On Jun 28, 7:06 am, "David Lee" <davidlee_malv...@dontusethisbit.hotmail.com> wrote:> Ron N wrote... > > David Lee: > >> Sampling rate is usually 44.1kHz and the frequency of the bat echolocation > >> vocalizations can be as high as 110kHz. > > >> That's the original frequency of course - I'm not trying to beat Nyquist! I'm > >> dealing with the frequency divided signal (sampled at 44.1kHz) which can > >> contain frequencies as high as 11kHz. > > What's the maximum rate-of-change of the frequency > > which you're trying to track? > > A Natterer's bat, for example, uses an extremely linear broadband frequency sweep and can sweep from > above 110kHz to below 20kHz (ie 11 to 2 kHz after division) in times around 2.5 to 4ms. Insect > "vocalizations" can exhibit much higher sweep rates - and maximum rate of change of frequency is one > of the criteria used in the automatic recognition of bat calls to eliminate insect sounds. > > The purpose of the time/frequency representation of calls is identification of species and so the > requirement is to be able to identify characteristic features of the calls and not to extract > accurate detailed parameters - for which purpose we normally use FFT-based tools to analyse the > original call (usually captured as a 10x time-expanded signal so as to be audible and easily handled > as an audio sound file). > > Another major issue is that the recordings can be up to several hours in length, so a rapid analysis > technique is required to extract frequency data and filter out the bat-call candidates from the > background noise. > > There is a commercial bat detector system - the Anabat - that carries out the analysis in real-time > and can be left unattended in the field for months at a time (provided that it isn't blown up by the > bomb disposal squad as happened recently here in the UK when the ecologists concerned failed to > properly label their equipment!) What I am trying to do is to extract zero-crossing data from a > much cheaper, more accessible, detector into a form that can be used with the same freely available > software as is used for the commercial device. > > Using linear interpolation to determine zero-crossing times, I am already obtaining acceptable > results. I was just looking for a staightforward and rapid way of refining the interpolation and > thought that a cubic spline may fit the bill. > > Thanks for your interest > > DavidTry Poincare sections on a reconstructed attractor in multi- dimensional state space... It's a multi-dimensional generalization of a one-dimensional level- crossing technique (zero-crossing in your case) Ah, heck, this is just comp.dsp, I almost forgot it :-)
Cubic Spline Interpolation and Zero Crossing Analysis
Started by ●June 27, 2007
Reply by ●June 28, 20072007-06-28
fizteh89 wrote...> Try Poincare sections on a reconstructed attractor in multi- > dimensional state space... > It's a multi-dimensional generalization of a one-dimensional level- > crossing technique (zero-crossing in your case) > > Ah, heck, this is just comp.dsp, I almost forgot it :-)I'm sure that there must be a point that you are trying to make but I haven't a clue what it might be.
On Jun 28, 7:03 am, fizteh89 <d...@soundmathtech.com> wrote:> On Jun 28, 7:06 am, "David Lee"...> <davidlee_malv...@dontusethisbit.hotmail.com> wrote: > > Ron N wrote... > > > David Lee: > > >> Sampling rate is usually 44.1kHz and the frequency of the bat echolocation > > >> vocalizations can be as high as 110kHz. > > > >> That's the original frequency of course - I'm not trying to beat Nyquist! I'm > > >> dealing with the frequency divided signal (sampled at 44.1kHz) which can > > >> contain frequencies as high as 11kHz. > > > What's the maximum rate-of-change of the frequency > > > which you're trying to track? > > > A Natterer's bat, for example, uses an extremely linear broadband frequency sweep and can sweep from > > above 110kHz to below 20kHz (ie 11 to 2 kHz after division) in times around 2.5 to 4ms.So you're trying to estimate frequency as it changes from under 2 cycles per millisecond to over 6 cycles per millisecond in the first 1 millisecond (about 44 samples)? Given that rate of change of frequency, I'll take back my phase vocoder recommendation, as that techniques usually requires a more stable frequency between the two fft windows. I might try using some sort of software PLL to track your sweep. But I'm not even sure that a 44.1 kHz sampling rate is high enough given those rates of frequency modulation.> Insect > > "vocalizations" can exhibit much higher sweep rates - and maximum rate of change of frequency is one > > of the criteria used in the automatic recognition of bat calls to eliminate insect sounds. > > > The purpose of the time/frequency representation of calls is identification of species and so the > > requirement is to be able to identify characteristic features of the calls and not to extract > > accurate detailed parameters - for which purpose we normally use FFT-based tools to analyse the > > original call (usually captured as a 10x time-expanded signal so as to be audible and easily handled > > as an audio sound file). > > > Another major issue is that the recordings can be up to several hours in length, so a rapid analysis > > technique is required to extract frequency data and filter out the bat-call candidates from the > > background noise. > > > There is a commercial bat detector system - the Anabat - that carries out the analysis in real-time > > and can be left unattended in the field for months at a time (provided that it isn't blown up by the > > bomb disposal squad as happened recently here in the UK when the ecologists concerned failed to > > properly label their equipment!) What I am trying to do is to extract zero-crossing data from a > > much cheaper, more accessible, detector into a form that can be used with the same freely available > > software as is used for the commercial device. > > > Using linear interpolation to determine zero-crossing times, I am already obtaining acceptable > > results. I was just looking for a staightforward and rapid way of refining the interpolation and > > thought that a cubic spline may fit the bill. > > > Thanks for your interest > > > David > > Try Poincare sections on a reconstructed attractor in multi- > dimensional state space... > It's a multi-dimensional generalization of a one-dimensional level- > crossing technique (zero-crossing in your case) > > Ah, heck, this is just comp.dsp, I almost forgot it :-)So how does the time/memory/Watts/MACs/LUTs/etc. per result of using Poincare sections compare to measuring interpolated zero crossings in terms of cost per result? -- rhn A.T nicholson d.0.t C-o-M
