Hi, could someone explain me the difference and the relationship between SNR ratio and Eb/No ratio ? thanks a lot !
Eb/No and SNR
Started by ●August 7, 2007
Reply by ●August 7, 20072007-08-07
"dude23" <pf_morlat@yahoo.fr> writes:> Hi, could someone explain me the difference and the relationship between > SNR ratio and Eb/No ratio ? > thanks a lot !Energy per bit (Eb) is defined as the ratio of signal power to bit-rate, Eb = Ps / B [joules / bit], where Ps is in [watts = joules / sec] and B is in [bits / sec]. The bit-rate can be expressed in terms of the spectral efficiency b [bits / sec / Hz] and bandwidth W [Hz] required for the signal as B = b * W [bits / sec]. Therefore Eb = Ps / (b * W) [joules / bit]. Now note that if the noise is flat with constant power spectral density No [watts / Hz = joules], then the noise power Pn in bandwidth W [Hz = 1 / sec] is Pn = No * W [joules / sec = watts]. Thus the signal-to-noise ratio SNR is SNR = Ps / Pn = Ps / (No * W), and Eb / No is related to SNR as Eb / No = Ps / (b * W * No) = SNR / b [1 / bit]. See [lessandmesserschmitt3] for a good coverage of this. To state it more heuristically, Eb/No is a sort of normalized way to look at SNR in which the SNR is normalized to the bit rate. For example, you wouldn't want to consider two signals that have the same SNR to be equivalent (in terms of energy efficiency) if one was twice the bit rate of the other. --Randy @BOOK{leeandmesserschmitt3, title = "{Digital Communication}", author = "{John R. Barry and Edwared A. Lee and David G. Messerschmitt}", publisher = "Springer", edition = "third", year = "2004"} -- % Randy Yates % "My Shangri-la has gone away, fading like %% Fuquay-Varina, NC % the Beatles on 'Hey Jude'" %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Shangri-La', *A New World Record*, ELO http://home.earthlink.net/~yatescr
Randy Yates <yates@ieee.org> writes:> See [lessandmesserschmitt3] for a good coverage of this.Sorry - that should have been [leeandmesserschmitt3].> @BOOK{leeandmesserschmitt3, > title = "{Digital Communication}", > author = "{John R. Barry and Edwared A. Lee and David G. Messerschmitt}", > publisher = "Springer", > edition = "third", > year = "2004"}--Randy -- % Randy Yates % "She tells me that she likes me very much, %% Fuquay-Varina, NC % but when I try to touch, she makes it %%% 919-577-9882 % all too clear." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
After pondering this awhile, I think I made couple of wrong statements and need to correct myself. Everything I initially wrote prior to the point below was correct. Randy Yates <yates@ieee.org> writes:> [...] > To state it more heuristically, Eb/No is a sort of normalized way to > look at SNR in which the SNR is normalized to the bit rate.No. Eb / No is SNR normalized to the spectral efficiency (b). That's pretty much what the mathematical relationship stated directly: Eb / No = SNR / b.> For example, you wouldn't want to consider two signals that have the > same SNR to be equivalent (in terms of energy efficiency) if one was > twice the bit rate of the other.Just ignore the above statement completely. If we're concerned with energy efficiency, then we have to look no further than Eb (energy per bit) alone. If we're concerned with spectral efficieny, then we have to look no further than b (spectral efficiency) alone. Eb / No is a significant ratio because the performance (i.e., bit-error rate) of many common digital comm signals is a function of this ratio. To see why we wouldn't use SNR in performance computations, consider comparing two signals S1 and S2 with the same bit rate B and energy per bit Eb but with varying spectral efficiencies b1 = 1 bit / sec / Hz and b2 = 2 bit / sec / Hz: Ps = Eb * B W = B / b Pn = No * W SNR = Ps / Pn Qty Signal 1 Signal 2 Units --- -------- -------- ----- Ps Eb * B Eb * B [watts] W B B / 2 [Hz] Pn No * B No * B / 2 [watts] SNR Eb / No 2 * Eb / No [none] Eb / No Eb / No Eb / No [1 / bit] The point is that the spectral efficiency caused signal 2 to have a higher SNR even though the transmitted power was the same due to the fact that the noise bandwidth is half and thus the noise power is half. However, this would not have created any better performance in terms of bit-error rate since its Eb / No is the same as signal 1. I hope this is correct and hasn't confused the heck out of anyone. -- % Randy Yates % "Midnight, on the water... %% Fuquay-Varina, NC % I saw... the ocean's daughter." %%% 919-577-9882 % 'Can't Get It Out Of My Head' %%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Reply by ●August 8, 20072007-08-08
ok, I understand better thanks a lot>After pondering this awhile, I think I made couple of wrong statements >and need to correct myself. Everything I initially wrote prior to the >point below was correct. > >Randy Yates <yates@ieee.org> writes: >> [...] >> To state it more heuristically, Eb/No is a sort of normalized way to >> look at SNR in which the SNR is normalized to the bit rate. > >No. Eb / No is SNR normalized to the spectral efficiency (b). That's >pretty much what the mathematical relationship stated directly: > > Eb / No = SNR / b. > >> For example, you wouldn't want to consider two signals that have the >> same SNR to be equivalent (in terms of energy efficiency) if one was >> twice the bit rate of the other. > >Just ignore the above statement completely. > >If we're concerned with energy efficiency, then we have to look no >further than Eb (energy per bit) alone. > >If we're concerned with spectral efficieny, then we have to look >no further than b (spectral efficiency) alone. > >Eb / No is a significant ratio because the performance (i.e., bit-error >rate) of many common digital comm signals is a function of this ratio. > >To see why we wouldn't use SNR in performance computations, consider >comparing two signals S1 and S2 with the same bit rate B and energy >per bit Eb but with varying spectral efficiencies b1 = 1 bit / sec / Hz >and b2 = 2 bit / sec / Hz: > > Ps = Eb * B > W = B / b > Pn = No * W > SNR = Ps / Pn > > Qty Signal 1 Signal 2 Units > --- -------- -------- ----- > Ps Eb * B Eb * B [watts] > W B B / 2 [Hz] > Pn No * B No * B / 2 [watts] > SNR Eb / No 2 * Eb / No [none] > Eb / No Eb / No Eb / No [1 / bit] > >The point is that the spectral efficiency caused signal 2 to >have a higher SNR even though the transmitted power was the >same due to the fact that the noise bandwidth is half and >thus the noise power is half. However, this would not have >created any better performance in terms of bit-error rate >since its Eb / No is the same as signal 1. > >I hope this is correct and hasn't confused the heck out of >anyone. >-- >% Randy Yates % "Midnight, on the water... >%% Fuquay-Varina, NC % I saw... the ocean's daughter." >%%% 919-577-9882 % 'Can't Get It Out Of My Head' >%%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra >http://home.earthlink.net/~yatescr >
Reply by ●June 23, 20152015-06-23
>and Eb / No is related to SNR as > > Eb / No = Ps / (b * W * No) > = SNR / b [1 / bit].First off, your explanation is really helpful.I have a query regarding the units of above expression. I understand that expression on LHS (left hand side) has units of 1/bit. (as Eb is Energy per bit). Now for RHS expression, You have written units as "[1 / bit]". I am unable to understand it because "b" being spectral efficiency has units bits/s/Hz, so how come you have written only 1/bit. /s/Hz units are absent. Is this because /s/Hz cancel out each other. Please help me out. --------------------------------------- Posted through http://www.DSPRelated.com
a.s. <104988@DSPRelated> wrote: [ attribution lost wrote]>>and Eb / No is related to SNR as >> >> Eb / No = Ps / (b * W * No) >> = SNR / b [1 / bit].>First off, your explanation is really helpful.I have a query regarding the >units of above expression. I understand that expression on LHS (left hand >side) has units of 1/bit. (as Eb is Energy per bit).The above sort of formula is the closest you can get to relating Eb/No to SNR, however there are situations where applying this formula directly might be misleading. Ignoring that detail and looking at the units: Eb/No = (energy per bit ) / (noise power per Hz) Signal power = (energy per bit) * (bits per Hz) Noise power = (noise power per Hz) * (BW in Hz) therefore SNR = Eb * (bits per Hz) / ( (noise power per Hz) (BW in Hz) = (Eb/No) * (bits per Hz) / BW Since "bits per hertz" and "BW" (bandwidth) both have units of "frequency", SNR is dimensionless as is Eb/No. Hope this helps. Steve
[...snip...]> [Hz = 1 / sec] >[...snip...]> >--Randy >I realize the original post is from eight years ago, but I disagree with your units for Hz being 1/sec, it should be cycles per second. From Wikipedia: "The hertz (symbol Hz) is the unit of frequency in the International System of Units (SI) and is defined as one cycle per second." This makes more sense in calculations like the following: Consider a tone at 1000 Hz. CD Quality = 44,100 Samples per second 44,100 Samples per second / 1000 cycles per second = 44.1 Samples per cycle Speed of sound in air 1130 feet per second 1130 feet per second / 1000 cycles per second = 1.13 feet per cycle Ced --------------------------------------- Posted through http://www.DSPRelated.com
Cedron <103185@DSPRelated> wrote:>I realize the original post is from eight years ago,I was wondering about that.> but I disagree with your units for Hz being 1/sec, it should be cycles > per second.Hz denotes cycles per second, but dimensionally it is 1 / time. A "cycle" is dimensionless, as is a "radian", a "symbol", a "sample" or a "baud". To possibly tighten up the language used in previous posts the word "unit" should probably be replaced by "has dimensions of". Steve
>Cedron <103185@DSPRelated> wrote: > >>I realize the original post is from eight years ago, > >I was wondering about that. > >> but I disagree with your units for Hz being 1/sec, it should be cycles>> per second. > >Hz denotes cycles per second, but dimensionally it is 1 / time. >A "cycle" is dimensionless, as is a "radian", a "symbol", a >"sample" or a "baud". > >To possibly tighten up the language used in previous posts the word >"unit" should probably be replaced by "has dimensions of". > >SteveI found this tutorial on the topic: https://www.physics.uoguelph.ca/tutorials/dimanaly/ So, I would say Randy was mostly carrying units all along, not doing a dimensional analysis. In short, the units for Hertz, a measure of frequency, should be cycles/second and the dimension should be Time^(-1) (not 1/sec). Well, that's how I read it. Ced --------------------------------------- Posted through http://www.DSPRelated.com
