ARMA modeling
Started by Tom ●June 13, 2007
I am looking for an algorithm to model a system using an ARMA filter. The
input and the desired output are available. Is there an iterative algorithm
that can give a global optimum solution ? Any good reference ?
Regards
Tom
On Jun 13, 1:53 pm, "Tom" <tomda...@yahoo.com> wrote:
> I am looking for an algorithm to model a system using an ARMA filter. The > input and the desired output are available. Is there an iterative algorithm > that can give a global optimum solution ? Any good reference ? > > Regards > > Tom
Simon Haykin, "Adaptive Filter Theory"
And oh, it might be useful to define what you mean by a "global optimum solution" (a.k.a, your optimization criteria).
On Jun 13, 1:21 pm, BERT <callm...@gmail.com> wrote:
> On Jun 13, 1:53 pm, "Tom" <tomda...@yahoo.com> wrote: > > > I am looking for an algorithm to model a system using an ARMA filter. The > > input and the desired output are available. Is there an iterative algorithm > > that can give a global optimum solution ? Any good reference ? > > > Regards > > > Tom > > And oh, it might be useful to define what you mean by a "global > optimum solution" (a.k.a, your optimization criteria).
And if the original poster defines what he means by "iterative". Is it iterative in the samples received, or in terms of solving what this "global optimum solution" is?
On Wed, 13 Jun 2007 18:56:26 -0000, julius <juliusk@gmail.com> wrote:
>On Jun 13, 1:21 pm, BERT <callm...@gmail.com> wrote: >> On Jun 13, 1:53 pm, "Tom" <tomda...@yahoo.com> wrote: >> >> > I am looking for an algorithm to model a system using an ARMA filter. The >> > input and the desired output are available. Is there an iterative algorithm >> > that can give a global optimum solution ? Any good reference ? >> >> > Regards >> >> > Tom >> >> And oh, it might be useful to define what you mean by a "global >> optimum solution" (a.k.a, your optimization criteria). > >And if the original poster defines what he means by "iterative". >Is it iterative in the samples received, or in terms of solving >what this "global optimum solution" is?
Yeah, Parks-McLellan is iterative, but it only takes care of the "MA" part of ARMA. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
Any optimization criteria is OK as long as  the solution is optimal
(unique). In addition samples are available, iterative or non-iterative both
are ok.
Thanks
Tom
"BERT" <callmevc@gmail.com> wrote in message
news:1181758907.555174.71980@i38g2000prf.googlegroups.com...
> On Jun 13, 1:53 pm, "Tom" <tomda...@yahoo.com> wrote: >> I am looking for an algorithm to model a system using an ARMA filter. The >> input and the desired output are available. Is there an iterative >> algorithm >> that can give a global optimum solution ? Any good reference ? >> >> Regards >> >> Tom > > > And oh, it might be useful to define what you mean by a "global > optimum solution" (a.k.a, your optimization criteria). >
On Jun 13, 2:19 pm, BERT <callm...@gmail.com> wrote:
> On Jun 13, 1:53 pm, "Tom" <tomda...@yahoo.com> wrote: > > > I am looking for an algorithm to model a system using an ARMA filter. The > > input and the desired output are available. Is there an iterative algorithm > > that can give a global optimum solution ? Any good reference ? > > > Regards > > > Tom > > Simon Haykin, "Adaptive Filter Theory"
I wouldn't recommend that book for ARMA modeling; there isn't much any information on that technique in the text. Haykin (rightfully) points out that ARMA modeling is in general a nonlinear problem, which is much more difficult to produce than a model with a simpler AR structure. On the other hand, it is, IMO, a great adaptive filtering text. Jason
I don't think that book will help him much. A better book is Ljung and Sodestrom Theory and Practice of Recursive Estimation, MIT Press 1983.
You could be more clear about what you want. A quick solution or in depth knowledge. I use a minimizing or optimizing algorithm. These exist in Scilab as lsqrsolve and optim. In Mathcad I use Minerr. In C I use lmfit.c which is c code converted from ancient fortran but it works. There are other versions out there that are buggy. If iterative means on-the-fly there is the recursive least squares method but I would be careful with this. In my testing, a fast sample rate yields poles close to the unit circle. The poles move around a bit while updating and sometimes the poles would cross the unit circle. Not good. What ever method you chose you must make a decision as to how many coefficients you need. One can always get a smaller norm or mean squared error by adding more coefficients but often the poles in the z domain end up on the negative real axis which is an indicator that you probably have too many coefficients. I don't use the recursive least squares but I do find it interesting how the poles move around and by how much. I read about the Levenberg-Marquardt algorithm in Numerical Recipes in C but didn't like the code or the restrictions. After that I found tracing through lmfit.c code helpful. I didn't need anything beyond this. Peter Nachtwey
If you are looking for Levenburg-Marquardt, I would suggest levmar.
http://www.ics.forth.gr/~lourakis/levmar/
You will need the BLAS 1 and LAPACK libraries.  I think the code from ATLAS is
the best choice.
In article <1182034526.765823.116870@x35g2000prf.googlegroups.com>,
pnachtwey@gmail.com wrote:
>On Jun 13, 10:53 am, "Tom" <tomda...@yahoo.com> wrote: >> I am looking for an algorithm to model a system using an ARMA filter. The >> input and the desired output are available. Is there an iterative algorithm >> that can give a global optimum solution ? Any good reference ? >> >> Regards >> >> Tom > >You could be more clear about what you want. A quick solution or in >depth knowledge. I use a minimizing or optimizing algorithm. These >exist in Scilab as lsqrsolve and optim. In Mathcad I use Minerr. In >C I use lmfit.c which is c code converted from ancient fortran but it >works. There are other versions out there that are buggy. > >If iterative means on-the-fly there is the recursive least squares >method but I would be careful with this. In my testing, a fast sample >rate yields poles close to the unit circle. The poles move around a >bit while updating and sometimes the poles would cross the unit >circle. Not good. > >What ever method you chose you must make a decision as to how many >coefficients you need. One can always get a smaller norm or mean >squared error by adding more coefficients but often the poles in the z >domain end up on the negative real axis which is an indicator that you >probably have too many coefficients. I don't use the recursive least >squares but I do find it interesting how the poles move around and by >how much. > >I read about the Levenberg-Marquardt algorithm in Numerical Recipes in >C but didn't like the code or the restrictions. After that I found >tracing through lmfit.c code helpful. I didn't need anything beyond >this. > >Peter Nachtwey >
