Is there a good way to compute indefinite integral numerically? How does FFT compare to numerical integration?
Started by Mike ●May 18, 2007
Hi all,
I want to take Foureir transform of f(t), which is F(v),
and a continuous-time Foureir transform needs to integrate from -infinity to
+infinity.
It's too complicated, and there is no closed-form solution. So I need to
compute the Foureir transform numerically...
How to do that? I have some past experience with FFT but now I need to renew
my memory.
Please give me some pointers about how to convert the infinite range
integration to finite sums in FFT?
Moreover, the Foureir transform can also be computed by numerical
integration, what's the disadvantage and advantage of both approaches?
Before I begin the work, I would like to hear your expert opinions and
comments about these approaches.
Thanks a lot!
On 18 May, 08:27, "Mike" <meathea...@gmail.com> wrote:
> Hi all, > > I want to take Foureir transform of f(t), which is F(v), > > and a continuous-time Foureir transform needs to integrate from -infinity to > +infinity. > > It's too complicated, and there is no closed-form solution. So I need to > compute the Foureir transform numerically... > > How to do that? I have some past experience with FFT but now I need to renew > my memory. > > Please give me some pointers about how to convert the infinite range > integration to finite sums in FFT? > > Moreover, the Foureir transform can also be computed by numerical > integration, what's the disadvantage and advantage of both approaches? > Before I begin the work, I would like to hear your expert opinions and > comments about these approaches. > > Thanks a lot!
All methods of numerical integration involve making an approximation and assuming the curve to be smooth. FFT has the advantage of being a Log(2)N method. It is as valid as any spline method. The disadvantage of FFT and the advantage of splines is that you don't have to have uniform spacing of points. As far as infinity is concerned, you need to look at your function and decide how it behaves with large v. Are you certain BTW that the integral is finite? If you are you need to integrate by some non numerical method from your cut off point to infinity. At large v an integral must either be 1/x^n or be infinite. - Ian Parker As far
"Ian Parker" <ianparker2@gmail.com> wrote in message
news:1179485500.108252.79330@w5g2000hsg.googlegroups.com...
> On 18 May, 08:27, "Mike" <meathea...@gmail.com> wrote: >> Hi all, >> >> I want to take Foureir transform of f(t), which is F(v), >> >> and a continuous-time Foureir transform needs to integrate from -infinity >> to >> +infinity. >> >> It's too complicated, and there is no closed-form solution. So I need to >> compute the Foureir transform numerically... >> >> How to do that? I have some past experience with FFT but now I need to >> renew >> my memory. >> >> Please give me some pointers about how to convert the infinite range >> integration to finite sums in FFT? >> >> Moreover, the Foureir transform can also be computed by numerical >> integration, what's the disadvantage and advantage of both approaches? >> Before I begin the work, I would like to hear your expert opinions and >> comments about these approaches. >> >> Thanks a lot! > > All methods of numerical integration involve making an approximation > and assuming the curve to be smooth. FFT has the advantage of being a > Log(2)N method. It is as valid as any spline method. The disadvantage > of FFT and the advantage of splines is that you don't have to have > uniform spacing of points. > > As far as infinity is concerned, you need to look at your function and > decide how it behaves with large v. Are you certain BTW that the > integral is finite? If you are you need to integrate by some non > numerical method from your cut off point to infinity. At large v an > integral must either be 1/x^n or be infinite. > > > - Ian Parker > > As far >
I just don't understand in practice how people use FFT to do Foureir transform, because it is almost always an infinite integral. We know that if a signal is finite support in time domain, then it is infinite support in spectrum domain; vice versa. So anyway people will have to face the infinite support problem, no matter if they use FFT or numerical integration. How do they handle this nicely? FFT is highly optimized throughout the years, but it uses uniform samplings; of course I can imagine over the years people invented non-uniform sampling FFT, but less efficient since they are less popular. But on the other hand, numerical integration such as Gaussian Quardrature method etc. are also highly optimized and they are supposed to use "smart" and "adaptive" sampling points. Does anybody have a comparison between them? I am still not sure about the points you made about the infinite integral part. Do you mean I have to truncate at some large range, and then use other ways to compute tail integral?
Fourier transform
no, you only need to look at the frequency range you need for a result, otherwise the fft isn't viable
the fft algorithms are widely availably, any C compiler or math package has them
people use the fft (fast fourier transform) simply because it is computationaly more efficient than doing all the matrix multiplication that a finite elements fourier transform requires. for instance, if you want to minimise badwidth for realtime voice transmission, you take the audio signal, put it into the frequency domain, and keep only the useful frequencies (20hz - 8 Khz) send that to the reciever, who can do the ifft (inverse fast fourier transform) which outputs the voice, and little else. the fft was discovered by accident and solved a lot of problems in realtime spectral analysis at a time when computer speed was limited. the same thing can be acheived by the fourier transorm, it just takes much longer for each packet. the other thing about the fft is that it is fairly accurate, there is always a small loss with numerical methods, but the fft is quite reliable.
if you want an infinite range you have to do the maths. if you want to convert discreet samples into the frequency domain, use the fft.
> Thanks a lot!
derek
Mike wrote:
> Hi all, > > I want to take Foureir transform of f(t), which is F(v), > > and a continuous-time Foureir transform needs to integrate from -infinity to > +infinity. > > It's too complicated, and there is no closed-form solution. So I need to > compute the Foureir transform numerically... > > How to do that? I have some past experience with FFT but now I need to renew > my memory. > > Please give me some pointers about how to convert the infinite range > integration to finite sums in FFT? > > Moreover, the Foureir transform can also be computed by numerical > integration, what's the disadvantage and advantage of both approaches? > Before I begin the work, I would like to hear your expert opinions and > comments about these approaches. > > Thanks a lot! > >
A document accessible from http://mathalacarte.com/c/math77_head.html (then go to item 10.0 for the link to the document) may be of some use to you. Fred
Mike wrote:
> I just don't understand in practice how people use FFT to do Foureir > transform, because it is almost always an infinite integral. We know that if > a signal is finite support in time domain, then it is infinite support in > spectrum domain; vice versa. So anyway people will have to face the infinite > support problem, no matter if they use FFT or numerical integration. How do > they handle this nicely?
The FFT is misnamed, it is actually a Fourier series. But then much of computing deals with approximations, including Fortran's REAL variables which include only a small subset of the real line.
> FFT is highly optimized throughout the years, but it uses uniform samplings; > of course I can imagine over the years people invented non-uniform sampling > FFT, but less efficient since they are less popular. But on the other hand, > numerical integration such as Gaussian Quardrature method etc. are also > highly optimized and they are supposed to use "smart" and "adaptive" > sampling points. Does anybody have a comparison between them?
Gaussian quadrature is not adaptive, but takes advantage of the 2N degrees of freedom available choosing the position and magnitude of each sample point. With the assumption that the integrand is a polynomial, it works well. http://mathworld.wolfram.com/GaussianQuadrature.html
> I am still not sure about the points you made about the infinite integral > part. Do you mean I have to truncate at some large range, and then use other > ways to compute tail integral?
An indefinite integral doesn't have a numerical value. That is what the +C indicates. -- glen
Even so, there's a usual caveat - use at your own risk and *ymmv*, and particularly so when dealing with infinite intervals. Case in point, integrate sinc(t) from zero to inf with quadpack code for such matters, http://netlib.org/quadpack/qagi.f a globally adaptive quadrature integrator for infinite intervals. Since the integral is known - pi/2 - it is less than comforting how poor the result turns out to be. --- sdx - modeling, simulation. http://www.sdynamix.com
"glen herrmannsfeldt" <gah@ugcs.caltech.edu> wrote in message
news:1tWdnfuwYPN6uNPbnZ2dnUVZ_rTinZ2d@comcast.com...
: Mike wrote:
: > I just don't understand in practice how people use FFT to do Foureir
: > transform, because it is almost always an infinite integral. We know
that if
: > a signal is finite support in time domain, then it is infinite support
in
: > spectrum domain; vice versa. So anyway people will have to face the
infinite
: > support problem, no matter if they use FFT or numerical integration. How
do
: > they handle this nicely?
: The FFT is misnamed, it is actually a Fourier series.
Correct, and  FFT means Fast Fourier Transform.
"Fast" depends on the computer used, so it's doubly misnomered.
:  But then much
: of computing deals with approximations, including Fortran's REAL
: variables which include only a small subset of the real line.
There is a target value and a tolerance. In the case of Fourier, there is
also a limit to the number of frequencies to be considered.
Computers are as exact as we want them to be.
When a mathematician writes "pi" he means an exact quantity.
When a computer produces 3.1415926535897932384626433832795
then that's as exact as I want it to be, but it's not pi.
: > FFT is highly optimized throughout the years, but it uses uniform
samplings;
: > of course I can imagine over the years people invented non-uniform
sampling
: > FFT, but less efficient since they are less popular. But on the other
hand,
: > numerical integration such as Gaussian Quardrature method etc. are also
: > highly optimized and they are supposed to use "smart" and "adaptive"
: > sampling points. Does anybody have a comparison between them?
: Gaussian quadrature is not adaptive, but takes advantage of the 2N
: degrees of freedom available choosing the position and magnitude
: of each sample point.  With the assumption that the integrand
: is a polynomial, it works well.
: http://mathworld.wolfram.com/GaussianQuadrature.html
: > I am still not sure about the points you made about the infinite
integral
: > part. Do you mean I have to truncate at some large range, and then use
other
: > ways to compute tail integral?
: An indefinite integral doesn't have a numerical value.
Correct.
: That is what the +C indicates.
Huh?
An indefinite integral is analytical; it has no predefined limits
and is expressed as a function.
A definite integral has a value, the limits are known.
Explain, please.
robert wrote:
>> I want to take Foureir transform of f(t), which is F(v), > > Fourier transform
> ... discreet samples ...
Discrete samples. :-) -- Dr Jon D Harrop, Flying Frog Consultancy The F#.NET Journal http://www.ffconsultancy.com/products/fsharp_journal/?usenet
"widmar" <jrw@sdynamix.com> wrote in message
news:464E2B7D.26CB3D98@sdynamix.com...
> Mike wrote: >> >> FFT is highly optimized throughout the years, but it uses uniform >> samplings; >> of course I can imagine over the years people invented non-uniform >> sampling >> FFT, but less efficient since they are less popular. But on the other >> hand, >> numerical integration such as Gaussian Quardrature method etc. are also >> highly optimized and they are supposed to use "smart" and "adaptive" >> sampling points. > > Even so, there's a usual caveat - use at your own risk and *ymmv*, and > particularly so when dealing with infinite intervals. Case in point, > integrate sinc(t) from zero to inf with quadpack code for such matters, > > http://netlib.org/quadpack/qagi.f > > a globally adaptive quadrature integrator for infinite intervals. Since > the integral is known - pi/2 - it is less than comforting how poor the > result turns out to be. > > ---
I don't understand your reply. Are you saying that the numerical integration and FFT both fail when the integrand is "wierd"? I came to seek help because exactly the same problem -- I have met with a lot numerical difficulties in integration with infinite support... Any thoughts?
> sdx - modeling, simulation. > http://www.sdynamix.com >
