I am using Matlab's mfilt.cicinterp on a piece of data. Out of curiousity, I also tried to write my own CIC interpolation filter. I referred to Hogenhauers original paper (An Economical Class of Digital Filters for Decimation and Interpolation) as well as Matlab's documentation for mfilt.cicinterp at http://www.mathworks.com/access/helpdesk/help/toolbox/filterdesign/index.html?/access/helpdesk/help/toolbox/filterdesign/ref/mfilt.cicinterp.html Based on that I have the following dilemma:>> u=(-1).^(1:20); % alternating +1 and -1; >> Hm=mfilt.cicinterp(2,1,1); % 2x interpolation with one stage CIC >> y1=filter(Hm, u);This chunk of code gives me y1= [0 -1 -1 1 1 -1 -1 1 1 ... -1 -1 1]; Now I try to simulate Matlab's CIC block diagram in following code:>> function z=CICInt(u,R,N)>> L=length(u); >> y=u; % buffer for differentiator stage >> y1=0*y; >> dcG=R^(N-1); % dc gain>> for i=1:N >> for j=2:L >> y1(j)=y(j)-y(j-1); % differentiator >> end >> y=y1; >> y1=0*y; >> end >> z=upsample(y,R); % upsampling >> z1=0*z; % initialize z1, output of each stage >> for i=1:N >> for j=2:L*R >> z1(j)=z(j)+z1(j-1); % delaying integrator >> end >> z=[0 z1(1:end-1)]; % delay output for next stage and call it inputfor next stage>> z1=0*z; % re-initialize output buffer >> end >> z=z/dcG; % scale outputWhen I run this on the same input I get [0 0 0 2 2 0 0 2 2 0 0 2 2 0 0 ... 0 2]. Where am I going wrong? I put in a probe point after the upsampling and the input to the integrator stage is [0 0 2 0 -2 0 2 0 -2 ... 2 0] which makes sense. Probably something immensely trivial that I am missing, but 4 cups of coffee later, I need help :-) _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
Trying to understand CIC interpolation
Started by ●May 21, 2007
Reply by ●June 3, 20072007-06-03
On Mon, 21 May 2007 12:40:38 -0500, "somdeb" <somdeb@gmail.com> wrote:>I am using Matlab's mfilt.cicinterp on a piece of data. Out of curiousity, >I also tried to write my own CIC interpolation filter. I referred to >Hogenhauers original paper (An Economical Class of Digital Filters for >Decimation and Interpolation) as well as Matlab's documentation for >mfilt.cicinterp at >http://www.mathworks.com/access/helpdesk/help/toolbox/filterdesign/index.html?/access/helpdesk/help/toolbox/filterdesign/ref/mfilt.cicinterp.html >(snipped) Hello somdeb, I don't know if it will help you much, or not, but you might take a look at: http://www.embedded.com/shared/printableArticle.jhtml?articleID=160400592 Good Luck, [-Rick-]
Reply by ●July 1, 20072007-07-01
On May 21, 10:40 pm, "somdeb" <som...@gmail.com> wrote:> I am using Matlab's mfilt.cicinterp on a piece of data. Out of curiousity, > I also tried to write my own CIC interpolation filter. I referred to > Hogenhauers original paper (An Economical Class of Digital Filters for > Decimation and Interpolation) as well as Matlab's documentation for > mfilt.cicinterp athttp://www.mathworks.com/access/helpdesk/help/toolbox/filterdesign/in... > > Based on that I have the following dilemma: > > >> u=(-1).^(1:20); % alternating +1 and -1; > >> Hm=mfilt.cicinterp(2,1,1); % 2x interpolation with one stage CIC > >> y1=filter(Hm, u); > > This chunk of code gives me y1= [0 -1 -1 1 1 -1 -1 1 1 ... -1 -1 1]; > > Now I try to simulate Matlab's CIC block diagram in following code: > > > > > > >> function z=CICInt(u,R,N) > >> L=length(u); > >> y=u; % buffer for differentiator stage > >> y1=0*y; > >> dcG=R^(N-1); % dc gain > >> for i=1:N > >> for j=2:L > >> y1(j)=y(j)-y(j-1); % differentiator > >> end > >> y=y1; > >> y1=0*y; > >> end > >> z=upsample(y,R); % upsampling > >> z1=0*z; % initialize z1, output of each stage > >> for i=1:N > >> for j=2:L*R > >> z1(j)=z(j)+z1(j-1); % delaying integrator > >> end > >> z=[0 z1(1:end-1)]; % delay output for next stage and call it input > for next stage > >> z1=0*z; % re-initialize output buffer > >> end > >> z=z/dcG; % scale output > > When I run this on the same input I get [0 0 0 2 2 0 0 2 2 0 0 2 2 0 0 ... > 0 2].Looking at the code snippet which you have provided, it seems a bit too verbose than what is required. The output seems to be wrong too... :-) If I understand correctly, your objective is to u=(-1).^(1:20); u1 = [u ; zeros(1,length(u))]; u1 = u1(:).'; % zero inserted o = conv(u1, ones(1,2)); % op of filtering for a simple for-loop code (matching with the hardware block diagram), maybe you can have a look @ the blog post http://dsplog.blogspot.com/2007/07/example-of-cascaded-integrator-comb.html> > Where am I going wrong? I put in a probe point after the upsampling and > the input to the integrator stage is [0 0 2 0 -2 0 2 0 -2 ... 2 0] which > makes sense. > > Probably something immensely trivial that I am missing, but 4 cups of > coffee later, I need help :-)Hope this helps. Regards, Krishna http://dsplog.blogspot.com> > _____________________________________ > Do you know a company who employs DSP engineers? > Is it already listed athttp://dsprelated.com/employers.php?
Reply by ●July 4, 20072007-07-04
On May 21, 1:40 pm, "somdeb" <som...@gmail.com> wrote:> I am using Matlab's mfilt.cicinterp on a piece of data. Out of curiousity, > I also tried to write my own CIC interpolation filter. I referred to > Hogenhauers original paper (An Economical Class of Digital Filters for > Decimation and Interpolation) as well as Matlab's documentation for > mfilt.cicinterp athttp://www.mathworks.com/access/helpdesk/help/toolbox/filterdesign/in... > > Based on that I have the following dilemma: > > >> u=(-1).^(1:20); % alternating +1 and -1; > >> Hm=mfilt.cicinterp(2,1,1); % 2x interpolation with one stage CIC > >> y1=filter(Hm, u); > > This chunk of code gives me y1= [0 -1 -1 1 1 -1 -1 1 1 ... -1 -1 1]; > > Now I try to simulate Matlab's CIC block diagram in following code: > > > > > > > > >> function z=CICInt(u,R,N) > >> L=length(u); > >> y=u; % buffer for differentiator stage > >> y1=0*y; > >> dcG=R^(N-1); % dc gain > >> for i=1:N > >> for j=2:L > >> y1(j)=y(j)-y(j-1); % differentiator > >> end > >> y=y1; > >> y1=0*y; > >> end > >> z=upsample(y,R); % upsampling > >> z1=0*z; % initialize z1, output of each stage > >> for i=1:N > >> for j=2:L*R > >> z1(j)=z(j)+z1(j-1); % delaying integrator > >> end > >> z=[0 z1(1:end-1)]; % delay output for next stage and call it input > for next stage > >> z1=0*z; % re-initialize output buffer > >> end > >> z=z/dcG; % scale output > > When I run this on the same input I get [0 0 0 2 2 0 0 2 2 0 0 2 2 0 0 ... > 0 2]. > > Where am I going wrong? I put in a probe point after the upsampling and > the input to the integrator stage is [0 0 2 0 -2 0 2 0 -2 ... 2 0] which > makes sense. > > Probably something immensely trivial that I am missing, but 4 cups of > coffee later, I need help :-) > > _____________________________________ > Do you know a company who employs DSP engineers? > Is it already listed athttp://dsprelated.com/employers.php?- Hide quoted text - > > - Show quoted text -somedeb, This is certainly a late response to the original post, but WTH, Krishna popped it up to the top of the list. The difference in your two outputs appears to be because: 1) The first output of your differentiator is not set properly. 2) The first output of your integrator is not set properly. Comments: 1) The delay of the output you intoduce by inserting a leading zero is only required to align your output to that from your 3 line MATLAB code and can be eliminated in practice. 2) The CIC interpolation filter is really intended to be used on something that is already oversampled, your test signal is not. Consequently, the filter gain giving the desired output signal is not the low freq gain of the filter set in the MATLAB script, because it is not a low freq. 3) Test your final code rigorously on some other signals. Dirk
[snip]> 2) The CIC interpolation filter is really intended to be used on > something that is already oversampled, your test signal is not. > Consequently, the filter gain giving the desired output signal is not > the low freq gain of the filter set in the MATLAB script, because it > is not a low freq.In somdeb's code, there is code for upsampling (in between differentiator code and integrator code). Regards, Krishna http://dsplog.blogspot.com
On Jul 4, 8:17 am, Krishna <krishna.pil...@gmail.com> wrote:> [snip] > > > 2) The CIC interpolation filter is really intended to be used on > > something that is already oversampled, your test signal is not. > > Consequently, the filter gain giving the desired output signal is not > > the low freq gain of the filter set in the MATLAB script, because it > > is not a low freq. > > In somdeb's code, there is code for upsampling (in between > differentiator code and integrator code). > > Regards, > Krishnahttp://dsplog.blogspot.comKrishna, All that code does is stuff zeros between original samples. That is part of the CIC filter. A CIC interpolator is intended to be applied to oversampled original signals. Dirk
On Jul 4, 1:53 pm, dbell <bellda2...@cox.net> wrote:> On Jul 4, 8:17 am, Krishna <krishna.pil...@gmail.com> wrote: > > > [snip] > > > > 2) The CIC interpolation filter is really intended to be used on > > > something that is already oversampled, your test signal is not. > > > Consequently, the filter gain giving the desired output signal is not > > > the low freq gain of the filter set in the MATLAB script, because it > > > is not a low freq. > > > In somdeb's code, there is code for upsampling (in between > > differentiator code and integrator code). > > > Regards, > > Krishnahttp://dsplog.blogspot.com > > Krishna, > > All that code does is stuff zeros between original samples. That is > part of the CIC filter. A CIC interpolator is intended to be applied > to oversampled original signals. > > DirkKrishna, Rereading your response again I am now not sure what part of the comment 2) you were responding to. The zero padding is taken into account when the gain is calculated at the end of the script. If you interpolate alternating signed ones (magnitude 1 sine wave sampled at peaks, ... 1,-1,1,-1,1,...) and get pairs of alternating signed ones (...1,1,-1,-1,1,1,-1,-1,,...) that does not correspond to samples from an amplitude 1 sign wave. A CIC interpolator has gain near 1 near 0 Hz, and good attenuation of interpolation-related images for a GROSSLY oversampled (ie. severely lowpass frequency limited ) original signal. If I haven't responded to your objection, please restate. Regards, Dirk
Dirk, I was trying to comment on the statement: 2) The CIC interpolation filter is really intended to be used on> > something that is already oversampled, your test signal is not.I interpreted this as - "The input signal is not oversampled - hence the code is wrong". Maybe I made the wrong interpretation :) In the previous post, I tried to point out that the code has an upsampling stage inbetween differentiator and integrator stage (Refer the architecture shown in Figure9 of http://www.us.design-reuse.com/articles/article10028.html). Hence your statement on 'upsampling not being done' was not accurate. Additionally, I do not understand the comment:> If you > interpolate alternating signed ones (magnitude 1 sine wave sampled attem > peaks, ... 1,-1,1,-1,1,...) and get pairs of alternating signed ones > (...1,1,-1,-1,1,1,-1,-1,,...) that does not correspond to samples from > an amplitude 1 sign wave.Repeating the same sample twice is a form of filtering with almost sinc() shaped transfer function. Agree? Regards, Krishna http://dsplog.blogspot.com
Reply by ●July 5, 20072007-07-05
On Jul 4, 10:40 pm, Krishna <krishna.pil...@gmail.com> wrote:> Dirk, > > I was trying to comment on the statement: > 2) The CIC interpolation filter is really intended to be used on> > something that is already oversampled, your test signal is not. > > I interpreted this as - "The input signal is not oversampled - hence > the code is wrong".Krishna, I have no idea why you would make that interpretation. The comment had nothing to do with the code, just the test signal. Remember the CIC filter is really a pretty poor filter as a general lowpass filter. When interpolating, it greatly attenuates images over a very small region/regions, so the original lowpass bandwidth whose images (resulting from the CIC filter) you want filtered out must be very narrow bandwidth to start with. Normally the input signal would be extremely lowpass bandlimited (compared to its sample rate), either because it was originally bandlimited, or it was interpolated up to be, by interpolation methods more appropriate for a signal that has not been severely bandlimited relative to its original sample rate. A CIC interpolation filter is often used as the final filter(s) in a chain of interpolation filters that might be [FIR filter, interpolating halfband filters, CIC filters], such as part of a chip that does 'Digital Up Conversion(DUC)'. The test signal is not in a range that you would normally use a CIC filter on for interpolation. You would probably only use it because you know what the output should be for that particular input, as one of your test signals for the code. A further shortcoming of the test signal is explained below. Maybe I made the wrong interpretation :)> In the previous post, I tried to point out that the code has an > upsampling stage inbetween differentiator and integrator stage > (Refer the architecture shown in Figure9 ofhttp://www.us.design-reuse.com/articles/article10028.html). > Hence your statement on 'upsampling not being done' was not accurate. >I never made the statement that "upsampling not being done". What post are you refering to?> Additionally, I do not understand the comment: > > > If you > > interpolate alternating signed ones (magnitude 1 sine wave sampled attem > > peaks, ... 1,-1,1,-1,1,...) and get pairs of alternating signed ones > > (...1,1,-1,-1,1,1,-1,-1,,...) that does not correspond to samples from > > an amplitude 1 sign wave. >First, excuse my proofreading, that should be "sine wave" not "sign wave". Also, assuming the test signal is intending to represent a sinusoid, my implication that it had to come from an amplitude 1 sinusoid is incorrect. In fact, the sinusoidal signal amplitude of the signal that the test signal could have come from cannot be determined from the samples, because the signal frequency is half the sample rate. With the appropriate phase it could be samples of a sinusoid with signal frequency of half the input sample rate and ANY amplitude >= 1.0. So you cannot use the test signal to determine a non-zero system gain at the test signal frequency. On the other hand, the output from the test signal (assuming a sinusoid) does have an unambiguous amplitude of sqrt(2).> Repeating the same sample twice is a form of filtering with almost > sinc() shaped transfer > function. Agree?Repeating the same signal twice is adequate for interpolation only if your input is already sufficiently oversampled. If you are looking for a flat requency response, a sinc() shaped transfer function is pretty poor. Regards, Dirk> > Regards, > Krishnahttp://dsplog.blogspot.com
Reply by ●July 6, 20072007-07-06
Thanks Dirk. I understand your perspective now. Your comments were on the appropriateness of using CIC filter for the example test signal and I interpreted them as comments on the code - yes, it finally seeped in :) Thanks, Krishna http://dsplog.blogspot.com
