I read the paper by Hogenhauer , the treatment by Donadio and Rick Lyon's article at http://www.eetimes.com/showArticle.jhtml?articleID=160400592 and still have a basic question about DC gains and bit-allocations for CIC decimators. Please bear with me if this is too basic. I am new to digital implementation/bit allocation stuff. For an N-th order CIC decimator with decimation factor R, the bit- width requirement at the output stage (and all intermediate stages) is log2(R^N)+Bin, where Bin is the bit-width of the input signal. Also the DC gain for the filter is R^N. Hence, to normalize DC gain to '1', I should divide the output stage by R^N. So is it true to say that the bit-width required AFER the division is smaller than log2(R^N)+Bin? In a typical example, I have R=16, N=3 and Bin=2 (coming from the output of a 2-bit SDM). This gives a bit-width requirement of 14 for the CIC stages and hence the output requirement is 14 bits. I then divide by 16^3 to normalize DC gain to '1'. This is equivalent to right-shifting by 12 bits. I am then left with 2 bits output. Is this the typical design of a CIC after incorporating the gain factor? Something doesnt hang right here... this implies that the output bit- width of the CIC stage after the normalization factor reduces to that of the input signal, which is typically a low-bit width output from a sigma delta modulator. What am I missing? Should I implement the division as a multiplier of value 1/(16^3) and retain 14 bits after multiplication (the bits now being distributed as "decimal bits" and "mantissa bits")?
CIC Decimation Filter: implementation questions
Started by ●September 4, 2007
