Hi everbody, I am doing my M.SC thesis on the topic "ICI cancellation in OFDM". I have very limited time, if you can help me I will be grateful to you.... I can implement the OFDM structure in AWGN channel, it works very well.. But when i try to implement the system in a "rayleighchan", I obtain very bad BER results. -------------------------- N=3D256 ; % carriers GI=3DN/4; % Guard =C4=B1nterval=3DCyclic prefix DataBit =3D randint(N,1,2); % obtain 0 and 1's DataMod =3D qammod(DataBit,2); % obtain modulated symbols (BPSK) Ifft=3DIfft (DataMod, N); %Take ifft of the symbols x_t =3D [Ifft(N- GI + 1 : N);Ifft]; %Here x_t enters the channel %CHANNEL pathgains=3D[1,0.63,0.1,0.01]; gain=3D 10*log10(pathgains); % convert to dB pathdelays=3D[0,0.2,0.4,0.6]*1E-6; samplingtime=3D0.2E-6; fdoppler=3D50 ; % 50 Hz chan=3Drayleighchan(samplingtime,fdoppler,pathdelays,gain); chan.ResetBeforeFiltering=3D0; y_t=3Dfilter(chan,x_t); .=2E... .=2E.. ------------------------------------ I have some questions: 1) Which parameters determine the sampling time of x_t and sampling time of the channel parameters? (It is a basic question sorry but I am confused...) (I think sampling time=3D0.2E-6 and x_t's sampling rate are not correlated in my code, may be it is the problem) 2) I do not determine any parameters like ; carrier frequency =3D2 MHz , OFDM symbol duration =3D 200us etc... May I determine them, then how i can I put them in the code...(Again it is a basic question sorry but I am confused...) 2)If i use only "chan=3Drayleighchan(samplingtime, fdoppler)" then there is no problem, BER results are good...So am I choosing wrong pathdelays and samplingtime or am I doing wrong channel estimation&equalization? 3) How can I get channel impulse response? (Because chan.PathGains gives the path gains , not channel impulse response complex values) 4)I am taking chan.ResetBeforeFiltering=3D0 but not sure about it, am I doing this wrong? Burkay Etiler
implementing rayleighchan in OFDM
Started by ●August 12, 2007
