Hi all, I am facing the following non-homework problem: The sequence Pk for k=0, 1, 2, ... has the Z-transform H(z). And define another sequence by: Qn=Sum( (k-s)*Pk, k from n to +infinity) for n=0, 1, 2, ... where s is a constant. What should be the Z-transform of Qn sequence? Thanks a lot!
How to find z-transform of this sequence?
Started by ●June 28, 2007
Reply by ●June 28, 20072007-06-28
On 28 Jun., 05:47, "Vista" <a...@gmai.com> wrote:> Hi all, > > I am facing the following non-homework problem: > > The sequence Pk for k=0, 1, 2, ... > > has the Z-transform H(z). > > And define another sequence by: > > Qn=Sum( (k-s)*Pk, k from n to +infinity) > > for n=0, 1, 2, ... > > where s is a constant. > > What should be the Z-transform of Qn sequence? > > Thanks a lot!You can use two properties of the z-transform to solve this questions: differentiation and linearity. Don't forget to subtract the terms Pk for 0<=k<n. Regards, Andor
How ? "Andor" <andor.bariska@gmail.com> wrote in message news:1183013860.620286.45440@q69g2000hsb.googlegroups.com...> On 28 Jun., 05:47, "Vista" <a...@gmai.com> wrote: >> Hi all, >> >> I am facing the following non-homework problem: >> >> The sequence Pk for k=0, 1, 2, ... >> >> has the Z-transform H(z). >> >> And define another sequence by: >> >> Qn=Sum( (k-s)*Pk, k from n to +infinity) >> >> for n=0, 1, 2, ... >> >> where s is a constant. >> >> What should be the Z-transform of Qn sequence? >> >> Thanks a lot! > > You can use two properties of the z-transform to solve this questions: > differentiation and linearity. Don't forget to subtract the terms Pk > for 0<=k<n. > > Regards, > Andor >
