does anyone knows literature concerning models for kalman filter based azimuth and elevation tracking(without using range).Is it necessary to go to cartesian system of coordinates for kalman filter model?
kalman filter based azimuth and elevation tracking models
Started by ●July 11, 2007
Reply by ●July 12, 20072007-07-12
On Jul 11, 12:50 pm, "Sylvia" <sylvia.za...@gmail.com> wrote:> does anyone knows literature concerning models for kalman filter based > azimuth and elevation tracking(without using range).Is it necessary to go > to cartesian system of coordinates for kalman filter model?I think there are several options, Cartesian is often chosen because of the ease of the target motion model, but it often leads to strong nonlinearities in the measurement model. For cases where the range is unobservable the modified polar/spherical is popular, since the unobservable component is limited to one state, and it becomes observable when an acceleration takes place. It still requires and Extended Kalman Filter or some other mechanism to handle the non- linearities. Blackman's book "Design and Analysis of Modern Tracking Systems" discusses this and provides quite a number of references. Cheers, David
Reply by ●July 15, 20072007-07-15
Sylvia wrote:> does anyone knows literature concerning models for kalman filter based > azimuth and elevation tracking(without using range).Is it necessary to go > to cartesian system of coordinates for kalman filter model?Are you tracking orbiting satellites for which you know the elements? If so, there are quite a few programs around that will drive antennas for you, or at least give you the azimuth/elevation figures. Many will also compute Doppler shift. See http://www.amsat-na.com/category.php?c=Software I think there are also some GPLed packages for Linux/UNIX. Most satellite tracking programs take Keplerian orbital elements, but a few take cartesian state vectors, and there are utilities that will convert between them for you. --Phil
