Gardner TED for BPSk is e(r)=y(r-1/2)[y(r)-y(r-1)].that mean the e(r) is related to y's amplitude and so related to signal's power. But TED is attend to give a phasic error,which is in[0,2*pi] and unrelated to signal's power. How can I get the e(r) in zone [0,2*pi]? What's the normalization method?
A Question about Gardner TED
Started by ●June 25, 2007
Reply by ●June 25, 20072007-06-25
On Jun 25, 9:17 am, peugeot888 <peugeot...@tom.com> wrote:> Gardner TED for BPSk is e(r)=y(r-1/2)[y(r)-y(r-1)].that mean the > e(r) is related to y's amplitude and so related to > signal's power. But TED is attend to give a phasic error,which is > in[0,2*pi] and unrelated to signal's power. How > can I get the e(r) in zone [0,2*pi]? What's the normalization method?It's intended to give *delay* estimate, not phase estimate.
On Jun 25, 10:17 am, peugeot888 <peugeot...@tom.com> wrote:> Gardner TED for BPSk is e(r)=y(r-1/2)[y(r)-y(r-1)].that mean the > e(r) is related to y's amplitude and so related to > signal's power. But TED is attend to give a phasic error,which is > in[0,2*pi] and unrelated to signal's power. How > can I get the e(r) in zone [0,2*pi]? What's the normalization method?Think of the TED
On Jun 25, 10:17 am, peugeot888 <peugeot...@tom.com> wrote:> Gardner TED for BPSk is e(r)=y(r-1/2)[y(r)-y(r-1)].that mean the > e(r) is related to y's amplitude and so related to > signal's power. But TED is attend to give a phasic error,which is > in[0,2*pi] and unrelated to signal's power. How > can I get the e(r) in zone [0,2*pi]? What's the normalization method?Think of the TED as a "timing delay to number" converter, and the NCD (numerically-controlled delay) that follows the loop filter as a "number to timing delay" converter ...
Reply by ●June 26, 20072007-06-26
But what is unit for e(r)? How can I express the delay? "BERT" <callmevc@gmail.com> ??????:1182783396.990637.224230@q75g2000hsh.googlegroups.com...> On Jun 25, 10:17 am, peugeot888 <peugeot...@tom.com> wrote: >> Gardner TED for BPSk is e(r)=y(r-1/2)[y(r)-y(r-1)].that mean the >> e(r) is related to y's amplitude and so related to >> signal's power. But TED is attend to give a phasic error,which is >> in[0,2*pi] and unrelated to signal's power. How >> can I get the e(r) in zone [0,2*pi]? What's the normalization method? > > Think of the TED as a "timing delay to number" converter, and the NCD > (numerically-controlled delay) that follows the loop filter as a > "number to timing delay" converter ... >
You need to do some homework and derive it, there's a dependence on the pulse shape that you use in your modulation. It is commonly called the "gain" of the TED, and it can be derived from the S-curve, which is the expected output of the TED as a function of the true delay. Do you have references on the terms I used above? On Jun 26, 8:50 am, "peugeot888" <peugeot...@tom.com> wrote:> But what is unit for e(r)? How can I express the delay? > >
julius wrote:> You need to do some homework and derive it, there's a > dependence on the pulse shape that you use in your > modulation. It is commonly called the "gain" of the TED, > and it can be derived from the S-curve, which is the expected > output of the TED as a function of the true delay. > > Do you have references on the terms I used above?For pulse shape think excess bandwidth. Gardner works great with large excess bandwidth, and falls apart for very limited excess bandwidth. In most practical cases, the result of the Gardner calculation should be thought of as little more than a "go left" or "go right" indication. Trying to use the actual magnitude of the result, rather than just its sign, works fine in a sterile noiseless model. In the real noisy world the impairments mean trying to scale the adjustment with the magnitude of the result can be less than spectacularly successful. Steve
Reply by ●June 27, 20072007-06-27
> In most practical cases, the result of the Gardner calculation should be > thought of as little more than a "go left" or "go right" indication. > Trying to use the actual magnitude of the result, rather than just its > sign, works fine in a sterile noiseless model. In the real noisy world > the impairments mean trying to scale the adjustment with the magnitude > of the result can be less than spectacularly successful. >And, that is also why the Gardener TED works for a wide range of modulation schemes including QAM. Anyways, you might want to consult "Digital Communication Receivers" by H. Meyr et. al, for a more in- depth treatment of this subject. Vijay.
What references give the definition of S-curve?I have look up <Synchronization Techniques for Digital Receivers> . <Digital Communication Receivers Synchronization, Channel Estimation, and Signal Processing> and <digital communications>.But I can't find the definition of S-curve. Could tell me the reference?thanks "julius" <juliusk@gmail.com> ??????:1182877605.962511.200660@q69g2000hsb.googlegroups.com...> You need to do some homework and derive it, there's a > dependence on the pulse shape that you use in your > modulation. It is commonly called the "gain" of the TED, > and it can be derived from the S-curve, which is the expected > output of the TED as a function of the true delay. > > Do you have references on the terms I used above? > > > On Jun 26, 8:50 am, "peugeot888" <peugeot...@tom.com> wrote: >> But what is unit for e(r)? How can I express the delay? >> >> > >
On Jun 27, 7:29 am, "peugeot888" <peugeot...@tom.com> wrote:> What references give the definition of S-curve?I have look up > <Synchronization Techniques for Digital Receivers> . <Digital Communication > Receivers Synchronization, Channel Estimation, and Signal Processing> > and <digital communications>.But I can't find the definition of S-curve. > Could tell me the reference?thanks >Look again, it's definitely in d'Andrea and Mengali's "Synchronization Techniques for Digital Receivers." You didn't give the authors names, but I assume that you were referring to the same book. Julius
