Hello guys, I was going through Steves comments about narrow band detector in dsprelated.com ,i.e. using auto correlation and finding peaky_ness. The sources of these tone signal are 1) Echo of dial tone ( which is a amplitude modulated signal , 400 hz being modulated by 25 hz) 2) a dtmf tone ( may be as high as 0 dbm ) 3) may be echo of other tones 4) or a whistle may be from the talker ( I recorded a whistle at around 1225 Hz) My point is we can perhaps assume the highest frequency tone is around 1633 Hz, now can we devise simplistic auto correlation method so that we can find a positive to negetive transion ( or vice versa )of this autocorrelation values . Number of transitions will be highest for 1633 hz and lowest for 400 hz . Does this number (of transitions) can accurately tells the presence of narrow band energy ? Any thought about this?
narrow band detector for telephones
Started by ●June 27, 2007
Reply by ●June 30, 20072007-06-30
>Hello guys, >I was going through Steves comments about narrow band detector in >dsprelated.com ,i.e. using auto correlation and finding peaky_ness. The >sources of these tone signal are >1) Echo of dial tone ( which is a amplitude modulated signal , 400 hz >being modulated by 25 hz) >2) a dtmf tone ( may be as high as 0 dbm ) >3) may be echo of other tones >4) or a whistle may be from the talker ( I recorded a whistle at around >1225 Hz) > >My point is we can perhaps assume the highest frequency tone is around >1633 Hz, now can we devise simplistic auto correlation method so that we >can find a positive to negetive transion ( or vice versa )of this >autocorrelation values . Number of transitions will be highest for 1633hz>and lowest for 400 hz . Does this number (of transitions) can accurately >tells the presence of narrow band energy ? > >Any thought about this? >Tested! Seems to be working ! just that I get a positive to negetive transition for artificially generated white noise also !> > > > > >
> Tested! Seems to be working ! just that I get a positive to negetive > transition for artificially generated white noise also !Offcourse, unless I misunderstood something, your method just is based on the zero crossing counting of the autocorrelation function. It does not seem to check for bandwidth at all... To check for bandwith I would suggest generating an AR model from the data and looking at the distance of the poles from the unit circle. Or, alternatively, generate an SVD decomposition of the autocorrelation matrix and looking at the condition number of the singular values (just a thought).
