Hello, Currently I am trying to implement a transmitter-receiver unit on a DSP board. Transmitter and Receiver will be implemented on seperate boards. I have only one carrier with a fixed frequency and send my symbols for one period. I guess that since there is only one carrier, I don`t need any frequency synchronization. However I am not sure if I should apply symbol synchronization or would I be fine without it? any pointers would be appreciated. thanks alot Rifo
newbie question about synchronization
Started by ●July 19, 2007
Reply by ●July 19, 20072007-07-19
On Jul 19, 8:46 am, "rifo" <rtur...@yahoo.de> wrote:> Hello, > > Currently I am trying to implement a transmitter-receiver unit on a DSP > board. Transmitter and Receiver will be implemented on seperate boards. > > I have only one carrier with a fixed frequency and send my symbols for one > period. I guess that since there is only one carrier, I don`t need any > frequency synchronization. > > However I am not sure if I should apply symbol synchronization or would I > be fine without it? > > any pointers would be appreciated. > > thanks alot > RifoThis question is not really meaningful without a more complete specification. If there's any clock mismatch between the Tx and Rx, it will effectively induce frequency offset. So what's the clock mismatch? How do you plan to synchronize the operation of the Tx and Rx? Julius
Assuming you might be having independent crystals on Tx board and Rx board generating the RF carrier and the sampling clocks, you may need to do: (a) carrier frequency offset error estimation and compensation (b) sampling clock offset estimation and compensation (c) Symbol boundary estimation>> I guess that since there is only one carrier, I don`t need any frequency synchronization.Did not understand. HTH, Krishna http://dsplog.blogspot.com
Reply by ●July 20, 20072007-07-20
Hello thank you for your inputs, I try to give more info about the system>If there's any clock mismatch between the Tx and Rx, it will >effectively induce frequency offset. So what's the clock >mismatch? How do you plan to synchronize the operation >of the Tx and Rx?I am using two motorola 56303 development kits hence I will have independent crystals on board for Tx and Rx. I don't know about the clock mismatch, I will check the datasheets and report back about this but frankly I don't also have any plans for synchronization of Tx and Rx operations.>Assuming you might be having independent crystals on Tx board and Rx >board generating the >RF carrier and the sampling clocks, you may need to do: >(a) carrier frequency offset error estimation and compensation >(b) sampling clock offset estimation and compensation >(c) Symbol boundary estimationDo I need to implement all three of these. I would also appreciate if you point out any resources about the implementation of these algorithms.>>> I guess that since there is only one carrier, I don`t need anyfrequency synchronization.>Did not understand. >I was going through the book of Sklar, "Digital Communications" and in the synchronization chapter it said that; "Take an AM radio, if there is only a central carrier and many receivers, then in this system synchronization can be avoided" This led me to think that, since I only generate a single carrier with a fixed frequency I may at least skip carrier synchronization (since I would have coded the receiver DSP with the knowledge of this carrier frequency) But now I see that I have a misinterpretation of the above phrase. I would be happy to hear your further advices Thanks a lot Rifo
On Jul 20, 6:10 am, "rifo" <rtur...@yahoo.de> wrote:> I am using two motorola 56303 development kits hence I will have > independent crystals on board for Tx and Rx. I don't know about the > clock mismatch, I will check the datasheets and report back about this but > frankly I don't also have any plans for synchronization of Tx and Rx > operations.Please do.> >Assuming you might be having independent crystals on Tx board and Rx > >board generating the > >RF carrier and the sampling clocks, you may need to do: > >(a) carrier frequency offset error estimation and compensation > >(b) sampling clock offset estimation and compensation > >(c) Symbol boundary estimation > > Do I need to implement all three of these. I would also appreciate if > you > point out any resources about the implementation of these algorithms.The dry treatment is available in most textbooks, like Proakis or Sklar or Messerschmitt/Lee. But if you want to truly optimize the parameters, I am a big fan of d'Andrea and Mengali's text, and also the Meyr/Moeneclaey/Fechtel text. If you do a google search for "digital receiver synchronization" you can find several tutorial articles, but they do not go in much depth. If your goal is to just send from point A to point B and your SNR is very high, then there is much fewer things to optimize, so the tutorials may be enough. Regardless, for sure you need some sort of method for synchronizing.> I was going through the book of Sklar, "Digital Communications" and in > the synchronization chapter it said that; > > "Take an AM radio, if there is only a central carrier and many receivers, > then in this system synchronization can be avoided" > > This led me to think that, since I only generate a single carrier with > a fixed frequency I may at least skip carrier synchronization (since I > would have coded the receiver DSP with the knowledge of this carrier > frequency) But now I see that I have a misinterpretation of the above > phrase.No way :-). Are you actually implementing a digital communication system or an analog one? If you are doing just AM transmission, then Sklar is correct. I had always assumed that you were doing digital stuff.> I would be happy to hear your further advices > Thanks a lot > RifoIf your mixers are implemented in digital, you can simplify some parts from the above list. Julius
I hope I have a correct interpretation of clock mismatch concept :) so here it goes... Both development boards have the same codec (CS4125) which is driven by a 24.576 Mhz crystal. As far as I remember crystals should have a good precision... Okey I admit I don't know how to find the clock mismatch value :/ By the way Sklar included a big "ANALOG" in the phrase I quoted above and somehow I didn't see it :) My system is digital though and I create the high freq carrier signal in the dsp. I will now check the tutorials you have pointed out. Thanks a lot for your help. Rifo PS: Julius, can you also tell me which parts I can simplify since my mixers are implemented digitally
rifo wrote:> > I hope I have a correct interpretation of clock mismatch concept :) so > here it goes... > > Both development boards have the same codec (CS4125) which is driven by > a 24.576 Mhz crystal. As far as I remember crystals should have a good > precision... > Okey I admit I don't know how to find the clock mismatch value :/You can usually count on cheap run-of-the-mill crystals to be within 1E-7 of nominal. That's worst-case mismatch of 2E-7. ... Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On Jul 20, 1:33 pm, "rifo" <rtur...@yahoo.de> wrote:> I hope I have a correct interpretation of clock mismatch concept :) so > here it goes... > > Both development boards have the same codec (CS4125) which is driven by > a 24.576 Mhz crystal. As far as I remember crystals should have a good > precision... > Okey I admit I don't know how to find the clock mismatch value :/Two crystals, even manufactured in the same place at the same time, will not be perfectly accurate. This is specified by the PPM (parts per million) accuracy. Please read up on this.> By the way Sklar included a big "ANALOG" in the phrase I quoted above > and somehow I didn't see it :) > My system is digital though and I create the high freq carrier signal in > the dsp. I will now check the tutorials you have pointed out.Please stop comparing apples with durians [1]. This is not good practice :-).> Thanks a lot for your help. > Rifo > > PS: Julius, can you also tell me which parts I can simplify since my > mixers are implemented digitallyIt is possible to rely only on timing adjustment, without phase correction, assuming that you oversample the signal in the first place. Sorry, but this is as far as I can help you for now. Julius [1] http://en.wikipedia.org/wiki/Durian
Jerry Avins wrote:> You can usually count on cheap run-of-the-mill crystals to be within > 1E-7 of nominal."Misunderestimate" (c) W Bush. The microprocessor grade crystal from a pile is usually accurate to about 1e-5 of nominal. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky wrote:> > > Jerry Avins wrote: > >> You can usually count on cheap run-of-the-mill crystals to be within >> 1E-7 of nominal. > > "Misunderestimate" (c) W Bush. > > The microprocessor grade crystal from a pile is usually accurate to > about 1e-5 of nominal.The world is going to pot. Back in my day, Sonny, .... Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
