Hi, I have designed a digital FM demodulator... I have a 70 MHz FI signal that I downconvert to baseband This demodulator works fine with Analog Bessel 24 order filter on I and Q signals before demodulating. When I change this filter with a digital FIR filter (phase lineartity) I have a -50 dB THD My message signal is a pure 10 MHz filter sine My -50 dB THD is due to a 20 Hz sine (2 order harmonic) with the analog bessel filter I have -80 dB THD I don't have the 20 MHz sine not on I and Q, not on IdQ-QdI but this second harmonic is on I=B2+Q=B2 !!! So on the (IdQ-QdI)/(I=B2+Q=B2) signal I have this 20 MHz at -50 dB !!! What kind of digital filter must I put on I branch and Q branch ? thanks.
THD digital FM demod
Started by ●June 2, 2007
Reply by ●June 2, 20072007-06-02
On Jun 2, 12:36 pm, fpga.vhdl.desig...@gmail.com wrote:> Hi, > > I have designed a digital FM demodulator... > > I have a 70 MHz FI signal that I downconvert to baseband > > This demodulator works fine with Analog Bessel 24 order filter on I > and Q signals before demodulating. > When I change this filter with a digital FIR filter (phase lineartity) > I have a -50 dB THD > > My message signal is a pure 10 MHz filter sine > > My -50 dB THD is due to a 20 Hz sine (2 order harmonic) with the > analog bessel filter I have -80 dB THD > > I don't have the 20 MHz sine not on I and Q, not on IdQ-QdI but this > second harmonic is on I=B2+Q=B2 !!! > > So on the (IdQ-QdI)/(I=B2+Q=B2) signal I have this 20 MHz at -50 dB !!! > > What kind of digital filter must I put on I branch and Q branch ? > > thanks.Hello - Some things I'm not clear on with your design. Is one case where you down convert, analog filter, sample and then demodulate, and the other case where you down convert, sample, digital filter and demodulate? If this is the case, you just might have a problem with aliasing. Also if you are inputting 10MHZ, then each of I^2 and Q^2 will have 20MHz components. But they should be 180deg out of phase so I^2 + Q^2 is constant. Make sure your internal sample rates will allow for the double frequency components. If you can, give more details about the signals, where the sampling and filtering occurs and in what order. Also are you sure that your I and Q signals are out of phase by 90 degrees and have equal gains. Feed them to a O'scope in x-y mode, and you should just plot a circle when you feed in just an unmodulated carrier. Set the carrier frequency so that after downconverting, it is not 0 hertz, but maybe something like 1000Hz. Are you really using a 24th order analog Bessel filter in your design? Wow! Clay
Reply by ●June 18, 20072007-06-18
Hi, I have interested also FM demodulation. If you want to co-operate please contact with me. murselonder (at) yahoo dot com murselonder (at) hotmail dot com -->msn adress
yes i sampling first the signal then downconvert to baseband then filter (in one case with analog 24th order bessel and second case FIR filter) It's only in matlab simulation I do that I look at the good digital filter that have the same THD performance than the bessel analog filter I don't know what kind of filter to put in theory this filter is just here to remove the double NCO frequency that do the downconversion but it have importance on the THD at the output of the demodulator do you know what kind of digital filter is to have a very good THD thanks
