Hi people, I am trying to selectively mask a speech signal with white noise.what do i mean by selectively msaking? I mean i would like the noise to mask when a word is spoken and to stop masking when there is a period of silence. Any ideas or code on how to do this? Best regards G.N
Masking a speech signal
Started by ●July 10, 2007
Reply by ●July 10, 20072007-07-10
On Jul 10, 5:10 am, "pnalelia" <pnale...@yahoo.com> wrote:> Hi people, > I am trying to selectively mask a speech signal with white > noise.what do i mean by selectively msaking? I mean i would like the noise > to mask when a word is spoken and to stop masking when there is a period of > silence. Any ideas or code on how to do this? > Best regards > G.NIf your SNR is high enough, you could use a simple lowpass filter and squelch circuit. Design the filter so that it will track the envelope of the speech waveform, and compare its output to a threshold. If you're above the threshold, you can assume that speech is present, and you can insert the noise. The aspect of your filter that you want to be careful about is its delay, however. If the filter is too long, there may be a discernible time during which the filter output is ramping up to the threshold, resulting in unmasked speech. As I said, this is only good if you have a large enough SNR that you can reliably discriminate between noise and signal + noise. Jason
On Jul 10, 5:10 am, "pnalelia" <pnale...@yahoo.com> wrote:> Hi people, > I am trying to selectively mask a speech signal with white > noise.what do i mean by selectively msaking? I mean i would like the noise > to mask when a word is spoken and to stop masking when there is a period of > silence. Any ideas or code on how to do this? > Best regards > G.NWhy white noise? Dirk
Reply by ●July 11, 20072007-07-11
>On Jul 10, 5:10 am, "pnalelia" <pnale...@yahoo.com> wrote: >> Hi people, >> I am trying to selectively mask a speech signal with white >> noise.what do i mean by selectively msaking? I mean i would like thenoise>> to mask when a word is spoken and to stop masking when there is aperiod of>> silence. Any ideas or code on how to do this? >> Best regards >> G.N > >If your SNR is high enough, you could use a simple lowpass filter and >squelch circuit. Design the filter so that it will track the envelope >of the speech waveform, and compare its output to a threshold. If >you're above the threshold, you can assume that speech is present, and >you can insert the noise. The aspect of your filter that you want to >be careful about is its delay, however. If the filter is too long, >there may be a discernible time during which the filter output is >ramping up to the threshold, resulting in unmasked speech. > >As I said, this is only good if you have a large enough SNR that you >can reliably discriminate between noise and signal + noise. > >Jason >Thanks Jason, I will try to do it the way you proposed.Incase of any problems Can I get back at you? Regards
>On Jul 10, 5:10 am, "pnalelia" <pnale...@yahoo.com> wrote: >> Hi people, >> I am trying to selectively mask a speech signal with white >> noise.what do i mean by selectively msaking? I mean i would like thenoise>> to mask when a word is spoken and to stop masking when there is aperiod of>> silence. Any ideas or code on how to do this? >> Best regards >> G.N > >If your SNR is high enough, you could use a simple lowpass filter and >squelch circuit. Design the filter so that it will track the envelope >of the speech waveform, and compare its output to a threshold. If >you're above the threshold, you can assume that speech is present, and >you can insert the noise. The aspect of your filter that you want to >be careful about is its delay, however. If the filter is too long, >there may be a discernible time during which the filter output is >ramping up to the threshold, resulting in unmasked speech. > >As I said, this is only good if you have a large enough SNR that you >can reliably discriminate between noise and signal + noise. > >Jason >Jason, I realised I posted the question in the general DSP forum, I was meant to post it under the Matlab forum because I have to implement it in matlab..
Reply by ●September 3, 20072007-09-03
pnalelia wrote:> Hi people, > I am trying to selectively mask a speech signal with white > noise.what do i mean by selectively msaking? I mean i would like the noise > to mask when a word is spoken and to stop masking when there is a period of > silence. Any ideas or code on how to do this?The simple way uses a speech detector and turns on a noise source loud enough to blast the listener out of his seat whenever speech is detected. Since you equat speech to not silence, your speech detector should be very easy to design. I'm puzzled, though. If you blot out everything but silence, why not just turn the signal off altogether and run your noise generator with a random timer? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jerry Avins wrote: (snip)> The simple way uses a speech detector and turns on a noise source loud > enough to blast the listener out of his seat whenever speech is > detected. Since you equat speech to not silence, your speech detector > should be very easy to design. I'm puzzled, though. If you blot out > everything but silence, why not just turn the signal off altogether and > run your noise generator with a random timer?This reminds me of making "random word generator" computer programs. Generating letters with the right frequency doesn't tend to make readable words. I will guess that one can tell the difference between random noise and masked speech unless one is very good with the random numbers. -- glen
Reply by ●September 4, 20072007-09-04
glen herrmannsfeldt wrote:> Jerry Avins wrote: > > (snip) > >> The simple way uses a speech detector and turns on a noise source loud >> enough to blast the listener out of his seat whenever speech is >> detected. Since you equat speech to not silence, your speech detector >> should be very easy to design. I'm puzzled, though. If you blot out >> everything but silence, why not just turn the signal off altogether >> and run your noise generator with a random timer? > > This reminds me of making "random word generator" computer programs. > > Generating letters with the right frequency doesn't tend to make > readable words. > > I will guess that one can tell the difference between random noise and > masked speech unless one is very good with the random numbers.True, but does it matter? jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On Sep 3, 8:15 am, Jerry Avins <j...@ieee.org> wrote:> pnalelia wrote: > > Hi people, > > I am trying to selectively mask a speech signal with white > > noise.what do i mean by selectively msaking? I mean i would like the no=ise> > to mask when a word is spoken and to stop masking when there is a perio=d of> > silence. Any ideas or code on how to do this? > > The simple way uses a speech detector and turns on a noise source loud > enough to blast the listener out of his seat whenever speech is > detected. Since you equat speech to not silence, your speech detector > should be very easy to design. I'm puzzled, though. If you blot out > everything but silence, why not just turn the signal off altogether and > run your noise generator with a random timer? > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF==AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF May be he is on his first step to build a karaoke system. - hurry.
