I am modeling a system using a conventional linear predictor, in which the present output sample is predicted as a linear combination of past samples. Having obtained the transfer function of the analysis filter from those prediction coefficients, I am formulating the synthesis filter from the inverse of the analysis filter. All standard stuff, and my question is not about any aspect of the linear predictor. Instead, my question is about interpretation of the results. I am attempting to use the poles of the synthesis filter to determine an estimate of the system natural frequencies. From first principles I know that z = exp[sT] = exp[sigma + j(omega T)], so I can determine omega directly from the angle between the poles and the real axis. However, I also know that if a complex pole pair is viewed as a damped second-order system, then the resulting natural frequency is not only determined by the angle between the poles and the real axis, but also by the distance from the origin to the poles: z = exp[-(D omega T) +/- j(omega (sqrt(1-D^2)) T)], where D is damping factor. Under these circumstances, which is the more appropriate interpretation? Thanks, Greg
Help With Interpretation of Pole Locations in Z-Plane
Started by ●August 1, 2007
Reply by ●August 2, 20072007-08-02
"Greg Berchin" <gberchin@sentientscience.com> wrote in message news:1185992733.658190.286920@19g2000hsx.googlegroups.com...> I am modeling a system using a conventional linear predictor, in which > the present output sample is predicted as a linear combination of past > samples. Having obtained the transfer function of the analysis filter > from those prediction coefficients, I am formulating the synthesis > filter from the inverse of the analysis filter. > > All standard stuff, and my question is not about any aspect of the > linear predictor. Instead, my question is about interpretation of the > results. I am attempting to use the poles of the synthesis filter to > determine an estimate of the system natural frequencies. From first > principles I know that z = exp[sT] = exp[sigma + j(omega T)], so I can > determine omega directly from the angle between the poles and the real > axis. However, I also know that if a complex pole pair is viewed as a > damped second-order system, then the resulting natural frequency is > not only determined by the angle between the poles and the real axis, > but also by the distance from the origin to the poles: z = exp[-(D > omega T) +/- j(omega (sqrt(1-D^2)) T)], where D is damping factor. > Under these circumstances, which is the more appropriate > interpretation?Hi Greg, My understanding is the LPC analysis gives you a MSE model of spectrum. Therefore there is generally no direct relation between the pole locations of the synth. filter and the modes of the system. As for your question, in those special cases where there is such relation, the damping should be accounted for. Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
On Aug 2, 1:10 am, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> wrote:> My understanding is the LPC analysis gives you a MSE model of spectrum. > Therefore there is generally no direct relation between the pole locations > of the synth. filter and the modes of the system.I have been struggling with that issue, too. Frankly, none of the reference material I have read addresses the subject directly. However, I do know that, when the measured data consist of pure sinusoids, the poles of the synthesis filter match the sinewave frequencies extremely well. However, such test signals do not answer the damping question, because pure sinewaves fall on the jw axis where damping is nonexistent.> As for your question, in > those special cases where there is such relation, the damping should be > accounted for.I have been leaning toward that conclusion myself, based upon my experimental results. It's always good to get a second opinion, however. Thank you, Vladimir, Greg
On Aug 2, 7:12 am, Greg Berchin <gberc...@sentientscience.com> wrote:> On Aug 2, 1:10 am, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> > wrote: > > > My understanding is the LPC analysis gives you a MSE model of spectrum. > > Therefore there is generally no direct relation between the pole locations > > of the synth. filter and the modes of the system. > > I have been struggling with that issue, too. Frankly, none of the > reference material I have read addresses the subject directly. > However, I do know that, when the measured data consist of pure > sinusoids, the poles of the synthesis filter match the sinewave > frequencies extremely well. However, such test signals do not answer > the damping question, because pure sinewaves fall on the jw axis where > damping is nonexistent.You should expect to get good results with pure sinusoid inputs, as they are both deterministic and periodic. The linear predictor can exactly predict future samples based on past values; all it needs is a single tap with a value of unity at the delay line that corresponds to the sinusoid's period. For more complicated signals, however, as Vladimir pointed out, all you get is a MSE model of the system, which doesn't necessarily relate to the system's modes. Jason
On Aug 2, 7:40 am, cincy...@gmail.com wrote:> You should expect to get good results with pure sinusoid inputs, as > they are both deterministic and periodic.For that matter, so are the signals that I am characterizing ... at least it's a reasonable assumption over some short time periods, and those are the regions in which I am interested. There is, of course, also some noise.> The linear predictor can > exactly predict future samples based on past values; all it needs is a > single tap with a value of unity at the delay line that corresponds to > the sinusoid's period.The period can be considerably longer than the predictor, in my case. Thanks, Greg
