Hi, I do not know much about O notation, except that it gives a theoretical indication of the performance of some algorithms. I have seen a reference somewhere (have to look it up, but think it was in "Numerical recipes in C") that matrix inversion is O(N^3). Is this true for all sizes of N, assuming an (N x N) matrix, or does the inversion of large matrices of size (N x N) approach O(N^3)? I.e., for matrices with small N, the actual performance would be better than O(N^3)? Would it then be better to try and break large (N x N) matrices into smaller matrices and invert these, if it is possible? Your time, effort and suggestions will be greatly appreciated? Jaco Versfeld
Is Matrix inversion O(N^3)?
Started by ●May 12, 2004
Reply by ●May 12, 20042004-05-12
On 12 May 2004 07:12:11 -0700, Jaco Versfeld wrote:> Hi,> I do not know much about O notation, except that it gives a > theoretical indication of the performance of some algorithms.> I have seen a reference somewhere (have to look it up, but think it > was in "Numerical recipes in C") that matrix inversion is O(N^3).The usual algorithms are O(N^3), but there is a class of algorithms such as Strassen's algorithm that improves on that. I think it's something like O(N^2.83) for Strassen and somewhat better for some other algorithms based on a similar technique. The basic idea is to reduce the number of multiplications required, at the cost of many extra additions. This can be an advantage when you realize that the algorithm can be applied recursively to block submatrices, where matrix multiplication is much slower than matrix addition.> Is this true for all sizes of N, assuming an (N x N) matrix, or does > the inversion of large matrices of size (N x N) approach O(N^3)? > I.e., for matrices with small N, the actual performance would be > better than O(N^3)?The O notation actually doesn't tell you anything at all about performance for small N. It's only relevant to the asymptotic behavior as N -> oo. And it doesn't automatically follow that an O(N^2.83) algorithm is better (faster, easier) than one that is O(N^3), since the O natation only tells you about the time up to some multiplicative constant, which in practice is much larger for the Strassen-class algorithms than for standard Gaussian elimination. This means that the potential advantage of using Strassen only exists for very large matrices.> Would it then be better to try and break large (N x N) matrices into > smaller matrices and invert these, if it is possible?Not exactly, but recursion is part of the algorithm.> Your time, effort and suggestions will be greatly appreciated? > Jaco Versfeld-- Dave Seaman Judge Yohn's mistakes revealed in Mumia Abu-Jamal ruling. <http://www.commoncouragepress.com/index.cfm?action=book&bookid=228>
"Jaco Versfeld" <jaco_versfeld@hotmail.com> wrote in message news:e48813da.0405120612.22b81029@posting.google.com...> Is this true for all sizes of N, assuming an (N x N) matrix, or does > the inversion of large matrices of size (N x N) approach O(N^3)? > I.e., for matrices with small N, the actual performance would be > better than O(N^3)?Big O doesn't care what happens to the small N either way. While the classical Gaussian elimination algorithm is O(N^3), there are faster algorithms. The current record is O(N^2.376). However, the faster algorithms are more challenging to implement as computer programs and sacrifice numerical stability. See <http://mathworld.wolfram.com/StrassenFormulas.html> for some related info.
On 12 May 2004 07:12:11 -0700, Jaco Versfeld <jaco_versfeld@hotmail.com> wrote:> Hi, > > I do not know much about O notation, except that it gives a > theoretical indication of the performance of some algorithms.DAGS on "Big O Notation" Tons of references. I like "Discrete Mathematics and its Application(s)" for a good, rigorous, discussion of all things Discrete.> > I have seen a reference somewhere (have to look it up, but think it > was in "Numerical recipes in C") that matrix inversion is O(N^3). > > Is this true for all sizes of N, assuming an (N x N) matrix, or does > the inversion of large matrices of size (N x N) approach O(N^3)? > I.e., for matrices with small N, the actual performance would be > better than O(N^3)?Nope. Big O notation (now that you've looked it up) is for all N.> Would it then be better to try and break large (N x N) matrices into > smaller matrices and invert these, if it is possible?With matrices there are a ton of special cases that make your life easier: Say for example you know your matrix is invertable beforehand, the matrix is sparse with certain properties . . . the matrix is already in row-reduced form. For certain classes of problems, all of these simplifications apply. "Numerical Recipies in ..." primary value is in telling you where to go for better information. Their implementations are better in FORTRAN--the're all based on Fortran IV. All other languages are translations of varying success. I found their simple functions more useful than their vector-matrix operations: Their matrix and vector libraries rely on "Undefined Behavior" which is NEVER good. Their fft code works.
"Jaco Versfeld" <jaco_versfeld@hotmail.com> wrote in message news:e48813da.0405120612.22b81029@posting.google.com...> Hi, > > I do not know much about O notation, except that it gives a > theoretical indication of the performance of some algorithms. > > I have seen a reference somewhere (have to look it up, but think it > was in "Numerical recipes in C") that matrix inversion is O(N^3). > > Is this true for all sizes of N, assuming an (N x N) matrix, or does > the inversion of large matrices of size (N x N) approach O(N^3)? > I.e., for matrices with small N, the actual performance would be > better than O(N^3)? > > Would it then be better to try and break large (N x N) matrices into > smaller matrices and invert these, if it is possible? > > Your time, effort and suggestions will be greatly appreciated? > Jaco VersfeldHello Jaco, Yes the general effort for matrix inversion is O(N^3) but in Numerical Recipes (in C) they do give some details for an algo that is O(N^2.7). However the overhead of keeping track of what is going on seems to diminish the advantage - and for small matrices the added complication is not worth it. There are some iterative methods for solving systems of equations. Do you have a particular system you wish to solve or do you just want to invert a matrix? The way I would handle the problem would be to write a c++ object for your GF arithmetic and overload the standard arithmatic operators to work in your GF. Then just use a standard matrix inversion routine. I did this with a different class of numbers and it worked like a champ. -- Clay S. Turner, V.P. Wireless Systems Engineering, Inc. Satellite Beach, Florida 32937 (321) 777-7889 www.wse.biz csturner@wse.biz
Hi Jaco,
In a problem on p.287, [1] states that matrix inversion
requires n^3 multiplications/divisions and n^3 - 2*n^2 + n
additions/subtractions. There is also some discussion on
the problem in [2] but (surpisingly) not an explicit derivation
of the complexity.
Also, my coding theory professor stated this in a class just this
past (Spring) semester.
--Randy
[1] = @BOOK{burden,
title = "{Numerical Analysis}",
author = "Richard~L.Burden, J.~Douglas~Faires, Albert~C.~Reynolds",
publisher = "Prindle, Weber and Schmidt",
edition = "second",
year = "1981"}
[2] = @BOOK{artofcomputerprogrammingb,
title = "{The Art of Computer Programming, Volume 2: Seminumerical Algorithms",
author = "Donald~E.~Knuth",
publisher = "Addison-Wesley",
edition = "third",
year = "1998"}
jaco_versfeld@hotmail.com (Jaco Versfeld) writes:
> Hi,
> better than O(N^3)?
> Jaco Versfeld
Randy Yates
Sony Ericsson Mobile Communications
Research Triangle Park, NC, USA
randy.yates@sonyericsson.com, 919-472-1124
Dave Seaman wrote: ...> The usual algorithms are O(N^3), but there is a class of algorithms such > as Strassen's algorithm that improves on that. I think it's something > like O(N^2.83) for Strassen and somewhat better for some other algorithms > based on a similar technique. The basic idea is to reduce the number of > multiplications required, at the cost of many extra additions. ...That's not a useful trade on hardware with single-cycle multipliers. For DSPs, the O() calculations need to use the same cost for addition and multiplication, and a relatively exorbitant cost for division. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Wed, 12 May 2004 13:05:17 -0400, Jerry Avins wrote:> Dave Seaman wrote:> ...>> The usual algorithms are O(N^3), but there is a class of algorithms such >> as Strassen's algorithm that improves on that. I think it's something >> like O(N^2.83) for Strassen and somewhat better for some other algorithms >> based on a similar technique. The basic idea is to reduce the number of >> multiplications required, at the cost of many extra additions. ...> That's not a useful trade on hardware with single-cycle multipliers. For > DSPs, the O() calculations need to use the same cost for addition and > multiplication, and a relatively exorbitant cost for division.It may be a useful trade if you are comparing multiplication of, say, 1024x1024 matrices with addition of those matrices. The cost is most definitely not the same. -- Dave Seaman Judge Yohn's mistakes revealed in Mumia Abu-Jamal ruling. <http://www.commoncouragepress.com/index.cfm?action=book&bookid=228>
Dave Seaman wrote:> On Wed, 12 May 2004 13:05:17 -0400, Jerry Avins wrote: > >>Dave Seaman wrote: > > >> ... > > >>>The usual algorithms are O(N^3), but there is a class of algorithms such >>>as Strassen's algorithm that improves on that. I think it's something >>>like O(N^2.83) for Strassen and somewhat better for some other algorithms >>>based on a similar technique. The basic idea is to reduce the number of >>>multiplications required, at the cost of many extra additions. ... > > >>That's not a useful trade on hardware with single-cycle multipliers. For >>DSPs, the O() calculations need to use the same cost for addition and >>multiplication, and a relatively exorbitant cost for division. > > > It may be a useful trade if you are comparing multiplication of, say, > 1024x1024 matrices with addition of those matrices. The cost is most > definitely not the same.Indeed, but few programmable processors have instructions to deal with matrices. I assume that the primitives in the O() calculations deal with executable instructions. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Wed, 12 May 2004 13:58:01 -0400, Jerry Avins wrote:> Dave Seaman wrote:>> On Wed, 12 May 2004 13:05:17 -0400, Jerry Avins wrote:>>>Dave Seaman wrote:>>> ...>>>>The usual algorithms are O(N^3), but there is a class of algorithms such >>>>as Strassen's algorithm that improves on that. I think it's something >>>>like O(N^2.83) for Strassen and somewhat better for some other algorithms >>>>based on a similar technique. The basic idea is to reduce the number of >>>>multiplications required, at the cost of many extra additions. ...>>>That's not a useful trade on hardware with single-cycle multipliers. For >>>DSPs, the O() calculations need to use the same cost for addition and >>>multiplication, and a relatively exorbitant cost for division.>> It may be a useful trade if you are comparing multiplication of, say, >> 1024x1024 matrices with addition of those matrices. The cost is most >> definitely not the same.> Indeed, but few programmable processors have instructions to deal with > matrices. I assume that the primitives in the O() calculations deal with > executable instructions.Huh? Are you claiming that you can't do an O() calculation if the algorithm you are evaluating makes use of subroutines? I beg to differ. At the lowest level, everything reduces to executable instructions, but that is irrelevant to what I said. The Strassen algorithm is pointless if you don't apply it recursively, and that is precisely where addition and multiplication begin to have unequal cost. -- Dave Seaman Judge Yohn's mistakes revealed in Mumia Abu-Jamal ruling. <http://www.commoncouragepress.com/index.cfm?action=book&bookid=228>
