Randy Yates wrote:> Tim Wescott <tim@seemywebsite.com> writes: >> As a model, the Delta function is a great thing. If I do make an >> issue of anything it is all the places where I was taught the model as >> reality, then tripped up once I got into the real world. > > Well, yeah. Do you think anyone out of college really expects to see a > Dirac generator sitting on the bench? :)You mean they've been dropped from this year's Agilent catalogue? :-) Steve
CTFT of a discrete signal
Started by ●August 13, 2007
Reply by ●August 15, 20072007-08-15
On 14 Aug, 20:54, "NewLine" <umts_remove_this_and_t...@skynet.be> wrote:> > Depends on what you want. If you want to troll and start a war > > on comp.dsp you are almost certain to succeed. If you want to > > get on to a side track whic will cause you huge greaf and provide > > no understanding about either DSP or continuous-time signal > > processing, you are well on your way. > > This is not at all my goal, I am just trying to get a clearer view on both > transforms...or like some others have replied in some way unify both. > Maybe I am making it difficult for myself, that can be true....so be it...Just be aware that this is an area that is by no means easy. As I understand it, Dirac's Delta is some sort of simplification that can be used instead of Lebesgue's integral. The only thing I know about Lebesgue's integral is that it can integrate weird functions and is taught only to graduate maths students. As long as you aware of this fact, you might just get through in one piece.> Also like others have mentioned, often in text books discrete signals are > obtained by multiplication with a dirac comb. So if it possible to go from > continuous to discrete in that way, is it such a stupid question trying to > go the other way?The stupidity here lies with the textbook authors. Except for two notable exceptions (Oppenheim and Schafer's 1975 book and Rick Lyon's "Understanding DSP") they all look the same, address the issues in more or less the same order, in more or less the same way. Which means they all make the same mistakes. As far as I am concerned, the relationships between the different forms of the Fourier transforms are not covered remotely near sufficiently in standard texts. I suppose authors find the stuff too basic / fundamental to really look into, and it is usually included as a matter of form, before they start doing the stuff that interest them. Just to illustrate the oversimplification by authors -- have you ever seen a derivation of the convolution sum formula in the textbooks? Me neither. But that derivation is first of all very simple to do, second it illustrates how one thinks in terms of mathematical concepts. As far as I am concerned, it is a grave mistake on the authors part not to include it. Only after I had observed some of Mr Beans threads here on comp.dsp, did I notice the potential for confusion over Dirac's Delta. I have, in fact, seen one, maybe two, texts on DSP which attempt to address these questions. There is one book by two French authors, from Springer. I don't remember the title of the book, but it was published soe time around 1997-97. Rune
> > You're on the right track. When you model the discrete signal x(nT) as > a series of scaled diracs, then plug that into the CTFT, the integral > from the CTFT turns them into a sum of numbers ala DTFT. Remember the > sifting property of the Dirac? \int_{-infty}^{+\infty} x(t)\delta(t - tau) > dt = x(tau). > --first of all, thanks to all the people that have responded, all your inputs were very useful to me...also rbj I liked a lot the link to your mathematical description of sampling & reconstruction. Below I tried to do continue with what Randy introduced above. Are there any flaws in this? ---------------- my discrete signal, only k= 0 : N-1 values are non-zero (spaced T) s[k] discrete signal represented as series of scaled dirac's as if it were a 'continuous signal' s(t) = SUM_{k=0}^_{k=N-1} s[k] * d(t-k*T) where d(t) is the dirac delta FT of s(t): S(f) = INT_{-inf}_{+inf} SUM_{k=0}^_{k=N-1} s[k] * d(t-k*T) exp(-i*2*pi*f*t) dt S(f) = SUM_{k=0}^_{k=N-1} s[k] INT_{-inf}_{+inf} d(t-k*T) exp(-i*2*pi*f*t) dt S(f) = SUM_{k=0}^_{k=N-1} s[k] exp(-i*2*pi*f*k*T) S(f) = SUM_{k=-inf}^_{k=+inf} s[k] exp(-i*2*pi*f*k*T) replacing 2*pi*f*T with the normalized radial frequency w (radians per sample) this becomes: SUM_{k=-inf}^_{k=+inf} s[k] exp(-i*k*w) which is if I am not mistaken the DTFT.
On 15 Aug, 11:55, "NewLine" <qw897jhk_remove_this_and_t...@skynet.be> wrote:> > You're on the right track. When you model the discrete signal x(nT) as > > a series of scaled diracs, then plug that into the CTFT, the integral > > from the CTFT turns them into a sum of numbers ala DTFT. Remember the > > sifting property of the Dirac? \int_{-infty}^{+\infty} x(t)\delta(t - tau) > > dt = x(tau). > > -- > > first of all, thanks to all the people that have responded, all your inputs > were very useful to me...also rbj I liked a lot the link to your > mathematical description of sampling & reconstruction. > > Below I tried to do continue with what Randy introduced above. Are there any > flaws in this?None other than that there is no justification for bringing in Dirac's delta. To see why Dirac's delta came into being, consider the spectrum of the power signal x[n] = exp(jw'n) n = ...,-2,-1,0,1,2,... [1] The required computations go like (view with fixed-width font) N 1 X(w) = lim sum ----- exp(jw'n)exp(-jwn) [2.a] N->inf n=-N 2N-1 N 1 = lim sum ----- 1 [2.b] N->inf n=-N 2N-1 / 2N-1 | lim ------ = 1 w = w' = | N->inf 2N-1 | \ 0 w =/= w' So X(w) == 0 "almost everywhere ," i.e. everywhere except for one point, at w = w', where it equals 1. It's a half-weird function if you are only used to think in terms of continuous function, but for somebody with a college maths course under the belt, it is nothing extraordinary about X(w). Now, how do you get something like Parseval's relation, which relates the integral of squared x[n] in time domain with the integral of squared X(w) in frequency domain, to work with an X(w) as above? Using the old workhorse, the Riemann integral, fails: inf -e e integral X(w) = lim integral 0 dw + integral 1 dw -inf e->0 -inf -e inf + integral 0 dw = 0. [3] e Riemann's integral is stertched beyond its limits by an integrand which is 0 "almost everywhere." But the would of maths be a lot nicer place if X(w) could be integrated, right? This was the problem Lebesgue solved. He developed a way of integrating functions which are 0 "almost everywhere" so that inf integral_Lebesgue X(w) = 1. -inf with X(w) above. The one problem with Lebesque's integral is that it is far from easy to use (well, that's what my maths teachers told me; I have no personal experience with it) so Dirac set about to come up with a way to integrate functions which are 0 "almost everywhere" without having to resort to the Lebesgue integral. The result is Dirac's delta function. The function inf X = integral d(t - t0) dt -inf is basically nothing more than a tag, a note to the analyst, to say that "add 1 to the integral X when you pass t = t0." That's all there is to it. Once you get a clear picture of why the Dirac delta is useful, you also see why it is plain wrong to use it outside the integral sign. Rune
"NewLine" <qw897jhk_remove_this_and_this@skynet.be> writes:>> >> You're on the right track. When you model the discrete signal x(nT) as >> a series of scaled diracs, then plug that into the CTFT, the integral >> from the CTFT turns them into a sum of numbers ala DTFT. Remember the >> sifting property of the Dirac? \int_{-infty}^{+\infty} x(t)\delta(t - tau) >> dt = x(tau). >> -- > > first of all, thanks to all the people that have responded, all your inputs > were very useful to me...also rbj I liked a lot the link to your > mathematical description of sampling & reconstruction. > > Below I tried to do continue with what Randy introduced above. Are there any > flaws in this? > > ---------------- > > my discrete signal, only k= 0 : N-1 values are non-zero (spaced T) > > s[k] > > discrete signal represented as series of scaled dirac's as if it were a > 'continuous signal' > > s(t) = SUM_{k=0}^_{k=N-1} s[k] * d(t-k*T) > > where d(t) is the dirac deltaYou've prematurely represented the signal as a sequence s[k]. Keep the original signal intact. By the way, I don't see the original signal here, so let's call it s_a(t) (for "analog"), and let s(t) be the "discretized" version, i.e., s(t) = s_a(t) * sum_{n=-\infty}^{+\infty} d(t-n*T). Then when you take the FT of s(t) you use the sifting property of the Dirac delta function: S(f) = \int_{-infty}^{+\infty} (s_a(t) * sum_{n=-\infty}^{+\infty} d(t-n*T)) * e^{-j\omega t} dt. = sum_{n=-\infty}^{+\infty} \int_{-infty}^{+\infty} s_a(t) * d(t-n*T) e^{-j\omega t} dt. = sum_{n=-\infty}^{+\infty} s_a(n*T) * e^{-j\omega n*T} and continue from there. -- % Randy Yates % "Watching all the days go by... %% Fuquay-Varina, NC % Who are you and who am I?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://home.earthlink.net/~yatescr
robert bristow-johnson wrote: (snip, I wrote)>>Among the transform pairs there is>>discrete <--> periodic>>Applying that twice, you get>>discrete periodic <--> discrete periodic>>which is the DTFT.> Glen, i think that's the DFT (discrete periodic <--> discrete > periodic).> the DTFT is > > aperiodic, discrete time <--> periodic, continuous frequencyI think you are right. I was trying to complement the CTFT in the original post, and somehow DTFT seemed more natural. The other that always confuses me is, why isn't that a Fourier series? continuous time, periodic <--> aperiodic discrete frequency should be a Fourier series, so why not the other way around? -- glen
Randy Yates wrote: (snip)> Well, yeah. Do you think anyone out of college really expects to see a > Dirac generator sitting on the bench? :)I do remember generators with a capacitor (and charging circuit) and reed relay to generate very short pulses. It seems too simple, but it works pretty well. (As long as they aren't too close together.) It is pretty easy to make pulses shorter than you can measure. -- glen
Randy Yates wrote: (snip)> I'm not sure I respect your attempt to make this such an issue. First > of all, you act like you're the only mathematician around here and theI, at least, never thought that.> rest of us need you to enlighten us. Some of us have had some analysis > as well. I think we all must admit that there is always more to be > learned.When I learned about delta functions, I was told that mathematicians didn't like them, and often didn't believe in them. There was a story about some mathematician who rewrote a quantum mechanics book to remove delta functions from all the explanations. -- glen
On Aug 15, 4:26 pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> robert bristow-johnson wrote: > > (snip, I wrote) > > >>Among the transform pairs there is > >>discrete <--> periodic > >>Applying that twice, you get > >>discrete periodic <--> discrete periodic > >>which is the DTFT. > > Glen, i think that's the DFT > > (discrete periodic <--> discrete periodic). > > the DTFT is > > > aperiodic, discrete time <--> periodic, continuous frequency > > I think you are right. I was trying to complement the CTFT in > the original post, and somehow DTFT seemed more natural. > > The other that always confuses me is, why isn't that a Fourier series?why do you say that it isn't? the discrete samples in the time domain are the fourier coefficients of the periodic spectrum in the freqency domain. if you normalize out the 2*pi factor (by expressing frequency in normalized cycles/sample rather than radians/sample), the period of that periodic spectrum is 1, and the spacing between your discrete coefs (which are the samples) is 1.> continuous time, periodic <--> aperiodic discrete frequency > > should be a Fourier series, so why not the other way around?it *is* a Fourier series. r b-j
On Aug 15, 4:33 pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> > When I learned about delta functions, I was told that mathematicians > didn't like them, and often didn't believe in them.what they don't believe is that the dirac delta "function" is a true function as the mathematicians understand a function of a real variable. from the POV ofLebesgue integration (which is more general than the Riemann integration we learned in calculus), if two functions agree "almost everywhere" (which is "everywhere but for a countable number of discrete points"), then the integrals of the two functions over the same region (or limits of integration) must agree. well, we electrical engineers like to think of the dirac impulse as have zero value everywhere but at t=0, and its integral (from -eps to +eps) is 1. but the dirac impulse "function" agrees with the zero everywhere function at every point except t=0, and we know that the integral of 0 is 0. so this understanding of the dirac impulse violates that property of Lebesgue integration of two virtually identical functions.> There was a story > about some mathematician who rewrote a quantum mechanics book to remove > delta functions from all the explanations.yeah, some math guys really don't like it, and like our Neanderthal engineering treatment of the dirac impulse even less. i'm completely fine with the Neanderthal engineering usage of the dirac delta. r b-j
