The example in the upfirdn() - link below - is as follows. L = 147; M = 160; % Interpolation/decimation factors. N = 24*M; h = fir1(N,1/M,kaiser(N+1,7.8562)); h = L*h; % Passband gain = L Fs = 48e3; % Original sampling frequency-48kHz n = 0:10239; % 10240 samples, 0.213 seconds long x = sin(2*pi*1e3/Fs*n); % Original signal, sinusoid @ 1kHz y = upfirdn(x,h,L,M); % 9408 samples, still .213 seconds % Overlay original (48kHz) with resampled % signal (44.1kHz) in red. stem(n(1:49)/Fs,x(1:49)); hold on stem(n(1:45)/(Fs*L/M),y(13:57),'r','filled'); xlabel('Time (sec)');ylabel('Signal value'); I think I understand the factors 147 and 160, but cannot figure out why N = 24*M? My understanding of h = fir1(N,1/M,kaiser(N+1,7.8562)) is an FIR of order N, cut-off frequency pi/M, and the given Kaiser window. Am I correct? Thanks in advance. http://www.mathworks.com/access/helpdesk/help/toolbox/signal/index.html?/access/helpdesk/help/toolbox/signal/upfirdn.html&http://www.google.com/search?hl=en&q=upfirdn
Upsample/FIR/downsample
Started by ●August 3, 2007
Reply by ●August 4, 20072007-08-04
On Fri, 03 Aug 2007 19:38:18 -0700, mpowell_jr@hotmail.com wrote:> > >The example in the upfirdn() - link below - is as follows. > >L = 147; M = 160; % Interpolation/decimation factors. >N = 24*M; >h = fir1(N,1/M,kaiser(N+1,7.8562)); >h = L*h; % Passband gain = L >Fs = 48e3; % Original sampling frequency-48kHz >n = 0:10239; % 10240 samples, 0.213 seconds long >x = sin(2*pi*1e3/Fs*n); % Original signal, sinusoid @ 1kHz >y = upfirdn(x,h,L,M); % 9408 samples, still .213 seconds > >% Overlay original (48kHz) with resampled >% signal (44.1kHz) in red. > >stem(n(1:49)/Fs,x(1:49)); hold on >stem(n(1:45)/(Fs*L/M),y(13:57),'r','filled'); >xlabel('Time (sec)');ylabel('Signal value'); > > >I think I understand the factors 147 and 160, but cannot figure out >why N = 24*M? > >My understanding of > >h = fir1(N,1/M,kaiser(N+1,7.8562)) > >is an FIR of order N, cut-off frequency pi/M, and the given Kaiser >window. Am I correct? > >Thanks in advance. >http://www.mathworks.com/access/helpdesk/help/toolbox/signal/index.html?/access/helpdesk/help/toolbox/signal/upfirdn.html&http://www.google.com/search?hl=en&q=upfirdnHello mpowell, Here are my two cents: Because your interpolation factor is so darned high, the filter must be a super narrowband (with a super-narrow transition region width) filter. Your desired filter passband width is roughly Fs/(2*160)!! And I'm guessing your filter's transition region width is on the same order of magnitude. Such a filter, having 50-60 dB of stopband attenuation, will have many hundreds, or maybe a couple thousand taps. That's why I think N was defined to be so large (N = 3840). Now MATLAB's "upfirdn" command (written by the great James McClellan of Parks-McClellan filter design fame) is a MEX file so I couldn't learn exactly how the filtering is implemented. But the filter is implemented using polyphase filter decomposition, so that tells me that the filter's tap length mostly likely needs to be an integer multiple of L or M (I don't know which). So I'm guessing the polyphase implementation is why the filter length was set to an integer multiple of M. BUT!! Here's the part that puzzles me. When we use: h = fir1(N,1/M,kaiser(N+1,7.8562)); the number of coefficients in h is N+1!! That means the number of taps, 3841, is not an integer multiple of either L = 147 or M = 160. I sure can't explain that. Shoot mpowell, I don't think I was of much help here. Let's hope somebody else can be. See Ya', [-Rick-]
> > Shoot mpowell, I don't think I was of much > help here. Let's hope somebody else can be. > > See Ya', > [-Rick-]- Hide quoted text -Rick as always I appreaciate the response. Still soaking up your comments. If only I knew half as much as you, Jerry, Bristow among others
mpowell_jr@hotmail.com wrote:>> Shoot mpowell, I don't think I was of much >> help here. Let's hope somebody else can be. >> >> See Ya', >> [-Rick-]- Hide quoted text - > > Rick as always I appreaciate the response. Still soaking up your > comments. If only I knew half as much as you, Jerry, Bristow among > othersWho, me? I don't know nuttin! Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Reply by ●August 5, 20072007-08-05
On Aug 3, 10:38 pm, mpowell...@hotmail.com wrote:> The example in the upfirdn() - link below - is as follows. > > L = 147; M = 160; % Interpolation/decimation factors. > N = 24*M; > h = fir1(N,1/M,kaiser(N+1,7.8562)); > h = L*h; % Passband gain = L > Fs = 48e3; % Original sampling frequency-48kHz > n = 0:10239; % 10240 samples, 0.213 seconds long > x = sin(2*pi*1e3/Fs*n); % Original signal, sinusoid @ 1kHz > y = upfirdn(x,h,L,M); % 9408 samples, still .213 seconds > > % Overlay original (48kHz) with resampled > % signal (44.1kHz) in red. > > stem(n(1:49)/Fs,x(1:49)); hold on > stem(n(1:45)/(Fs*L/M),y(13:57),'r','filled'); > xlabel('Time (sec)');ylabel('Signal value'); > > I think I understand the factors 147 and 160, but cannot figure out > why N = 24*M?i believe that N=24, means that your polyphase filter (for resampling) is a 24-tap FIR filter and there are 160 different "phases" or fractional-sample delays for it. essentially, the way they are presenting this problem called: "Change the sampling rate by a factor of 147/160. This factor is used to convert from 48kHz (DAT rate) to 44.1kHz (CD sampling rate)." is that you are conceptually upsampling by a factor of 147 (so 48 kHz * 147 = 7.056 Mhz) and then downsample by a factor of 160 (7.058 Mhz = 44.1 kHz * 160). you're doing this (again *conceptually*, you're not actually gonna bloody your fists doing exactly this - you'll win this battle with a little subterfuge) by padding 146 zeros between each of your actual samples. then, to downsample, you're gonna throw away 159 adjacent samples (that you've fought so hard to compute) out of every 160 and what you got left (after lotsa blood and bruises) is your 44.1 kHz audio. that's upsampled to 7 Mhz, *but* you still have images at every multiple of 48 kHz. one at 48, another at 96, another at -48, etc. if you were to resample this at 44.1 kHz, all of those images would fold over into your baseband and you would have an icky mess resembling canine fecal matter. so now (**conceptually**, not really) at the sampling rate of 7.056 Mhz, you're gonna low-pass filter them images (except for the original image centered at 0 Hz) out of the picture with a big, expensive 24*160 = 3840 tap FIR brickwall LPF that gets designed by fir1(.). the cutoff frequency is gonna be Nyquist (3.528 MHz) divided by 160 or 22.05 kHz. hence the 1/M in fir1(). but since 146 out of every 147 samples are zero, your big, expensive 7 Mhz FIR is wasting a lot of multiply-accumulate instructions on terms that you know, *in*advance* are friggin zero. why bother multiplying a bunch of pairs of numbers where one of each pair are known to be zero? i now see a problem in MATLAB's example. they should have made their FIR to be 24*147 = 3528 taps long. then you would know that out of the 3528 taps, exactly 24 equally spaced taps will have non-zero data and the other 3504 taps will have the zero samples. so their first mistake is that h = fir1(24*160,1/M,kaiser(N+1,7.8562)); should be h = fir1(24*147,1/M,kaiser(N+1,7.8562)); so let's correct that error and proceed as if M = 24*147 = 3528 instead of 3840. (i'll bet the arrogant assholes at MathWorks do not admit their error. they never admit their errors, until MATLAB can have non-positive indices in their arrays.) so we know that exactly 24 equally spaced taps have non-zero data and the opther 3504 have zero, so, to save a little blood, we won't bother crunching those numbers. now there are 147 different possible alignments with the upsampled signal relative to the non-zero samples. we are incrementing our index by 160 for each output sample. so let's say we start out at 0 and the taps with non-zero data are at 0, 147, 294, etc. those are the coefficients we'll use and the other coefficients we'll skip over. then we add 160 to our index for our next output sample (we save more of our precious blood by choosing not to fight the other 159 battles between tap 0 and tap 160 - fuck 'em, we don't need those FIR outputs in our final 44.1 kHz signal, we'd be throwing them away anyway). that scoots us ahead by 160 samples (at the 7 Mhz rate). the taps at 0 and 147 are behind us but we still have 294, 441, 588... and, relative to the output sample location of 160, those taps now have relative indices 134, 281, 428... in the big 3528 tap FIR. now if you look at this from the POV of the original samples (at 48 kHz), all of the samples are non-zero but our output pointer or index is not an integer, but also has a fractional value. for every output sample, this index advances by a step of 160/147 (which is 48000/44100). the integer part of this index will tell you which 24 samples to used (all of them at integer indices of equal or ahead of that integer part). the fractional part which is one of 147 possible values, (0/147, 1/147, 2/147 ... 146/147) tells you which set of 24 coefficients out of the 3528 coefs, that you actually have to use to combine in an FIR filter to get your output for one sample at 44.1 kHz. if this is not clear, there is something at DSPguru that explains it this way, but i also periodically post a little FAQ on the sampling theorem and how to think of resampling from that POV (rather than this "upsample by 147 and downsample by 160" thing which i consider to be less intuitive). i like to think of resampling as hypothetically reconstructing the continuous-time output (using what we know from the Nyquist/Shannon Sampling and Reconstruction Theorem) and then sampling that continuous-time function at the *new* sampling instances. if your reconstruction filter (with a continuous-time impulse response) has a finite length (rather than the perfect sinc() function), it eventually comes out to be the same math as the above way of looking at it. there are a lot of EE topics where i choose not to look at it the same way as most other EEs, and this is one of them.> My understanding of > > h = fir1(N,1/M,kaiser(N+1,7.8562)) > > is an FIR of order N, cut-off frequency pi/M, and the given Kaiser > window. Am I correct?yes, almost. the FIR is of order N-1, but the number of taps is the FIR order + 1 (or N). but they fucked it up. N should be 24*147, not 24*160. r b-j
On Aug 5, 1:02 am, robert bristow-johnson <r...@audioimagination.com> wrote: ...> i now see a problem in MATLAB's example. they should have made > their FIR to be 24*147 = 3528 taps long. then you would know that out > of the 3528 taps, exactly 24 equally spaced taps will have non-zero > data and the other 3504 taps will have the zero samples. so their > first mistake is that > > h = fir1(24*160,1/M,kaiser(N+1,7.8562)); > > should be > > h = fir1(24*147,1/M,kaiser(N+1,7.8562)); >my correction to MATLAB's code needs to be corrected. they made two errors. i'm surprized they could make this work at all, because MATLAB is (understandably) quite unforgiving when dimensions of rows and columns of multiplied matrices are incompatible. the program should look like: L = 147; M = 160; % Interpolation/decimation factors. N = 24*L; % 24 taps out of N will be non-zero for every output sample. h = fir1(N-1,1/M,kaiser(N,7.8562)); % FIR order is N-1, but N is the number of taps h = L*h; % Passband gain = L Fs = 48e3; % Original sampling frequency-48kHz n = 0:10239; % 10240 samples, 0.213 seconds long x = sin(2*pi*1e3/Fs*n); % Original signal, sinusoid @ 1kHz y = upfirdn(x,h,L,M); % 9408 samples, still .213 seconds % Overlay original (48kHz) with resampled % signal (44.1kHz) in red. stem(n(1:49)/Fs,x(1:49)); hold on stem(n(1:45)/(Fs*L/M),y(13:57),'r','filled'); xlabel('Time (sec)');ylabel('Signal value');
On Aug 5, 1:02 am, robert bristow-johnson <r...@audioimagination.com> wrote:> On Aug 3, 10:38 pm, mpowell...@hotmail.com wrote: >...> > I think I understand the factors 147 and 160, but cannot figure out > > why N = 24*M? > > i believe that N=24, means that your polyphase filter (for resampling) > is a 24-tap FIR filter and there are 160 different "phases" or > fractional-sample delays for it.and i meant to correct my other misleading statement (following MathWorks' mis-lead), to say that there are 147 different phases or fractional-sample delays, not 160. i gotta be more careful, even if TMW is not. (now cross-posted to comp.soft-sys.matlab. you c.s-s.m folks will have to mosey on over to comp.dsp to see what the rest of this is about. lotsa fun when TMW publishes mistaken code examples.) r b-j
Reply by ●August 6, 20072007-08-06
"robert bristow-johnson" <rbj@audioimagination.com> wrote in message news:1186291696.843200.210150@w3g2000hsg.googlegroups.com...> On Aug 5, 1:02 am, robert bristow-johnson <r...@audioimagination.com> > wrote: >> On Aug 3, 10:38 pm, mpowell...@hotmail.com wrote: >> > ... >> > I think I understand the factors 147 and 160, but cannot figure out >> > why N = 24*M? >> >> i believe that N=24, means that your polyphase filter (for resampling) >> is a 24-tap FIR filter and there are 160 different "phases" or >> fractional-sample delays for it. > > and i meant to correct my other misleading statement (following > MathWorks' mis-lead), to say that there are 147 different phases or > fractional-sample delays, not 160. i gotta be more careful, even if > TMW is not. > > (now cross-posted to comp.soft-sys.matlab. you c.s-s.m folks will > have to mosey on over to comp.dsp to see what the rest of this is > about. lotsa fun when TMW publishes mistaken code examples.)I've asked the developers responsible for the Signal Processing Toolbox to take a look at that example and correct it and/or add some comments clarifying what it's doing. Thanks for bringing it to our attention. If you find something like this in the future, please report it to The MathWorks directly in addition to posting it to comp.dsp. This will make certain that we're aware of the issue (sometimes Usenet messages get delayed or lost) and will let technical support track how many people have reported the issue. You can send feedback in using the forms on this page: http://www.mathworks.com/company/aboutus/contact_us/ For those CSSM readers who want to mosey on over to comp.dsp to read the first messages in this thread, the Google groups link is: http://groups.google.com/group/comp.dsp/browse_frm/thread/27b53982eaed9291/4c4d7ef1c9f78a68?hl=en#4c4d7ef1c9f78a68 -- Steve Lord slord@mathworks.com
On Aug 6, 1:36 pm, "Steven Lord" <sl...@mathworks.com> wrote:> "robert bristow-johnson" <r...@audioimagination.com> wrote in message > > news:1186291696.843200.210150@w3g2000hsg.googlegroups.com... > > > > > On Aug 5, 1:02 am, robert bristow-johnson <r...@audioimagination.com> > > wrote: > >> On Aug 3, 10:38 pm, mpowell...@hotmail.com wrote: > > > ... > >> > I think I understand the factors 147 and 160, but cannot figure out > >> > why N = 24*M? > > >> i believe that N=24, means that your polyphase filter (for resampling) > >> is a 24-tap FIR filter and there are 160 different "phases" or > >> fractional-sample delays for it. > > > and i meant to correct my other misleading statement (following > > MathWorks' mis-lead), to say that there are 147 different phases or > > fractional-sample delays, not 160. i gotta be more careful, even if > > TMW is not. > > > (now cross-posted to comp.soft-sys.matlab. you c.s-s.m folks will > > have to mosey on over to comp.dsp to see what the rest of this is > > about. lotsa fun when TMW publishes mistaken code examples.) > > I've asked the developers responsible for the Signal Processing Toolbox to > take a look at that example and correct it and/or add some comments > clarifying what it's doing. Thanks for bringing it to our attention. > > If you find something like this in the future, please report it to The > MathWorks directly in addition to posting it to comp.dsp. This will make > certain that we're aware of the issue (sometimes Usenet messages get delayed > or lost) and will let technical support track how many people have reported > the issue. You can send feedback in using the forms on this page: > > http://www.mathworks.com/company/aboutus/contact_us/i needed to register or something that made it painful to report.> For those CSSM readers who want to mosey on over to comp.dsp to read the > first messages in this thread, the Google groups link is: > > http://groups.google.com/group/comp.dsp/browse_frm/thread/27b53982eae...give my best to Cleve. please tell him that it's still not to late to fix the horrible indexing problem for MATLAB (when using an FFT, DC is not in "bin #1"). r b-j
On Sun, 05 Aug 2007 05:22:18 -0000, robert bristow-johnson <rbj@audioimagination.com> wrote:>On Aug 5, 1:02 am, robert bristow-johnson <r...@audioimagination.com> >wrote: >... >> i now see a problem in MATLAB's example. they should have made >> their FIR to be 24*147 = 3528 taps long. then you would know that out >> of the 3528 taps, exactly 24 equally spaced taps will have non-zero >> data and the other 3504 taps will have the zero samples. so their >> first mistake is that >> >> h = fir1(24*160,1/M,kaiser(N+1,7.8562)); >> >> should be >> >> h = fir1(24*147,1/M,kaiser(N+1,7.8562)); >> > >my correction to MATLAB's code needs to be corrected. they made two >errors. i'm surprized they could make this work at all, because >MATLAB is (understandably) quite unforgiving when dimensions of rows >and columns of multiplied matrices are incompatible. the program >should look like: > >L = 147; M = 160; % Interpolation/decimation factors. >N = 24*L; % 24 taps out of N will be non-zero for every output >sample. >h = fir1(N-1,1/M,kaiser(N,7.8562)); % FIR order is N-1, but N is the >number of taps >h = L*h; % Passband gain = L >Fs = 48e3; % Original sampling frequency-48kHz >n = 0:10239; % 10240 samples, 0.213 seconds long >x = sin(2*pi*1e3/Fs*n); % Original signal, sinusoid @ 1kHz >y = upfirdn(x,h,L,M); % 9408 samples, still .213 seconds > >% Overlay original (48kHz) with resampled >% signal (44.1kHz) in red. > >stem(n(1:49)/Fs,x(1:49)); hold on >stem(n(1:45)/(Fs*L/M),y(13:57),'r','filled'); >xlabel('Time (sec)');ylabel('Signal value');Hi Robert, I'll bet that you're correct. By the way, in the Math Works "Signal Processing ToolboxUser's Guide" textbook, Version Four (dated 1996), on page 6-301, their upfirdn() example is interpolation by a factor of 160/147. There they designed the FIR filter using: h = fir1(300,2/160); So in that textbook example the FIR filter length was unrelated to either L=160, or M=147. See Ya', [-Rick-]
