Hello, I've recently developed an interest in software music synthesis, and five minutes of trying to comprehend sample code for a VSTi have shown me that I desperately need to learn the principles of DSP in order to get anywhere, and that I know nothing about it. So, I have two questions: 1) Generally speaking, what math/physics will I need to have under my belt? 2) Can you recommend any books to start with? Thanks in advance for your time. -GbJ
Beginner's references
Started by ●June 6, 2007
Reply by ●June 7, 20072007-06-07
gabriel.ben.jamin@gmail.com writes:> Hello, > > I've recently developed an interest in software music synthesis, and > five minutes of trying to comprehend sample code for a VSTi have shown > me that I desperately need to learn the principles of DSP in order to > get anywhere, and that I know nothing about it. > > So, I have two questions: 1) Generally speaking, what math/physics > will I need to have under my belt? 2) Can you recommend any books to > start with? > > Thanks in advance for your time.Hi GbJ, It probably wouldn't be a bad idea to have a look at the comp.dsp FAQ: http://www.bdti.com/faq/dsp_faq.htm It has some "bibles of DSP theory" and other references that may be useful. The mathematics for DSP ranges, depending on what you need to do, from basic algebra, trigonometry, and complex numbers through calculus, probability, and random processes, and even up to real and complex analysis and abstract algebra. However, you should be able to grasp 75 percent of DSP with a good grasp of algebra, complex numbers, and trig. -- % Randy Yates % "The dreamer, the unwoken fool - %% Fuquay-Varina, NC % in dreams, no pain will kiss the brow..." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO http://home.earthlink.net/~yatescr
Apart from general books on DSP, you will find books specifically devoted to audio and music programming very useful. One of the best is "Elements of Computer Music" by F.R. Moore (loads of C code in that apart from everything else), and another one is "A Digital Signal processing primer" by Ken Steiglitz. no code, more maths, but always with reference to audio and music. It is also a good idea to subscribe to the music-dsp mailing list: http://music.columbia.edu/mailman/listinfo/music-dsp and of course take a look at the musicdsp code archive too: http://www.musicdsp.org/ If you are just starting out on dsp programming, doing a VSTi (or any real-time plugin) is almost certainly too much to take on. Better to start with simple commandline programs (use libsndfile to read/write standard soundfiles) that are easy to debug and modify; and only incorporate your code into a VST plugin when the dsp side is largely tested and working. Most of the code in a VST plguin (especially if there is a GUI) has nothing to do with dsp! There is of course a ton++ of music-dsp code availoable on the net, especially in the large open source projetcs - Csound, PD, SuperCollider, CLAM, etc, all of which have active mailing lists associated with them. Richard Dobson gabriel.ben.jamin@gmail.com wrote:> Hello, > > I've recently developed an interest in software music synthesis, and > five minutes of trying to comprehend sample code for a VSTi have shown > me that I desperately need to learn the principles of DSP in order to > get anywhere, and that I know nothing about it. > > So, I have two questions: 1) Generally speaking, what math/physics > will I need to have under my belt? 2) Can you recommend any books to > start with? > > Thanks in advance for your time. > -GbJ >
