Michael A. Terrell <mike.terrell@earthlink.net> pinched out a steaming pile of<466AE488.44D532DB@earthlink.net>:>"���hw��f" wrote: >> >> Now then. They wouldnt "send a BIOS chip" since that isnt how you"fix" them.>> If the chip can be re-flashed that would be the way to go. >> >> Otherwise you replace the mobo since trying to de-solder a chip andreplace it>> would likely damage others in the process. > > ><http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2949323&CatId=1569>>shows it in a socket, but it takes a special extraction tool and >expensive adapter to program it off the motherboard. > >Well there you go :) Try flashing it first before you go prying things off?
Re: Asus A8N32-SLI Deluxe Backplate Questions.
Started by ●June 10, 2007
