Hello everybody, I am trying to filter a image and do some edge detection using the Marr Hildreth method. I have (hopefully!) two problems: 1) I read the image and stores it in a array. Then, I create a laplacian of a gaussian using the same size of the imagem. I transform both using FFTW r2c_2d, do the pointwise complex multiplication, and then transform back using c2r_2d. On the returned array I do the normalization, dividing the transformed array by width*height. But the returned array is never normalized: depending the sigma of the gaussian, the returned array can be very large or very small. So here is the first problem: where, and how can I normalize the returned array? I tried to use also 1/sqrt(width*height), but with no success. I think that maybe this is related to the normalization of the laplacian of the gaussian, because the original signal (the image) is on the intensity scale, 0 for white and 1 for black. I saw some posts here at DSPrelated but with no luck. 2) I don't know if it is related to the above problem, but the laplacian of a gaussian, that should return positive and negative values, is returning only positive or negative values for several sigmas, and return positive and negative ones with just one sigma, 0.4. I think that this is odd, because the sigma should control the smoothing and the scale of the transform... I have written the gaussian in the four corners of the image because the periodical characteristic of the fft of a gaussian. Here is some code: **** Initializations goes hre float sigma = 0.42; for(i=0; i < altura; i++) { for(j=0; j < largura; j++) { in_sinal[i*largura + j] = (double)sinal[i*largura + j]; in_gauss[i*largura + j] = -(1/sqrt(largura*altura))* ((1 - ( (i-altura)*(i-altura) + (j)*(j) )/(sigma*sigma)) *exp(-( (i-altura)*(i-altura) + (j*j) ) /(2*sigma*sigma)) + (1-( (i)*(i) + (j-largura)*(j-largura) )/(sigma*sigma)) *exp(-( i*i + (j-largura)*(j-largura) ) /(2*sigma*sigma)) + (1-( (i-altura)*(i-altura) + (j-largura)*(j-largura) )/(sigma*sigma)) *exp(-( (i-altura)*(i-altura) + (j-largura)*(j-largura) ) /(2*sigma*sigma)) + (1-( i*i + j*j )/(sigma*sigma))*exp(-( (i*i + j*j)) /(2*sigma*sigma))); } } p = fftw_plan_dft_r2c_2d(altura, largura,in_sinal, out_sinal,FFTW_ESTIMATE); fftw_execute(p); p_gauss = fftw_plan_dft_r2c_2d(altura, largura,in_gauss, out_gauss,FFTW_ESTIMATE); fftw_execute(p_gauss); for(l=0; l < altura/2 +1; l++) { for(m=0; m < largura; m++) { out_sinal[l*largura + m] = ((creal(out_sinal[l*largura + m])*creal(out_gauss[l*largura + m]) - cimag(out_sinal[l*largura + m])*cimag(out_gauss[l*largura+m])) + I*(creal(out_sinal[l*largura + m])*cimag(out_gauss[l*largura + m]) + cimag(out_sinal[l*largura + m])*creal(out_gauss[l*largura +m]))); } } p = fftw_plan_dft_c2r_2d(altura, largura, out_sinal, in_sinal,FFTW_ESTIMATE); fftw_execute(p); return in_sinal; *** end of it Thank you so much!
FFTW multiplication, marr hildreth filter, and normalization
Started by ●July 4, 2007
Reply by ●July 4, 20072007-07-04
