Hi to everybody, As you can understand from the subject, i am trying to estimate durations of the pulses from the output of the matched filter. Let me explain you the problem. I have pulses that are seperated in time enough under 10 dB SNR white gaussian noise. The nominal pulse durations are 0.45 microseconds. However they may come 0.15 microseconds less than 0.45 microseconds. These narrower pulses should be accepted too. However, pulses which are 0.20(or more than this) microseconds shorter than the nominal pulse duration should be rejected. My sampling rate is 80 MHz. Therefore there are just 4 points (0.05us*80 MHz=4) difference between the narrowest pulse that should be accepted and the the pulses that should be rejected. Another thing is pulses might come with a dynamic range of amplitude. I mean a narrower pulse with a larger amplitude can have the same peak value at the matched filter output with an another pulse which has a lower amplitude but a has longer duration.And the noise power is adjusted according to the weakest pulse(i.e it is 10 dB according to the weakest pulse).Finally, my pulses are of rectangular type, with a rise time 0.07 microseconds and a fall time 0.12 microseconds. Durations are defined between 0.5*amplitude and rise and fall time are defined between 0.1*amplitude and 0.9*amplitude. I have tried many things but, each time i was unable to have large detection probability. I would be grateful if anybody can help me about this problem. I hope 4 points is not very few to accomplish this task. Thank you very much, okutan.
PULSE DURATION ESTIMATION FROM THE OUTPUT OF MATCHED FILTER
Started by ●June 10, 2007
Reply by ●June 10, 20072007-06-10
okutan wrote:> Hi to everybody, > > As you can understand from the subject, i am trying to estimate durations > of the pulses from the output of the matched filter. Let me explain you > the problem. I have pulses that are seperated in time enough under 10 dB > SNR white gaussian noise. The nominal pulse durations are 0.45 > microseconds. However they may come 0.15 microseconds less than 0.45 > microseconds. These narrower pulses should be accepted too. However, > pulses which are 0.20(or more than this) microseconds shorter than the > nominal pulse duration should be rejected. My sampling rate is 80 MHz. > Therefore there are just 4 points (0.05us*80 MHz=4) difference between the > narrowest pulse that should be accepted and the the pulses that should be > rejected. Another thing is pulses might come with a dynamic range of > amplitude. I mean a narrower pulse with a larger amplitude can have the > same peak value at the matched filter output with an another pulse which > has a lower amplitude but a has longer duration.And the noise power is > adjusted according to the weakest pulse(i.e it is 10 dB according to the > weakest pulse).Finally, my pulses are of rectangular type, with a rise > time 0.07 microseconds and a fall time 0.12 microseconds. Durations are > defined between 0.5*amplitude and rise and fall time are defined between > 0.1*amplitude and 0.9*amplitude. I have tried many things but, each time i > was unable to have large detection probability. I would be grateful if > anybody can help me about this problem. I hope 4 points is not very few to > accomplish this task.Since the question is so fuzzy, I suggest you using the fuzzy logic approach to distinguish the pulses. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●June 11, 20072007-06-11
I hope there are people who can help me. Is this atoo complicated problem?? I would appreciate the replies which say that you don't have any idea for the solution of this problem. Or I will think that nobody cares about this problem?? Thanks a lot Okutan.> > >okutan wrote: > >> Hi to everybody, >> >> As you can understand from the subject, i am trying to estimatedurations>> of the pulses from the output of the matched filter. Let me explainyou>> the problem. I have pulses that are seperated in time enough under 10dB>> SNR white gaussian noise. The nominal pulse durations are 0.45 >> microseconds. However they may come 0.15 microseconds less than 0.45 >> microseconds. These narrower pulses should be accepted too. However, >> pulses which are 0.20(or more than this) microseconds shorter than the >> nominal pulse duration should be rejected. My sampling rate is 80 MHz. >> Therefore there are just 4 points (0.05us*80 MHz=4) difference betweenthe>> narrowest pulse that should be accepted and the the pulses that shouldbe>> rejected. Another thing is pulses might come with a dynamic range of >> amplitude. I mean a narrower pulse with a larger amplitude can havethe>> same peak value at the matched filter output with an another pulsewhich>> has a lower amplitude but a has longer duration.And the noise power is >> adjusted according to the weakest pulse(i.e it is 10 dB according tothe>> weakest pulse).Finally, my pulses are of rectangular type, with a rise >> time 0.07 microseconds and a fall time 0.12 microseconds. Durationsare>> defined between 0.5*amplitude and rise and fall time are definedbetween>> 0.1*amplitude and 0.9*amplitude. I have tried many things but, eachtime i>> was unable to have large detection probability. I would be grateful if >> anybody can help me about this problem. I hope 4 points is not very fewto>> accomplish this task. > >Since the question is so fuzzy, I suggest you using the fuzzy logic >approach to distinguish the pulses. > >Vladimir Vassilevsky > >DSP and Mixed Signal Design Consultant > >http://www.abvolt.com > > > > >
On Jun 11, 8:28 am, "okutan" <maoku...@aselsan.com.tr> wrote:> I hope there are people who can help me. Is this atoo complicated problem?? > I would appreciate the replies which say that you don't have any idea for > the solution of this problem. Or I will think that nobody cares about this > problem?? > > Thanks a lot > > Okutan. > > > > > > > > >okutan wrote: > > >> Hi to everybody, > > >> As you can understand from the subject, i am trying to estimate > durations > >> of the pulses from the output of the matched filter. Let me explain > you > >> the problem. I have pulses that are seperated in time enough under 10 > dB > >> SNR white gaussian noise. The nominal pulse durations are 0.45 > >> microseconds. However they may come 0.15 microseconds less than 0.45 > >> microseconds. These narrower pulses should be accepted too. However, > >> pulses which are 0.20(or more than this) microseconds shorter than the > >> nominal pulse duration should be rejected. My sampling rate is 80 MHz. > >> Therefore there are just 4 points (0.05us*80 MHz=4) difference between > the > >> narrowest pulse that should be accepted and the the pulses that should > be > >> rejected. Another thing is pulses might come with a dynamic range of > >> amplitude. I mean a narrower pulse with a larger amplitude can have > the > >> same peak value at the matched filter output with an another pulse > which > >> has a lower amplitude but a has longer duration.And the noise power is > >> adjusted according to the weakest pulse(i.e it is 10 dB according to > the > >> weakest pulse).Finally, my pulses are of rectangular type, with a rise > >> time 0.07 microseconds and a fall time 0.12 microseconds. Durations > are > >> defined between 0.5*amplitude and rise and fall time are defined > between > >> 0.1*amplitude and 0.9*amplitude. I have tried many things but, each > time i > >> was unable to have large detection probability. I would be grateful if > >> anybody can help me about this problem. I hope 4 points is not very few > to > >> accomplish this task. > > >Since the question is so fuzzy, I suggest you using the fuzzy logic > >approach to distinguish the pulses. > > >Vladimir Vassilevsky > > >DSP and Mixed Signal Design Consultant > > >http://www.abvolt.com- Hide quoted text - > > - Show quoted text -is this for an ATC transponder or DME or other radar? Mark
okutan wrote:> I hope there are people who can help me.Certainly. But if you want your problem solved for you, this is going to be the business.> Is this atoo complicated problem??No. I bet the problem is trivial.> I would appreciate the replies which say that you don't have any idea for > the solution of this problem.I have no idea of what the problem is. You are talking some triffles about filters, frequencies and pulses instead of the clear statement of what is the signal, what is the noise, what should be done as the result, and what hardware is available.> Or I will think that nobody cares about this > problem??The problem is yours. Why should anyone care?> Thanks a lotAnd how much exactly is "a lot"? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On 11 Jun, 14:28, "okutan" <maoku...@aselsan.com.tr> wrote:> I hope there are people who can help me. Is this atoo complicated problem?? > I would appreciate the replies which say that you don't have any idea for > the solution of this problem. Or I will think that nobody cares about this > problem??First, no one but you care about your problem. What you need to do, then is to make your problem intersting enough for others to start thinking about it. There are two ways of doing that: 1) Do your homewrok first 2) Describe your problem in full After reading your post twice I can'n figure out if the tolerance is 4 samples or the pulse is 4 samples wide. If the pulse is 4 samples, your problem is hard. If the pulse is wider and the tolerance is 4 samples, there are standard text you might want to consult. I would suggest volume 1 of van Trees. Rune
