > infinite precision (or double precision floating point). Eventually, I > would like to translate this to fixed point. > > If there are any books that I should refer to, please let me know. > > I have got experimental results for various functions using double > precision floating point format but need a way to mdel it. > > I apologize if this is the wrong group to post this question >it's a good group to post this to. maybe sci.math would be another appropriate group. even though i understand how to use Tchebyshev polynomials to approximate a constant segment (the passband gain in a Tchebyshev Type 1 filter or the stopband in the Tchebyshev Type 2 filter), i don't know exactly how to use Tchebyshev polynomials to optimally approximate a given function with finite order polynomial. for that problem, i use the Remez exchange algorithm (not to be confused with Parks-McClellan). personally, i don't know how to approximate a periodic function with Tchebyshev polynomials, but if you *do* compute the Fourier series coefficients of a periodic function and truncate those coefs to a finite order, you can use those Fourier series coefs to get you a sum of Tchebyshev polynomial operators with a single cosine as the input. is that what you want to do? r b-j
nithin.pal@gmail.com wrote:> This is regarding usage of chebyshev polynomials for function > approximation. I work on this problem during my spare time.My understanding, not having actually done it, is... One could write the Taylor series expansion of a function and truncate the series at some point. For most functions it will not be optimal over the desired domain of the function. One instead writes the function as an expansion of Chebyshev (sometimes the spelling is different) polynomials, truncates that series, and then rewrites the truncated series as an ordinary polynomial. Those coefficients will be a little different from the Taylor series, better over the desired domain, likely a lot worse outside that domain. Argument reduction is used to reduce the domain needed for the polynomial expansion using, for example, trigonometric identities. -- glen
In article <1179329920.465429.253030@p77g2000hsh.googlegroups.com>, nithin.pal@gmail.com says...> > >Hi >This is regarding usage of chebyshev polynomials for function >approximation. I work on this problem during my spare time. > >The Chebyshev polynomial coefficients are obtained from unequally >spaced zeroes of the function. But, if we use the same Chebyshev >polynomial to approximate a periodic finction, is there a certain way >to model (a mathematical equation) the error involved, assuming >infinite precision (or double precision floating point). Eventually, I >would like to translate this to fixed point. > >If there are any books that I should refer to, please let me know. > >I have got experimental results for various functions using double >precision floating point format but need a way to mdel it. > >I apologize if this is the wrong group to post this questionIIRC, Numerical Recipes has a discussion of this, as well as code.
