On Sun, 24 Oct 2004 16:12:18 -0700, Bob Cain <arcane@arcanemethods.com> wrote:> > >The Ghost wrote: > >> Bob Cain <arcane@arcanemethods.com> wrote in message news:<clf0jt01vlm@enews2.newsguy.com>... >> >> >>>As I said, just a nit. The real content was illuminating >>>for me. One of the problems with being self taught is that >>>the lack of a disciplined course can result in a hit or miss >>>base of knowledge. >> >> >> Based on your track record, it is appears to be mostly misses and few >> if any sutstantive hits. > >Print this out and take it to your next therapy session. > > http://www.apa.org/journals/psp/psp7761121.html > >I'm sure your mental health professional will appreciate the >insight it gives relative to your pathology. > >It'll be alright, Gary. New drugs are emerging for about >any mental ailment so relief shouldn't be that far away for you. > > >BobGood Hell! I wonder what caused "The Ghost" to make that wisecrack. [-Rick-]
What is the intuitive thought behind the cross-correlation function?
Started by ●October 20, 2004
Reply by ●October 25, 20042004-10-25
Rick Lyons wrote:> Good Hell! I wonder what caused "The Ghost" to make > that wisecrack.He's obsessed with me and now knows most of the places where I hang out so that he can stalk me as he's been doing for years on alt.sci.physics.acoustics but on a broader front. It's rather sad to be so filled with hatred. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
On 2004-10-25 03:53:38 +0200, Skint <wayneREMOVECAPSmarsh@dsl.pipexREMOVE.cXXXXom> said:> For example, with a signal bounded between -1 and 1, and values of > around 0.3 in the target signal, won't the resulting cross-correlation > signal always be highest in the areas where the original signal > averages around its peak? i.e. 0.3*1 > 0.3*0.3, by far. Surely in that > case the correlation signal is going to show higher correlation where > there is none?I'm sorry but I don't really understand your question. Can you be a bit more specific as to how your two data sets look like that you're trying to cross correlate? -- Stephan M. Bernsee http://www.dspdimension.com
Hi Bob, I must apologize for not meaning literally what I said. When I wrote "correlation tells you the sum of the squares of the difference between 2 signals", I mean: Given 2 signals, both with energy E (E - their inner product) = half the energy of (their difference) Regards. KD
On Mon, 25 Oct 2004 20:42:32 +0200, Stephan M. Bernsee <spam@dspdimension.com> wrote:>On 2004-10-25 03:53:38 +0200, Skint ><wayneREMOVECAPSmarsh@dsl.pipexREMOVE.cXXXXom> said: > >> For example, with a signal bounded between -1 and 1, and values of >> around 0.3 in the target signal, won't the resulting cross-correlation >> signal always be highest in the areas where the original signal >> averages around its peak? i.e. 0.3*1 > 0.3*0.3, by far. Surely in that >> case the correlation signal is going to show higher correlation where >> there is none? > >I'm sorry but I don't really understand your question. Can you be a bit >more specific as to how your two data sets look like that you're trying >to cross correlate?It's okay, I've worked it out in my head now. I was looking form the wrong philosophy as it were. Another, unrelated thought on the subject - could a correlation signal be generated by the inverse of the standard deviation of the shifted signals with respect to each other? This seems more instantly intuitive.
Skint wrote:> On Mon, 25 Oct 2004 20:42:32 +0200, Stephan M. Bernsee > <spam@dspdimension.com> wrote: > > >>On 2004-10-25 03:53:38 +0200, Skint >><wayneREMOVECAPSmarsh@dsl.pipexREMOVE.cXXXXom> said: >> >> >>>For example, with a signal bounded between -1 and 1, and values of >>>around 0.3 in the target signal, won't the resulting cross-correlation >>>signal always be highest in the areas where the original signal >>>averages around its peak? i.e. 0.3*1 > 0.3*0.3, by far. Surely in that >>>case the correlation signal is going to show higher correlation where >>>there is none? >> >>I'm sorry but I don't really understand your question. Can you be a bit >>more specific as to how your two data sets look like that you're trying >>to cross correlate? > > > It's okay, I've worked it out in my head now. I was looking form the > wrong philosophy as it were. > > Another, unrelated thought on the subject - could a correlation signal > be generated by the inverse of the standard deviation of the shifted > signals with respect to each other? This seems more instantly > intuitive.It ain't intuitive to me. I have no idea what you mean. I am confused on several points: I thought that a correlation is a number, not a signal. Standard deviation is a statistical measure related to the width of a probability density. What does the standard deviation of two signals mean? How is it calculated? Your inverse, is it multiplicative? Additive? Standard deviation is always positive. Correlation can be positive or negative. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Mon, 25 Oct 2004 17:16:24 -0400, Jerry Avins <jya@ieee.org> wrote:>Skint wrote: >> On Mon, 25 Oct 2004 20:42:32 +0200, Stephan M. Bernsee >> <spam@dspdimension.com> wrote: >> >> >>>On 2004-10-25 03:53:38 +0200, Skint >>><wayneREMOVECAPSmarsh@dsl.pipexREMOVE.cXXXXom> said: >>> >>> >>>>For example, with a signal bounded between -1 and 1, and values of >>>>around 0.3 in the target signal, won't the resulting cross-correlation >>>>signal always be highest in the areas where the original signal >>>>averages around its peak? i.e. 0.3*1 > 0.3*0.3, by far. Surely in that >>>>case the correlation signal is going to show higher correlation where >>>>there is none? >>> >>>I'm sorry but I don't really understand your question. Can you be a bit >>>more specific as to how your two data sets look like that you're trying >>>to cross correlate? >> >> >> It's okay, I've worked it out in my head now. I was looking form the >> wrong philosophy as it were. >> >> Another, unrelated thought on the subject - could a correlation signal >> be generated by the inverse of the standard deviation of the shifted >> signals with respect to each other? This seems more instantly >> intuitive. > >It ain't intuitive to me. I have no idea what you mean. I am confused on >several points: > >I thought that a correlation is a number, not a signal. > >Standard deviation is a statistical measure related to the width of a >probability density. What does the standard deviation of two signals >mean? How is it calculated?Okay, yes. I don't have any formal mathematical background, as you can tell. I know that what I'm suggesting isn't exactly standard deviation, but it seemed a fair enough description at the time. What I mean was that instead of multiplying and summing/integrating a window against a signal to produce the output, you could instead take the difference of each sample in comparison, and take the average of that. The inverse of this result is then used as the output signal (as when the windows are perfectly aligned the result would be smaller, when we actually want it to be bigger). Does that make sense at all to anybody? Anywhere? Somebody?
Reply by ●October 26, 20042004-10-26
Kedi wrote:> Hi Bob, > > I must apologize for not meaning literally what I said. When I wrote > "correlation tells you the sum of the squares of the difference > between 2 signals", I mean: > > Given 2 signals, both with energy E > > (E - their inner product) = half the energy of (their difference)Ah, so. Thanks. Your math did say that but the words were at odds. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
On 2004-10-25 23:53:14 +0200, Skint <wayneREMOVECAPSmarsh@dsl.pipexREMOVE.cXXXXom> said:> Okay, yes. I don't have any formal mathematical background, as you can > tell. I know that what I'm suggesting isn't exactly standard > deviation, but it seemed a fair enough description at the time. > What I mean was that instead of multiplying and summing/integrating a > window against a signal to produce the output, you could instead take > the difference of each sample in comparison, and take the average of > that. The inverse of this result is then used as the output signal > (as when the windows are perfectly aligned the result would be > smaller, when we actually want it to be bigger). > > Does that make sense at all to anybody? Anywhere? Somebody?Yes, that is called the average (squared) magnitude difference function (AMDF). It is sometimes used instead of the correlation function for similar purposes, usually in speech recognition instead of the auto-correlation to extract the fundamental frequency. -- Stephan M. Bernsee http://www.dspdimension.com
