Hi all, I've heared about particular algorithms to detect CW on a FFT. Anyone can help me ?
CW detection on DSP
Started by ●August 1, 2007
Reply by ●August 1, 20072007-08-01
On Aug 1, 10:37 am, "Bruno DAJIN" <brunodajin_nosp...@yahoo.fr> wrote:> I've heared about particular algorithms to detect CW on a FFT. > Anyone can help me ?Depends on the nature of what you need to detect. Is the carrier wave frequency fixed or modulated? Is the carrier wave frequency known or bounded? What is the signal-to-noise ratio with which you are working? Do you need to detect just the carrier, or are you interested in decoding Morse Code encoded CW? Do you know the WPM of the Morse Code? Is the WPM precise (machine generated), or is there a noticeable "fist" or other timing variations? Is the Morse Code dot clock synchronous or async to your fft apertures/windows? If the signal-to-noise ratio is very low, do you have some statistics on the textual content? A plain FFT might be good at finding the presence or absence of a relatively strong CW carrier, given reasonable assumptions about the frequencies, sample rates, frame size and noise levels; but other techniques may be needed to find the beginning and ends of the dots and dashes, or the likely encoded content of any contained message, depending on the exact nature and constraints of your problem per the answers to some of the questions above. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Reply by ●August 2, 20072007-08-02
Bruno DAJIN wrote:> Hi all, > > I've heared about particular algorithms to detect CW on a FFT. > Anyone can help me ?You know it's CW if it has no sidebands: i.e., it has a line spectrum. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On 2007-08-01, Bruno DAJIN <brunodajin_nospam_@yahoo.fr> wrote:> > I've heared about particular algorithms to detect CW on a FFT.If you display an FFT as a waterfall (one example here: http://www.nitehawk.com/sm5bsz/linuxdsp/usage/sdr14-w/sdr14-vw.htm ) it's pretty easy to see. -- Ben Jackson AD7GD <ben@ben.com> http://www.ben.com/
On Aug 1, 9:16 pm, Jerry Avins <j...@ieee.org> wrote:> Bruno DAJIN wrote: > > Hi all, > > > I've heared about particular algorithms to detect CW on a FFT. > > Anyone can help me ? > > You know it's CW if it has no sidebands: i.e., it has a line spectrum.Morse code modulated CW does have sidebands. The bandwidth required for typical human demodulation is around 2 to 4 times the WPM, although wider anti-click filtering is commonly used, which makes it easier to copy by ear (less ringy sounding). Synchronous DSP demodulated Morse code can be done using less bandwidth than the WPM, limited of course by the information capacity given the S/N ratio of the channel. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M (amateur advanced class)
Ron N. wrote:> On Aug 1, 9:16 pm, Jerry Avins <j...@ieee.org> wrote: >> Bruno DAJIN wrote: >>> Hi all, >>> I've heared about particular algorithms to detect CW on a FFT. >>> Anyone can help me ? >> You know it's CW if it has no sidebands: i.e., it has a line spectrum. > > Morse code modulated CW does have sidebands. The > bandwidth required for typical human demodulation is > around 2 to 4 times the WPM, although wider anti-click > filtering is commonly used, which makes it easier to > copy by ear (less ringy sounding).If its modulated, its not a pure carrier wave. Its an extreme form of AM, if it is pure OOK. Steve
Ron N. wrote:> On Aug 1, 9:16 pm, Jerry Avins <j...@ieee.org> wrote:(snip)>>You know it's CW if it has no sidebands: i.e., it has a line spectrum.> Morse code modulated CW does have sidebands. The > bandwidth required for typical human demodulation is > around 2 to 4 times the WPM, although wider anti-click > filtering is commonly used, which makes it easier to > copy by ear (less ringy sounding).Note that this is exactly the problem that Nyquist was working on: Quoting from Wikipedia: "In 1927 Nyquist determined that the number of independent pulses that could be put through a telegraph channel per unit time is limited to twice the bandwidth of the channel. Nyquist published his results in the paper Certain topics in Telegraph Transmission Theory (1928)." http://en.wikipedia.org/wiki/Harry_Nyquist I am not sure how you are converting WPM to bandwidth. http://en.wikipedia.org/wiki/Morse_code indicates that T=1200/W, where T is the dit time and W is WPM. -- glen
Reply by ●August 3, 20072007-08-03
On Wed, 1 Aug 2007 19:37:36 +0200, "Bruno DAJIN" <brunodajin_nospam_@yahoo.fr> wrote:>Hi all, > >I've heared about particular algorithms to detect CW on a FFT. >Anyone can help me ?Hi Bruno, Can you tell us EXACTLY what you mean by "CW", giving us every characteristic that you can think of regarding this thing you call "CW"? I'll bet the guys here can help you if you're able to clearly explain what it is that you're trying to detect. [-Rick-]
R.Lyons@_BOGUS_ieee.org (Rick Lyons) writes:> On Wed, 1 Aug 2007 19:37:36 +0200, "Bruno DAJIN" > <brunodajin_nospam_@yahoo.fr> wrote: > >>Hi all, >> >>I've heared about particular algorithms to detect CW on a FFT. >>Anyone can help me ? > > Hi Bruno, > Can you tell us EXACTLY what you mean > by "CW", giving us every characteristic > that you can think of regarding this > thing you call "CW"? > > I'll bet the guys here can help you if > you're able to clearly explain what it > is that you're trying to detect.Perhaps he's speaking of the basic detection problem in which an observation has two hypotheses: H0 == there is no signal present, H1 = a signal is present. By "signal" he means a single sinusoid at a known frequency but unknown amplitude. But you're right - it's a good idea for the OP to clarify what he means. -- % Randy Yates % "The dreamer, the unwoken fool - %% Fuquay-Varina, NC % in dreams, no pain will kiss the brow..." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO http://home.earthlink.net/~yatescr
Reply by ●August 4, 20072007-08-04
On Aug 3, 7:32 pm, Randy Yates <ya...@ieee.org> wrote:> R.Lyons@_BOGUS_ieee.org (Rick Lyons) writes: > > On Wed, 1 Aug 2007 19:37:36 +0200, "Bruno DAJIN" > > <brunodajin_nosp...@yahoo.fr> wrote: > > >>Hi all, > > >>I've heared about particular algorithms to detect CW on a FFT. > >>Anyone can help me ? > > > Hi Bruno, > > Can you tell us EXACTLY what you mean > > by "CW", giving us every characteristic > > that you can think of regarding this > > thing you call "CW"? > > > I'll bet the guys here can help you if > > you're able to clearly explain what it > > is that you're trying to detect. > > Perhaps he's speaking of the basic detection problem > in which an observation has two hypotheses: H0 == there > is no signal present, H1 = a signal is present. By > "signal" he means a single sinusoid at a known frequency > but unknown amplitude. > > But you're right - it's a good idea for the OP to clarify > what he means.Clarification would be good, given that I've heard the term "CW" used more often as an abbreviation for Morse Code than for pure carrier waves, even though the letters don't match... (or maybe one letter is upside-down :^) For audio Morse Code, one poster mentioned a waterfall display of fft's; but a scrolling spectrogram using fft's would allow one to read off any dots and dashes left-to-right, which might be easier than top-to-bottom (with the appropriate band separations and WPMs for the fft frame sizes, of course). IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
