I have a WAV file which is a complex audio signal generated in PC music software. I would like to play it back at an increased speed of 100 times the original. For example, if the dominant frequency was 20KHz, the upper limit of audio, at playback it would be 2MHz. That is as high as I need to go. Obviously, this cannot be done, or output, from the PC alone. I assume some type of programmable external hardware is required for storage and sped-up playback. What is the most straightforward ready made solution for this type of application? James Barlow
Play audio WAV at RF
Started by ●August 17, 2007
Reply by ●August 20, 20072007-08-20
A Rohde and Schwarz AMIQ might get the job done. Here's one for 3k: http://www.valuetronics.com/Details.aspx?ProdID=8740) It's got I and Q channel, so you can use it in stereo :) 14 bits, 16Msamples: http://www.valuetronics.com/vt/assets/pdfs/R&S_AMIQ.PDF It may be overkill for your problem, though... Cheers Markus
