Hello, I implement MIMO system in DSP TI-C6711, and I must send I&Q channel (for an antenna 1 and 2) from the DSP output to a radio equipment. I thought to use the line level output speaker, but I don't know how create different channels to avoid a serial output. Could you help me ? thanks, Nicolas
To send data from DSP to radio equipment
Started by ●May 13, 2004
Reply by ●May 13, 20042004-05-13
Nino wrote:> Hello, > > I implement MIMO system in DSP TI-C6711, and I must send I&Q channel (for an > antenna 1 and 2) from the DSP output to a radio equipment. I thought to use > the line level output speaker, but I don't know how create different > channels to avoid a serial output. > > Could you help me ? > > thanks, > > NicolasI'm sorry, but I can't figure out what you're asking. For example, I&Q stand for in-phase and quadrature, the two parts of a complex signal. How is that related to antennas? DSPs can have different kinds and sources of outputs. You don't say what kind you want to use. What kind of input signal does the radio want? (All radios accept RF. Some have other inputs.) Speakers (or headphones) are different from line level. Which is it? How does creating channels require or avoid serial output? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
