hi, i'm very new with DSP FIR. i need to make a Bandpass filter with FIR design. first, i use the AM signal for the input, then i want to get the information signal by filtering the AM signal. The problem is to get the value of transfer function of the FIR filter, i need a mathematical equation, i don't know where to start and what equation or theory to use?! can you give me an equation to start? or an example to design FIR filter? this is for my thesis, and i'm using the DSK TMS320C54... please give me some input...thanks... _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
How to design FIR filter with matematical equation?
Started by ●May 23, 2007
Reply by ●May 24, 20072007-05-24
On May 23, 7:11 am, "c1910" <c_19...@hotmail.com> wrote:> hi, > i'm very new with DSP FIR. > i need to make a Bandpass filter with FIR design. first, i use the AM > signal for the input, then i want to get the information signal by > filtering the AM signal. > The problem is to get the value of transfer function of the FIR filter, i > need a mathematical equation, > i don't know where to start and what equation or theory to use?! > can you give me an equation to start? > or an example to design FIR filter? > this is for my thesis, and i'm using the DSK TMS320C54... > please give me some input...thanks... >To add to Clay's suggestion, in general there are very few cases where there is a closed-form, algebraic rational solution to the design of an FIR filter. There are several things that you can try, these are called "Chebyshev filter", "Butterworth filter", etc. It is possible to use frequency translation to get a passband filter. Realize that the ideal lowpass/bandpass/highpass filter does not admit a rational, algebraic solution. The term Chebyshev refers to the polynomial approximation by the same name. However, one major discovery in the 70s was that it is possible to cast the design problem as an optimization, which turn out that it can be done as a linear programming problem. This is what is today called the Remez exchange algorithm, Parks- McClellan, etc. Hope that helps, Julius
