Hello, I have a signal sampled at 16kHz, and I would like to detect when any of the frequency components within 0.5Hz-10Hz is above predefined limit (say -10db). Because of high sample rate I expect that the resampling/decimating input signal will be necessary. Doing FFT just for yes/no answer seems like an overkill. I was considering bandpass filter with magnitude comparator. Are there any other solutions? Could I get away (any cheaper in terms of MIPS, RAM) with couple of goertzels? Just thought of asking before starting to code. Regards, Mitja
passband frequency detection
Started by ●June 12, 2007
Reply by ●June 12, 20072007-06-12
On 12 Jun, 14:15, Korenje <kore...@yahoo.co.uk> wrote:> Hello, > > I have a signal sampled at 16kHz, and I would like to detect when any > of the frequency components within 0.5Hz-10Hz is above predefined > limit (say -10db). > > Because of high sample rate I expect that the resampling/decimating > input signal will be necessary. > > Doing FFT just for yes/no answer seems like an overkill. > > I was considering bandpass filter with magnitude comparator.That seems like the obvious choise.> Are there any other solutions?Probably.> Could I get away (any cheaper in terms of MIPS, RAM) with couple of > goertzels? > > Just thought of asking before starting to code.Use the simple solutions first. Rune
Korenje wrote:> Hello, > > I have a signal sampled at 16kHz, and I would like to detect when any > of the frequency components within 0.5Hz-10Hz is above predefined > limit (say -10db). > > Because of high sample rate I expect that the resampling/decimating > input signal will be necessary. > > Doing FFT just for yes/no answer seems like an overkill. > > I was considering bandpass filter with magnitude comparator. > Are there any other solutions?Do it vice versa. Make a bandstop filter with a variable stopband and measure the RMS power outside of the stopband. This will probably cost you about one MIPS and 16 bytes of RAM. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
