hi, I have written program for fft in M file and using fixed point toolbox i simulated FFT . The final results` WordLength was 35 and FractionLength 27. I then took normal fft and compared results ,error was in the range of 10^-3. Just for curiosity i converted output of normal(Double Precision ) fft into fixed point using fi. The resulting fi object was having WordLength of 16 and FractionLength of 12. And error almost zero. Now how is this possible , a higher FractionLength should have shown less error isnt it?
Fixed point toolbox and fft
Started by ●August 3, 2007
Reply by ●August 5, 20072007-08-05
On Aug 3, 12:56 am, "sudarshan_onkar" <sudarshan.on...@gmail.com> wrote:> hi, > I have written program for fft in M file and using fixed point > toolbox i simulated FFT . The final results` WordLength was 35 and > FractionLength 27. I then took normal fft and compared results ,error was > in the range of 10^-3. > > Just for curiosity i converted output of normal(Double Precision ) > fft > into fixed point using fi. The resulting fi object was having WordLength > of 16 and FractionLength of 12. And error almost zero. Now how is this > possible , a higher FractionLength should have shown less error isnt it?Normalization issue? That would be my guess. Julius
Reply by ●August 6, 20072007-08-06
>On Aug 3, 12:56 am, "sudarshan_onkar" <sudarshan.on...@gmail.com> >wrote: >> hi, >> I have written program for fft in M file and using fixed point >> toolbox i simulated FFT . The final results` WordLength was 35 and >> FractionLength 27. I then took normal fft and compared results ,errorwas>> in the range of 10^-3. >> >> Just for curiosity i converted output of normal(Double Precision)>> fft >> into fixed point using fi. The resulting fi object was havingWordLength>> of 16 and FractionLength of 12. And error almost zero. Now how is this >> possible , a higher FractionLength should have shown less error isntit?> >Normalization issue? That would be my guess. > >Julius > >You mean to say Scaling is not proper?
