I have a legacy application that runs on a 6713 that uses the BIOS for scheduling and IRQ handling. I am using CC 3.1. Four mcasp channels are steered into a single edma channel, and 4Kx32 buffers are stored. I volunteered to code and test a modification where the 4 MCASP channels were replaced with a 4Kx32 block transfer over the emif. Seems straight forward enough. I am collecting emif blocks fine, but at the conclusion of the block transfer, my ISR is being invoked multiple times. (16 x on one block transfer .. but this degrades into continous IRQs when transfers are sustained). I have one call, several emails into TI ... still waiting for a response. [1] So ideas as to what I am doing wrong? The documentation on the linkages between the DSP EDMA IRQ dispatcher are minimal/nonexistent. I can provide my code in next posting ... but I think the symptom may be enough at this point. [2] I found a related problem on dsprelated.com from June 2003. The user believed a solution was to bypass the HWI IRQ dispatcher function, and requested details on how to proceed. He received a really good reply where 3 step process identified (create asm HWI handler to save config, enter C handler; create a C ISR, and change BIOS function link to asm handler. I can't seem to "fill in the steps of the asm handler for the C6713. Namely, can't find equivalent include filss or description of what is passed to HWI_enter/HWI exit. I am FPGA designer, but I thought this would be easy enough to tackle. What I thought might only take a day has taken over 10 days, and I am not done. I am finding reference material, but it is fairly distibuted, and not enough to come to compete closure. Thanks in advance. Here is the step 1 for creating asm for c62 series processor. ------------------------------------------------------------------------- 1) Create an HWI handler in assembly (indeed, hwi.h62 cannot be used in a C file...) --------- hwi_int4.s62 - begin ------------- .include "c62.h62" .include "hwi.h62" .text .global _hwi_int4_c_handler .global _hwi_int4_handler _hwi_int4_handler: ; Save Context HWI_enter C64_ATEMPS, C64_BTEMPS, C64_CTEMPS, 0xFFFF, 0 ; Clear int source mvkl 0x0000010, a3 ; assuming here Int4 mvc a3, ICR ; Call int handler b _hwi_int4_c_handler ; assuming near call is ok (memory model) mvkl _hwi_int4_end, b3 mvkh _hwi_int4_end, b3 nop 3 _hwi_int4_end: ; Restore context HWI_exit C64_ATEMPS, C64_BTEMPS, C64_CTEMPS, 0xFFFF, 0 .end ------------------------------------------------------------------ -- Regards, John Retta Owner and Designer Retta Technical Consulting Inc. 303-926-0068 email : jretta@rtc-inc.com web : www.rtc-inc.com
6713 multiple TCC IRQs for single EDMA block transfer when using DSP Bios
Started by ●May 25, 2007
Reply by ●May 26, 20072007-05-26
John Retta wrote:> I have a legacy application that runs on a 6713 that uses > the BIOS for scheduling and IRQ handling. I am using CC 3.1. > Four mcasp channels > are steered into a single edma channel, and 4Kx32 buffers are stored. > I volunteered to code and test a modification where the 4 MCASP channels > were replaced with a 4Kx32 block transfer over the emif. > > Seems straight forward enough. I am collecting emif blocks fine, but > at the conclusion of the block transfer, my ISR is being invoked > multiple times. (16 x on one block transfer .. but this degrades into > continous IRQs when transfers are sustained). > > I have one call, several emails into TI ... still waiting for a response. > > [1] So ideas as to what I am doing wrong? > The documentation on the linkages between the DSP EDMA IRQ dispatcher > are minimal/nonexistent. I can provide my code in next posting ... > but I think the symptom may be enough at this point. > > [2] I found a related problem on dsprelated.com from June 2003. > The user believed a solution was to bypass the HWI IRQ dispatcher function, > and requested details on how to proceed. He received a really good reply > where 3 step process identified (create asm HWI handler to > save config, enter C handler; create a C ISR, and change BIOS function > link to asm handler. I can't seem to "fill in the steps of the > asm handler for the C6713. Namely, can't find equivalent include filss > or description of what is passed to HWI_enter/HWI exit. > > I am FPGA designer, but I thought this would be easy enough to tackle. > What I thought might only take a day has taken over 10 days, and I am > not done. I am finding reference material, but it is fairly distibuted, > and not enough to come to compete closure. > > Thanks in advance. > > Here is the step 1 for creating asm for c62 series processor. > ------------------------------------------------------------------------- > > 1) Create an HWI handler in assembly (indeed, hwi.h62 cannot > be used in a C file...) > > --------- hwi_int4.s62 - begin ------------- > .include "c62.h62" > .include "hwi.h62" > > .text > .global _hwi_int4_c_handler > .global _hwi_int4_handler > > _hwi_int4_handler: > > ; Save Context > HWI_enter C64_ATEMPS, C64_BTEMPS, C64_CTEMPS, 0xFFFF, 0 > > ; Clear int source > mvkl 0x0000010, a3 ; assuming here Int4 > mvc a3, ICR > > ; Call int handler > b _hwi_int4_c_handler ; assuming near call is ok (memory model) > mvkl _hwi_int4_end, b3 > mvkh _hwi_int4_end, b3 > nop 3 > > _hwi_int4_end: > ; Restore context > HWI_exit C64_ATEMPS, C64_BTEMPS, C64_CTEMPS, 0xFFFF, 0 > > .end > > ------------------------------------------------------------------ >Yikes, I think you're headed in the wrong direction. I would definitely stick with your original scheme where EDMA_intDispatcher in conjunction with a handler for that specific transfer completion. The function EDMA_intDispatcher is actually a CSL function, not a BIOS function. Its purpose is simple: to read the CIPR register of the EDMA to determine which specific EDMA channel completed and then to call the corresponding handler. (FYI, it also clears the corresponding bit from CIPR so you wouldn't get the same interrupt over and over again). From what you describe it sounds like your issue is somewhere in your EDMA setup. Perhaps you should post your code being used to configure the EDMA Parameter Sets. Brad
Reply by ●May 28, 20072007-05-28
Okay ..here is my original code. I have tried two approaches. [1] The code as shown .... with the bios referencing _edmaIsr. I have the edma commented so that the link option is disabled. As I mentioned in the original email, if I allow one IRQ to be processed, I see that at the end of the 2x4Kx16 transfers on the emif, I see 16 calls to the ISR being made. If I enable // if (EDMA_intTest(EdmaMcAsp_RcvTcc)) and use that to clear EDMA_intClear(EdmaMcAsp_RcvTcc); then I can run for a few cycles before the ISR is not called. If I remove the above test, and unconditionally, issue EDMA_intClear(EdmaMcAsp_RcvTcc); the the ISR is called almost continuously. [2] Add the // EDMA_intHook(EdmaMcAsp_RcvTcc, edmaIsr); into the edma initialization routine, and change the BIOS setup to point to EDMA_intDispatcher. In this case, the edmaIsr is never entered. --------------------------------------------------------------- I appreciate your offer to review. I find debugging the problems like shooting in the dark. I suspect what I am doing is not that elaborate, I just can not find similar examples in TI documentation, or code composer help. Thanks in advance. ------------------------------------------------------------------ // Edma variables for McBsp static int McBspStartedFlag; static int McAspStartedFlag; static int EdmaXmtTcc; // XMIT Trasnfer Complete code static EDMA_Config Xmtcfg; // Config Structure for McBSP Xmit // Edma variables for McAsp static EDMA_Handle hEdmaMcAsp_RcvRld[ADBLKS]; // Reload-Link Parameter Blocks static int EdmaMcAsp_RcvTcc; // Receive Transfer Complete Code static int EdmaChARevt0; // Remapped EDMA Events void edmaIsr (void); #define DSP_FPGA_DMA (Uint32 *) 0xB0000398 #define DSP_CHIP_CTR (Uint32 *) 0xB00003C0 void InitEDMA_McAsp(void) { int i; EDMA_Config cfg; gAdBlkNum = -1; // Init Most recent blocknumber gAdBlkCnt = 0; // Init blk received counter // EdmaChARevt0 = EDMA_map(EDMA_CHA_AREVT0, 12); // McAsp0 Receive Event EdmaChARevt0 = EDMA_map(EDMA_CHA_EXTINT6, 12); // IRQ6 Event EdmaMcAsp_RcvTcc = EDMA_intAlloc(-1); // Allocate a trasnfer complete code, int number EDMA_intDisable (EdmaMcAsp_RcvTcc); // Disable Interupt, Clears bit in CIER EDMA_intClear (EdmaMcAsp_RcvTcc); // Clear any pending interrupt, Clears bit CIPR hEdmaMcAsp_Rcv = EDMA_open(EdmaChARevt0, EDMA_OPEN_RESET ); // Open the receive EDMA i = EDMA_allocTableEx(ADBLKS,&hEdmaMcAsp_RcvRld[0]); cfg.opt = EDMA_OPT_RMK( EDMA_OPT_PRI_LOW, EDMA_OPT_ESIZE_32BIT, EDMA_OPT_2DS_NO, EDMA_OPT_SUM_NONE, // Don't increment Source Adress EDMA_OPT_2DD_NO, // EDMA_OPT_DUM_IDX, // Increment Destination Address DUM = 011) EDMA_OPT_DUM_INC, // Increment Destination Address DUM = 011) EDMA_OPT_TCINT_YES, // Enable transfer Complete interrupt EDMA_OPT_TCC_OF(EdmaMcAsp_RcvTcc), // EDMA_OPT_LINK_YES, EDMA_OPT_LINK_NO, EDMA_OPT_FS_YES); // EDMA_OPT_FS_YES => FS = 0x1 cfg.src = EDMA_SRC_RMK( 0x80000000); cfg.dst = EDMA_DST_RMK(&gAdBuf[0]); cfg.cnt = EDMA_CNT_RMK(0, 2048); // 1 frame, 2048 elements cfg.idx = EDMA_IDX_RMK(8192,4); // (Bytes/frame,Bytes/element) cfg.rld = EDMA_RLD_RMK(2048, EDMA_getTableAddress(hEdmaMcAsp_RcvRld[0])); // cfg.rld = EDMA_RLD_RMK(0, 0); // Setup the primary EDMA Configuration for receive (Bit Definitions can be found in csl_edmahal.h.) EDMA_config (hEdmaMcAsp_Rcv, &cfg); for(i=0; i<ADBLKS;i++) { cfg.dst = EDMA_DST_RMK(&gAdBuf[2*i*ADBLK_LEN]); // 2* due to HS data. if(i != ADBLKS-1) cfg.rld = EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[i+1])); else cfg.rld = EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[0])); EDMA_config(hEdmaMcAsp_RcvRld[i], &cfg); } // EDMA_intHook(EdmaMcAsp_RcvTcc, edmaIsr); EDMA_intEnable(EdmaMcAsp_RcvTcc); // Sets the Tcc bit in the CIER return; } // InitEDMA_McAsp( ) // Setup the EDMA Interrupt to use the DSP/BIOS HWI Dispatcher void initEDMAInterrupt(void) { IRQ_globalEnable(); IRQ_nmiEnable(); IRQ_map(IRQ_EVT_EDMAINT, 8); IRQ_enable(IRQ_EVT_EDMAINT); // Enable EDMA-to-CPU interrupt ( interrupt 8 ) return; } void edmaIsr(void) { Uint32 t, ADC_BufErrCnt_prev; IfcHostStat *host_stat; msgObj msg; // Mailbox Message Object // *DSP_FPGA_DMA = 0x00000000; *DSP_CHIP_CTR = 0x00000000; // host_stat = &gHostStatus; // t = CLK_gethtime(); // if (McAspStartedFlag) STS_delta(&McaspRcvInt, t); // STS_set(&McaspRcvInt,t); // McAspStartedFlag = 1; // McAsp Receive EDMA Complete // if (EDMA_intTest(EdmaMcAsp_RcvTcc)) // { // ADC_BufErrCnt_prev = gADC_BufErrCnt; // if (gAdc_InProgressFlag == 2) // { // gADC_BufErrCnt++; // gRfInputStatus |= ADC_BUFFER_OVERWRITE_ERROR; // } // if (gADC_BufErrCnt != ADC_BufErrCnt_prev) // { // host_stat->adc_buf_error_count = gADC_BufErrCnt; // InterruptSBC(); // Status change; Set IRQ to SBC // } // gAdc_InProgressFlag++; gAdBlkCnt++; if(++gAdBlkNum == ADBLKS) {gAdBlkNum = 0;} // Indicate which block is full // if(gAdBlkNum != ADBLKS-1) // cfg.rld = EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[gAdBlkNum+1])); // else // cfg.rld = EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[0])); // EDMA_config(hEdmaMcAsp_RcvRld[i], &cfg); EDMA_intClear(EdmaMcAsp_RcvTcc); // Clear the Pending Flag // msg.msgId = EDMA_DONE; // msg.msgCmd = AD_BLKRDY; // post msg - timeout must be 0 for hwi // MBX_post(&mbxNextOp, &msg, 0); // then Send a message // } return; } ------------------------------------------------------------------ -- Regards, John Retta Owner and Designer Retta Technical Consulting Inc. 303-926-0068 email : jretta@rtc-inc.com web : www.rtc-inc.com "Brad Griffis" <bradgriffis@hotmail.com> wrote in message news:sZqdnaxvOPC8wMXbnZ2dnUVZ_hynnZ2d@comcast.com...> John Retta wrote: >> I have a legacy application that runs on a 6713 that uses >> the BIOS for scheduling and IRQ handling. I am using CC 3.1. >> Four mcasp channels >> are steered into a single edma channel, and 4Kx32 buffers are stored. >> I volunteered to code and test a modification where the 4 MCASP channels >> were replaced with a 4Kx32 block transfer over the emif. >> >> Seems straight forward enough. I am collecting emif blocks fine, but >> at the conclusion of the block transfer, my ISR is being invoked >> multiple times. (16 x on one block transfer .. but this degrades into >> continous IRQs when transfers are sustained). >> >> I have one call, several emails into TI ... still waiting for a response. >> >> [1] So ideas as to what I am doing wrong? >> The documentation on the linkages between the DSP EDMA IRQ dispatcher >> are minimal/nonexistent. I can provide my code in next posting ... >> but I think the symptom may be enough at this point. >> >> [2] I found a related problem on dsprelated.com from June 2003. >> The user believed a solution was to bypass the HWI IRQ dispatcher >> function, >> and requested details on how to proceed. He received a really good reply >> where 3 step process identified (create asm HWI handler to >> save config, enter C handler; create a C ISR, and change BIOS function >> link to asm handler. I can't seem to "fill in the steps of the >> asm handler for the C6713. Namely, can't find equivalent include filss >> or description of what is passed to HWI_enter/HWI exit. >> >> I am FPGA designer, but I thought this would be easy enough to tackle. >> What I thought might only take a day has taken over 10 days, and I am >> not done. I am finding reference material, but it is fairly distibuted, >> and not enough to come to compete closure. >> >> Thanks in advance. >> >> Here is the step 1 for creating asm for c62 series processor. >> ------------------------------------------------------------------------- >> >> 1) Create an HWI handler in assembly (indeed, hwi.h62 cannot >> be used in a C file...) >> >> --------- hwi_int4.s62 - begin ------------- >> .include "c62.h62" >> .include "hwi.h62" >> >> .text >> .global _hwi_int4_c_handler >> .global _hwi_int4_handler >> >> _hwi_int4_handler: >> >> ; Save Context >> HWI_enter C64_ATEMPS, C64_BTEMPS, C64_CTEMPS, 0xFFFF, 0 >> >> ; Clear int source >> mvkl 0x0000010, a3 ; assuming here Int4 >> mvc a3, ICR >> >> ; Call int handler >> b _hwi_int4_c_handler ; assuming near call is ok (memory model) >> mvkl _hwi_int4_end, b3 >> mvkh _hwi_int4_end, b3 >> nop 3 >> >> _hwi_int4_end: >> ; Restore context >> HWI_exit C64_ATEMPS, C64_BTEMPS, C64_CTEMPS, 0xFFFF, 0 >> >> .end >> >> ------------------------------------------------------------------ >> > > Yikes, I think you're headed in the wrong direction. I would definitely > stick with your original scheme where EDMA_intDispatcher in conjunction > with a handler for that specific transfer completion. > > The function EDMA_intDispatcher is actually a CSL function, not a BIOS > function. Its purpose is simple: to read the CIPR register of the EDMA > to determine which specific EDMA channel completed and then to call the > corresponding handler. (FYI, it also clears the corresponding bit from > CIPR so you wouldn't get the same interrupt over and over again). > > From what you describe it sounds like your issue is somewhere in your EDMA > setup. Perhaps you should post your code being used to configure the EDMA > Parameter Sets. > > Brad
Reply by ●May 29, 20072007-05-29
John Retta wrote:> Okay ..here is my original code. > > I have tried two approaches. > [1] The code as shown .... with the bios referencing _edmaIsr. > I have the edma commented so that the link option is disabled. > As I mentioned in the original email, if I allow one IRQ to be processed, > I see that at the end of the 2x4Kx16 transfers on the emif, I see 16 > calls to the ISR being made. If I enable > // if (EDMA_intTest(EdmaMcAsp_RcvTcc)) > and use that to clear > EDMA_intClear(EdmaMcAsp_RcvTcc); > then I can run for a few cycles before the ISR is not called. > If I remove the above test, and unconditionally, issue > EDMA_intClear(EdmaMcAsp_RcvTcc); > the the ISR is called almost continuously.It sounds like you're getting events in rapid fire! The edge for the next interrupt cannot occur until the next event happens. If they're coming in really fast this won't happen until you clear one. By the way, you may want to consider changing the ISR options in your BIOS configuration such that this ISR will not nest itself. On the HWI properties go to the "dispatcher" tab and you'll see an option for masking interrupts. Choose "self" such that it will not pre-empt itself and blow out the stack.> > [2] Add the > // EDMA_intHook(EdmaMcAsp_RcvTcc, edmaIsr); > into the edma initialization routine, and change the BIOS setup > to point to EDMA_intDispatcher. > > In this case, the edmaIsr is never entered.This is not at all what I would have expected. Can you try setting a breakpoint inside EDMA_intDispatcher to see whether you're never getting any EDMA interrupts or whether you're just not getting that specific interrupt? Also, did you set the breakpoint BEFORE you started running your code? Right now you have linking turned off so I would have expected only one transfer to occur so if the breakpoint wasn't already present you would have missed it.> --------------------------------------------------------------- > > I appreciate your offer to review. I find debugging the problems > like shooting in the dark. I suspect what I am doing is not that > elaborate, I just can not find similar examples in TI documentation, > or code composer help. > > Thanks in advance. > > ------------------------------------------------------------------ > // Edma variables for McBsp > static int McBspStartedFlag; > static int McAspStartedFlag; > static int EdmaXmtTcc; // XMIT Trasnfer Complete code > static EDMA_Config Xmtcfg; // Config Structure for McBSP Xmit > > // Edma variables for McAsp > static EDMA_Handle hEdmaMcAsp_RcvRld[ADBLKS]; // Reload-Link Parameter > Blocks > static int EdmaMcAsp_RcvTcc; // Receive Transfer > Complete Code > static int EdmaChARevt0; // Remapped EDMA Events > > void edmaIsr (void); > #define DSP_FPGA_DMA (Uint32 *) 0xB0000398 > #define DSP_CHIP_CTR (Uint32 *) 0xB00003C0 > > > void InitEDMA_McAsp(void) > { > int i; > EDMA_Config cfg; > > gAdBlkNum = -1; // Init Most recent blocknumber > gAdBlkCnt = 0; // Init blk received counter > > // EdmaChARevt0 = EDMA_map(EDMA_CHA_AREVT0, 12); // McAsp0 Receive Event > EdmaChARevt0 = EDMA_map(EDMA_CHA_EXTINT6, 12); // IRQ6 Event > EdmaMcAsp_RcvTcc = EDMA_intAlloc(-1); // Allocate a trasnfer complete code, > int number > EDMA_intDisable (EdmaMcAsp_RcvTcc); // Disable Interupt, Clears bit in > CIER > EDMA_intClear (EdmaMcAsp_RcvTcc); // Clear any pending interrupt, Clears > bit CIPR > > hEdmaMcAsp_Rcv = EDMA_open(EdmaChARevt0, EDMA_OPEN_RESET ); // Open the > receive EDMA > > i = EDMA_allocTableEx(ADBLKS,&hEdmaMcAsp_RcvRld[0]); > > cfg.opt = EDMA_OPT_RMK( > EDMA_OPT_PRI_LOW, > EDMA_OPT_ESIZE_32BIT, > EDMA_OPT_2DS_NO, > EDMA_OPT_SUM_NONE, // Don't increment Source Adress > EDMA_OPT_2DD_NO, > // EDMA_OPT_DUM_IDX, // Increment Destination Address DUM = 011) > EDMA_OPT_DUM_INC, // Increment Destination Address DUM = 011) > EDMA_OPT_TCINT_YES, // Enable transfer Complete interrupt > EDMA_OPT_TCC_OF(EdmaMcAsp_RcvTcc), > // EDMA_OPT_LINK_YES, > EDMA_OPT_LINK_NO, > EDMA_OPT_FS_YES); // EDMA_OPT_FS_YES => FS = 0x1Having frame synchronization turned on (FS_YES) means that for every McASP event that occurs the entire transfer will occur, not just one element of the transfer. Therefore you will get a completion interrupt every time there is an McASP RX event.> > cfg.src = EDMA_SRC_RMK( 0x80000000); > cfg.dst = EDMA_DST_RMK(&gAdBuf[0]); > cfg.cnt = EDMA_CNT_RMK(0, 2048); // 1 frame, 2048 elements > cfg.idx = EDMA_IDX_RMK(8192,4); // (Bytes/frame,Bytes/element) > cfg.rld = EDMA_RLD_RMK(2048, EDMA_getTableAddress(hEdmaMcAsp_RcvRld[0])); > // cfg.rld = EDMA_RLD_RMK(0, 0);You said up at the top you're trying to do a 2x4kx16 transfer. I don't see how this matches your parameters. You selected a 32-bit element size (4 bytes) and a 2048-element frame size.> > // Setup the primary EDMA Configuration for receive (Bit Definitions can be > found in csl_edmahal.h.) > > EDMA_config (hEdmaMcAsp_Rcv, &cfg); > > for(i=0; i<ADBLKS;i++) > { > cfg.dst = EDMA_DST_RMK(&gAdBuf[2*i*ADBLK_LEN]); // 2* due to HS data. > > if(i != ADBLKS-1) > cfg.rld = > EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[i+1])); > else > cfg.rld = EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[0])); > > EDMA_config(hEdmaMcAsp_RcvRld[i], &cfg); > > } > > // EDMA_intHook(EdmaMcAsp_RcvTcc, edmaIsr); > EDMA_intEnable(EdmaMcAsp_RcvTcc); // Sets the Tcc bit in the CIER > > > return; > > } // InitEDMA_McAsp( )Where do you call EDMA_enableChannel? Unless that is implicit within EDMA_config I don't see anywhere that you've enabled the channel (i.e. set the corresponding EER bit). Of course you would never get any transfers without this so I assume this must be done somewhere!> > > // Setup the EDMA Interrupt to use the DSP/BIOS HWI Dispatcher > > void initEDMAInterrupt(void) > { > IRQ_globalEnable(); > IRQ_nmiEnable(); > IRQ_map(IRQ_EVT_EDMAINT, 8); > IRQ_enable(IRQ_EVT_EDMAINT); // Enable EDMA-to-CPU interrupt ( > interrupt 8 ) > return; > }If you've configured the interrupt in BIOS you shouldn't need the above code. Also, after you return from main BIOS will enable NMI and GIE for you.> > void edmaIsr(void) > { > Uint32 t, ADC_BufErrCnt_prev; > IfcHostStat *host_stat; > msgObj msg; // Mailbox Message Object > > // *DSP_FPGA_DMA = 0x00000000; > *DSP_CHIP_CTR = 0x00000000; > > // host_stat = &gHostStatus; > // t = CLK_gethtime(); > > // if (McAspStartedFlag) STS_delta(&McaspRcvInt, t); > // STS_set(&McaspRcvInt,t); > // McAspStartedFlag = 1; > > // McAsp Receive EDMA Complete > > // if (EDMA_intTest(EdmaMcAsp_RcvTcc)) > // { > // ADC_BufErrCnt_prev = gADC_BufErrCnt; > // if (gAdc_InProgressFlag == 2) > // { > // gADC_BufErrCnt++; > // gRfInputStatus |= ADC_BUFFER_OVERWRITE_ERROR; > // } > // if (gADC_BufErrCnt != ADC_BufErrCnt_prev) > // { > // host_stat->adc_buf_error_count = gADC_BufErrCnt; > // InterruptSBC(); // Status change; Set IRQ to SBC > // } > > // gAdc_InProgressFlag++; > > gAdBlkCnt++; > if(++gAdBlkNum == ADBLKS) {gAdBlkNum = 0;} // Indicate which block is > full > > // if(gAdBlkNum != ADBLKS-1) > // cfg.rld = > EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[gAdBlkNum+1])); > // else > // cfg.rld = > EDMA_RLD_RMK(2048,EDMA_getTableAddress(hEdmaMcAsp_RcvRld[0])); > > // EDMA_config(hEdmaMcAsp_RcvRld[i], &cfg); > EDMA_intClear(EdmaMcAsp_RcvTcc); // Clear the Pending Flag > > // msg.msgId = EDMA_DONE; > // msg.msgCmd = AD_BLKRDY; > // post msg - timeout must be 0 for hwi > // MBX_post(&mbxNextOp, &msg, 0); // then Send a message > // } > > return; > } > > > ------------------------------------------------------------------ > > >
Reply by ●May 30, 20072007-05-30
First of all ... thanks a great deal for assistance. A few clarifications .... [1] The block transfer size is 2x2Kx16. I mistyped when I stated 2x4Kx16. [2] Original EDMA was triggered off of MCASP rx event .... new code triggered off of external IRQ6. I left the function call names and variable names unchanged for now .... this may add confusion, but it keeps code comparison between original and new easy for now. // EdmaChARevt0 = EDMA_map(EDMA_CHA_AREVT0, 12); // McAsp0 Receive Event>> EdmaChARevt0 = EDMA_map(EDMA_CHA_EXTINT6, 12); // IRQ6 Event> By the way, you may want to consider changing the ISR options in your BIOS > configuration such that this ISR will not nest itself. On the HWI > properties go to the "dispatcher" tab and you'll see an option for masking > interrupts. Choose "self" such that it will not pre-empt itself and blow > out the stack.[3] Dispatcher tab was defaulted to masking self. But this was a good tip anyway. [4]> This is not at all what I would have expected. Can you try setting a > breakpoint inside EDMA_intDispatcher to see whether you're never getting > any EDMA interrupts or whether you're just not getting that specific > interrupt? > > Also, did you set the breakpoint BEFORE you started running your code? > Right now you have linking turned off so I would have expected only one > transfer to occur so if the breakpoint wasn't already present you would > have missed it.So I can tell not via breakpoints, but rather via a write to an external emif port which increments a counter I can also read over emif. The EDMA_intDispatcher is a CSL function ... I think it is a compiled library. I wish I had access to EDMA_intDispatcher source so I could instrument as you suggest. [5]> Where do you call EDMA_enableChannel? Unless that is implicit within > EDMA_config I don't see anywhere that you've enabled the channel (i.e. set > the corresponding EER bit). Of course you would never get any transfers > without this so I assume this must be done somewhere--------------------------------------------------------------------------
> So I can tell not via breakpoints, but rather via a write to an external > emif > port which increments a counter I can also read over emif. > The EDMA_intDispatcher is a CSL function ... I think it is a compiled > library. I wish I had access to EDMA_intDispatcher source so I could > instrument as you suggest.The source code for the csl is provided in its entirety. It's located in the .src file along with the .lib files. You can open that .src file in Wordpad or you can use the archiver utility to extract the original source files. The archiver will probably take you 20 minutes to figure out how to use it so I recommend just opening in Wordpad and pasting that one function into its own source file. Then you can instrument as you please. The source file will get resolved by the linker before any libraries. You never replied back regarding your use of the FS bit. You have it set which implies the entire transfer occurs at once. If you're reading from an A/D converter or something then you would only want to transfer one element at per sync event and you would need FS=0.
>> You never replied back regarding your use of the FS bit. You have it set >> which implies the entire transfer occurs at once. If you're reading from >> an A/D converter or something then you would only want to transfer one >> element at per sync event and you would need FS=0.I have data which is buffered in an FPGA in 2Kx32 (ie 2x2Kx16). -- Regards, John Retta email : jretta@rtc-inc.com web : www.rtc-inc.com
