Thoughts on the C/Assembly Debate
Started by Randy Yates July 28, 2007
In article <b1Jqi.83$jO3.8@nlpi070.nbdc.sbc.com>,  <hel@40th.com> wrote:
>Check Intel's marketing for its C/C++ compiler. >I'm sure in there somewhere is how it detects >SOA/AOS requirements and reorders data, and >vectors it all using SSE2/3/4 for best effect. >I'm almost as sure that MS/VS will do the same. >All this even without #pragma hints. Since so >few will ever know asm well enough to beat a >current compiler, guru code (potentially) being >better than compiler code is pretty much moot. >Besides, this is more about knowing how to order >data, not a compiler/assembler thing. Had to yawn
One can easily give examples where the current languages are poor, and one can produce better instruction sets. One case, lacking in all computer languages to my knowledge (LISP may be an exception, but it is too clumsy) is the ability to have a list of results to the left of the replacement operator; this utility of this cannot be achieved by a struct. Also, there are many useful procedures in many machines (alas, they are declining due to the HLL mentality) which the HLLs cannot even conceive of. The assembly languages can be improved as well, decreasing their code length to be comparable to that of HLLs. The point is to use short names to avoid errors, and one can even use overloading in the assembler. There is no need to assume that assemblers have to be complete idiots. Please respond to sci.math or email me any response to this. -- This address is for information only. I do not claim that these views are those of the Statistics Department or of Purdue University. Herman Rubin, Department of Statistics, Purdue University hrubin@stat.purdue.edu Phone: (765)494-6054 FAX: (765)494-0558
Hi,
[Newsgroups line again shortened]
Randy Yates wrote:
> What I don't understand is why, once the decision > has been made that portability/readability/maintainability is to be > secondary to performance, assembly is a bad choice. As I just wrote in > another thread, it isn't that awful. Is it? I mean, folks here argue > as if it takes MAN-YEARS to write a single assembly routine.
Because it does take man-years? :-) I think nobody doubts that solving a given problem of sufficient size (i.e. more than just "compute a 2nd-order IIR filter") in assembly takes longer than solving the same problem in a high-level-language, be it C or something "higher". The high-level-language programmer will thus simply be ready before the all-in-asm programmer. Most of the time, the product will be "good enough" in terms of performance. And if it's too big or too slow, he still has enough time left to find and eliminate the performance eaters. Hence, saying "I'll do it in only asm to get best possible performance" is useless, because usually you only need good-enough performance. Asm is a useful addition to a high-level-language, but nothing to start a (sufficiently large) project in. Stefan
In article <IICdnb-H28SwMTbbnZ2dnUVZ_tbinZ2d@rcn.net>,
Jerry Avins  <jya@ieee.org> wrote:
>gyansorova@gmail.com wrote: >> On Jul 29, 2:18 am, Randy Yates <ya...@ieee.org> wrote:
>>> Also note that requiring the programmer to know the processor architecture >>> defeats, at least in part, the point of a high-level-language since time >>> is spent learning things that ideally would be handled by the compiler.
The compiler cannot handle them, as the programmer might want to do something the compiler writer did not envision.
>>> Note that this is absolutely irrefutable. The C language (and every other >>> computer language that I know of) is not capable of optimizing this BECAUSE >>> IT DOESN'T HAVE CONTROL OVER DATA ALIGNMENT AND STRUCTURE.
It does, to some extent, but not enough.
>> I have a feeling that data-flow is the answer. Check out the latest >> LabView. You must think differently.Sequencial code will die.
This is not enough, and also false. There are ways of writing non-sequential code sequentially.
>Until processors routinely execute and n instructions in parallel, all >code will be executed sequentially. You might as well write it that way.
This has been false for a long time. Instructions may be issued sequentially, but might not be executed sequentially. This can even cause errors in a high-level language, where two subroutines can write to the same memory locations, and if the modules executing those are parallel, the wrong one can write first. Such blocks can be put in hardware, but they can be circumvented without too much effort. This can easily happen on an MIMD machine, unless the programmer puts in the appropriate signaling. -- This address is for information only. I do not claim that these views are those of the Statistics Department or of Purdue University. Herman Rubin, Department of Statistics, Purdue University hrubin@stat.purdue.edu Phone: (765)494-6054 FAX: (765)494-0558
Rune Allnor wrote:
> On 30 Jul, 11:34, "Wade Ward" <zaxf...@invalid.net> wrote: > >> Tim has regular comment if c.l.f., fortran being a common extension of C. > > Really? That's new to me. According to the myths I've > heard, Fortran was developed alongside the first usable > computers in the '50s and early '60s. As I know the > language, that might very well be true (code start in > column 7, lines no longer than to column 72, no line > breaks inside statements, awkward function call > specifications, either '!' or 'C' as comment indicators, > and so on). C, on the other hand, was apparently > developed alongside UNIX in the late '60s / early '70s. > > If this is correct, I find a claim that "fortran is an > extension of C" very hard to believe. If such a claim > really has been made -- I read from comp.dsp -- I would > very much like to see the evidence to justify it.
I suspect that you misinterpreted Wade because you were foolish enough to accept what he wrote. :-) There's a lot of good Fortran code, much of it as libraries of subroutines. The calling sequences for calling Fortran routines differs from C, but it's common for C compilers to allow the Fortran calling sequence in order to make those libraries useful as C extensions. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Wade Ward wrote:
> "Tim Prince" <timothyprince@sbcglobal.net> wrote in message > news:ZqKqi.122$IE5.71@newssvr17.news.prodigy.net... >> hel@40th.com wrote: >>> Check Intel's marketing for its C/C++ compiler. >>> I'm sure in there somewhere is how it detects >>> SOA/AOS requirements and reorders data, and >>> vectors it all using SSE2/3/4 for best effect. >>> I'm almost as sure that MS/VS will do the same. >> If you checked the marketing, you might have seen that Intel C++ >> implements complex data type auto-vectorization for SSE3, but requires C99 >> syntax for that. Since you are cross-posting to c.l.f, you might consider >> that some people would prefer to use Fortran rather than less optimal asm >> hacks. Sorry if you are put off by flashbacks to the days when people >> called Fortran functions from COBOL rather than do asm. Beats me why >> people would rather use asm than embed C99 in C++ or C89. Don't know >> whether you consider the <?intrin.h> stuff to be assembly. > Tim has regular comment if c.l.f., fortran being a common extension of C. > As such, it has a standard. > > My experience in assembly would lead me to believe that it just might not > have a standard, as it is so close to many OS/hardware questions. I have > two questions: > 1) Does assembly have a standard?
There is a different assembly language for every processor family, and dialects peculiar to particular members of that family. There are some broad conventions, but I doubt that you mean that, so I won't try to enumerate some of them.
> 2) If fortran binds C, and C binds assembly, does Fortran bind assembly?
Bind? Like Immodium? Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
In article <1185677476.223390.5560@r34g2000hsd.googlegroups.com>,
robert bristow-johnson  <rbj@audioimagination.com> wrote:
>On Jul 28, 4:50 pm, Jerry Avins <j...@ieee.org> wrote:
>> Until processors routinely execute and n instructions in parallel, all >> code will be executed sequentially. You might as well write it that way.
>and if instructions have conditionals in them, those would have to be >executed sequentially, despite the brawn, no?
No. A conditional branch can be executed before all the already issued instructions are finished. Whether this can happen depends on the hardware; I do not know if the CYBER 205 had such blocks on a conditional after a vector instruction, and vectors could be quite long.
>r b-j
Walter Banks wrote:
> C99 compilers that implement ISO/IEC 18037 have full access > to the flag bits and all processor registers.
Wonderful! How is that done portably? Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Stefan Reuther wrote:
> Hi, > > [Newsgroups line again shortened] > > Randy Yates wrote: >> What I don't understand is why, once the decision >> has been made that portability/readability/maintainability is to be >> secondary to performance, assembly is a bad choice. As I just wrote in >> another thread, it isn't that awful. Is it? I mean, folks here argue >> as if it takes MAN-YEARS to write a single assembly routine. > > Because it does take man-years? :-) > > I think nobody doubts that solving a given problem of sufficient size > (i.e. more than just "compute a 2nd-order IIR filter") in assembly takes > longer than solving the same problem in a high-level-language, be it C > or something "higher". The high-level-language programmer will thus > simply be ready before the all-in-asm programmer. Most of the time, the > product will be "good enough" in terms of performance. And if it's too > big or too slow, he still has enough time left to find and eliminate the > performance eaters. > > Hence, saying "I'll do it in only asm to get best possible performance" > is useless, because usually you only need good-enough performance. Asm > is a useful addition to a high-level-language, but nothing to start a > (sufficiently large) project in.
Check out http://www.grc.com/default.htm (Gibson Research). Gibson writes all his code in assembly, including graphics. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Wade Ward wrote:
(snip)
Assembly is the human readable representation of the operations for a specific processor. It is different for each type of processor, or even for each revision of a processor. (Though not always very different.) Even then it isn't standard. The GNU assemblers often use different notation than the ones supplied by the manufacturer of the processor.
In terms of "high level languages", C is considered lower level than many others. It is a little more natural to allow mixing of assembler and C. -- glen
Jerry Avins <jya@ieee.org> writes:
> Walter Banks wrote: > > C99 compilers that implement ISO/IEC 18037 have full access > > to the flag bits and all processor registers. > > Wonderful! How is that done portably?
It's not really intended to be "portable" as such (except within closely related chip families). It's meeting in the middle, a syntactic sugar which permits the high level language to address low level concepts without resorting to __asm. It permits the programmer, or the chip vendor's toolchain header files, to declare a variable which represents the such-and-such register. The toolchain knows that when it sees the declaration it's supposed to use a certain hardware register for that variable. It is independent of the declaration of the type of the variable, so that you can declare a flags register as being a struct of bitfields if you so desire, or just an unstructured integer type, if you'd prefer that. Neither would be of any relevance to an unrelated architecture. So it enables you to concretise the underlying architecure, more than abstracting it. Phil -- Dear aunt, let's set so double the killer delete select all. -- Microsoft voice recognition live demonstration
