I understand you're transmitting a single sine cycle as pulse? That means the carrier is multiplied with a rectangular window in the time domain. The spectrum of that window is a sinc=sin(x)/x function with zeros at 1/750 s intervals, and is convolved with the carrier in the frequency domain("appears around the carrier frequency") Ideally, the receiver's filter implements that sinc frequency response. The spectrum of your filter is pretty wide, and so is the optimum Rx filter. Due to the choice of pulse shaping filter, the impulse response decays only slowly. But as long as the timing is accurate, the symbols don't interfere with each other, picture here: http://www.elisanet.fi/mnentwig/webroot/pulse_and_Nyquist/index.html -mn
complex valued Equalizer - zero forcing criterion
Started by ●August 29, 2007
Reply by ●September 8, 20072007-09-08
