Hi, I am setting up for development on TI 55x DSP and need advice/ recommendation on the various emulators that are available. I am getting Code Composer Studio 3.3. I see that the TI web site list 510 and 560 class emulators. I have used the XDS510 in the past but 560 is new to me. How useful are the new features it is supposed to provide? Then, within each class, there are emulators from various manufacturers TI, Spectrum Digital, Wintec, Blackhawk, GAO, FlexDS. The price ranges from a few hundereds to 4000 for TI XDS560. So, I am not sure which one to get. I am using a laptop, so I was considering using a USB based device. What are your experiences with USB vs parallel port or PCMCIA interface? TIA.
Recommend TI DSP emulator
Started by ●May 18, 2007
Reply by ●May 19, 20072007-05-19
anemat01@gmail.com wrote:> Hi, > I am setting up for development on TI 55x DSP and need advice/ > recommendation on the various emulators that are available. I am > getting Code Composer Studio 3.3. I see that the TI web site list 510 > and 560 class emulators. I have used the XDS510 in the past but 560 > is new to me. How useful are the new features it is supposed to > provide? Then, within each class, there are emulators from various > manufacturers TI, Spectrum Digital, Wintec, Blackhawk, GAO, FlexDS. > The price ranges from a few hundereds to 4000 for TI XDS560. So, I am > not sure which one to get. I am using a laptop, so I was considering > using a USB based device. What are your experiences with USB vs > parallel port or PCMCIA interface? TIA. >I recommend you purchase an XDS510 emulator. The additional features you gain from an XDS560 emulator are only available on some of the high end c6000 DSPs. Specifically, I recommend the USB510 from Blackhawk. It's small, bus-powered, durable, and most importantly it's fast! I believe it costs in the neighborhood of $1700-$1800. Brad
Brad Griffis <bradgriffis@hotmail.com> writes:> anemat01@gmail.com wrote: >> Hi, >> I am setting up for development on TI 55x DSP and need advice/ >> recommendation on the various emulators that are available. I am >> getting Code Composer Studio 3.3. I see that the TI web site list 510 >> and 560 class emulators. I have used the XDS510 in the past but 560 >> is new to me. How useful are the new features it is supposed to >> provide? Then, within each class, there are emulators from various >> manufacturers TI, Spectrum Digital, Wintec, Blackhawk, GAO, FlexDS. >> The price ranges from a few hundereds to 4000 for TI XDS560. So, I am >> not sure which one to get. I am using a laptop, so I was considering >> using a USB based device. What are your experiences with USB vs >> parallel port or PCMCIA interface? TIA. >> > > I recommend you purchase an XDS510 emulator. The additional features > you gain from an XDS560 emulator are only available on some of the > high end c6000 DSPs.Hi Brad, I thought the XDS560 had a significantly higher data transfer rate between the host interface (e.g., USB) and the target, so that, e.g., program downloads were much quicker and more monitoring on the host was feasible. Is this not true? -- % Randy Yates % "She tells me that she likes me very much, %% Fuquay-Varina, NC % but when I try to touch, she makes it %%% 919-577-9882 % all too clear." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
Reply by ●May 20, 20072007-05-20
Randy Yates wrote:> Brad Griffis <bradgriffis@hotmail.com> writes: > >> anemat01@gmail.com wrote: >>> Hi, >>> I am setting up for development on TI 55x DSP and need advice/ >>> recommendation on the various emulators that are available. I am >>> getting Code Composer Studio 3.3. I see that the TI web site list 510 >>> and 560 class emulators. I have used the XDS510 in the past but 560 >>> is new to me. How useful are the new features it is supposed to >>> provide? Then, within each class, there are emulators from various >>> manufacturers TI, Spectrum Digital, Wintec, Blackhawk, GAO, FlexDS. >>> The price ranges from a few hundereds to 4000 for TI XDS560. So, I am >>> not sure which one to get. I am using a laptop, so I was considering >>> using a USB based device. What are your experiences with USB vs >>> parallel port or PCMCIA interface? TIA. >>> >> I recommend you purchase an XDS510 emulator. The additional features >> you gain from an XDS560 emulator are only available on some of the >> high end c6000 DSPs. > > Hi Brad, > > I thought the XDS560 had a significantly higher data transfer rate > between the host interface (e.g., USB) and the target, so that, e.g., > program downloads were much quicker and more monitoring on the host > was feasible. > > Is this not true?Randy, That is partially true, but not the whole story. That is, the 560 emulators tend to be the fastest, but not necessarily by much. The higher date rate comes primarily from an adaptive algorithm in the emulator to set the TCLK frequency. The Spectrum Digital XDS510USB did not use this and so it would always run TCLK at about 10 MHz. On the other hand the TI XDS560 emulator would adaptively figure out how fast it could run generally achieving speeds between 25-35 MHz. Hence you'd get much faster downloads. That same principle is used by both the Blackhawk (BH) USB510 and BH USB560 emulators. This allows the BH USB510 to achieve download speeds close to that of a 560. I did some rough benchmarking a couple years ago between a BH USB560, BH USB510, Spectrum Digital (SD) XDS510USB, and SD XDS510 PP+. The results were that the BH USB560 was the best with the BH USB510 following closely behind. The SD emulators lagged far behind with the XDS510USB being only a little bit faster than the PP+. Since I did that testing SD has come out with a couple new emulators: the XDS510USB PLUS and the XDS560R. I've not tried out either of these. Of course download speed is not the whole story, there is also the speed of single-stepping through code, etc. to be taken into account. I never did any benchmarking of that. From general experience though I have found the 560 emulators to be only a hair faster. The place where an XDS560 emulator pays big dividends is with processors like the 6416 or 6455 which support high-speed real-time data exchange (HS-RTDX). To get all this benefit you need the 60-pin JTAG header which it seems most people don't use anyway. Those processors also support trace, though that requires a special $10,000 trace emulator. So to summarize I'd say if you're looking for the best emulator period then I'd recommend a 560. If you're looking for a good value that still has great performance then I'd recommend the BH USB510. Brad
Brad Griffis <bradgriffis@hotmail.com> writes:> [...]Excellent information! Thanks much, Brad. --Randy -- % Randy Yates % "...the answer lies within your soul %% Fuquay-Varina, NC % 'cause no one knows which side %%% 919-577-9882 % the coin will fall." %%%% <yates@ieee.org> % 'Big Wheels', *Out of the Blue*, ELO http://home.earthlink.net/~yatescr
