Dear All, Thank u very much for the help. Hi Vladimir, Can u please explain me in little detail how i can proceed further meanwhile i get the book u suggested. I need this higher order bessel filter implementation for the design of cross over application. I have designed for 24th order Butterworth and Linkwitz Riley filters but i am stuck up at 24th order Bessel filter implementation. Your guidance is very much appreciated. Gangadhar> > >Tim Wescott wrote: > > >> Now that we have powerful enough computers that exhaustive searches are>> only exhausting for the electrons involved, I've become a big fan of >> dropping a close approximation into a nonlinear optimizer, such as the>> one in Scilab, and letting it do the heavy lifting. > >I am guilty of that too. Quite often a brute force is the shortest way >to a solution, and it also helps better understanding of the problem. > >Not too long ago, I managed to find the closed form solution to the >system of nonlinear equations which I used to solve numerically. That >reduced the computing time from a second to several milliseconds in the >practical application. What is more important, the numerical algorithms >can go wild on the occasions, and the great care should be taken aboutthat.> > > This has served me >> well for problems in robust control and curve fitting, and I suspect >> it'd do fairly well for designing filters to specification. > >The high order IIR filter design by optimization is known to be >complicated. You have to define a filter in the way the stability is >guaranteed and the dependencies are continuous. > > The two big >> questions you have to answer before you start are "can I gin up an >> adequate cost function" and "will my algorithm avoid the localminima?".>> If the answers to those questions are both "yes", then you can do a >> pretty good job. > >Those conditions are the strong restrictions of what you can do already;>besides, there are the ill-behaviors, the numerical problems and the >discontinuities. > >> Speaking about approximations that don't work, do you know of a good >> reference that gives a clean expression for a working notch filter in >> the sampled-time domain? >> The various approximations don't work well, because they move the zeros>> around and mess up the null. I know how to do this by direct design, >> but the resulting expressions for the numerator coefficients are about>> as messy as can be -- it's good enough for me, but I'd like something >> that I can include in a publication for beginner or intermediate >> practitioners, which means that the derivation of the numerator >> coefficients should be smaller than the derivation of the propagationof>> electromagnetic radiation from Maxwell's equations. > >A basic notch is FIR with 3 taps. This looks like a simple trigonometry >problem: > >fi = 2 PI Fc/Fs >A1 cos(fi) + A2 cos(2fi) = -A0 >A1 sin(fi) = A2 sin(2fi) = 0 > >If I did not make a mistake somewhere: > >A2 = A0 >A1 = - 2 A0 cos(fi) > > >Vladimir Vassilevsky > >DSP and Mixed Signal Design Consultant > >http://www.abvolt.com > > > >
Higher order Bessel filter
Started by ●June 22, 2007
Reply by ●June 25, 20072007-06-25
