Hello, everybody. Who knows how to demodulate baseband GSM signal? I know that it can be realized by 1)typical complex FM discriminator,timing recovery and slicer or by 2)Viterbi algorithm I have filtered baseband GSM signal with 1 sample per symbol. Should i interpolate or not to get 2x or 4x sample rate? I must provide error free bitstream recovery with 10dB SNR at the input. Thank you. Pavel Schukin.
GMSK demodulator
Started by ●September 5, 2007
Reply by ●September 5, 20072007-09-05
On Sep 5, 2:28 pm, "Pavel Schukin" <pav8...@yahoo.com> wrote:> Hello, everybody. > Who knows how to demodulate baseband GSM signal? > I know that it can be realized by > 1)typical complex FM discriminator,timing recovery and slicer or by > 2)Viterbi algorithm > I have filtered baseband GSM signal with 1 sample per symbol. Should i > interpolate or not to get 2x or 4x sample rate? I must provide error free > bitstream recovery with 10dB SNR at the input. > Thank you. Pavel Schukin.Option 1 likely won't perform well due to the ISI induced in the modulator -- the eye opening is small. Option 2 is nontrivial, but will work well *if* you can obtain a trellis representation of the modulation, FEC, and channel, plus phaselock. That is what the midamble is for. John
Pavel Schukin wrote:> Hello, everybody. > Who knows how to demodulate baseband GSM signal?I do. However it is going to be for money.> I know that it can be realized by > 1)typical complex FM discriminator,timing recovery and slicer or bySuboptimal solution. However it works quite well up to BT ~ 1/2. For the smaller BT, you will need a DFE after the discriminator.> 2)Viterbi algorithmThis is better.> I have filtered baseband GSM signal with 1 sample per symbol. Should i > interpolate or not to get 2x or 4x sample rate?It depends. How accurate is the symbol sync?> I must provide error free > bitstream recovery with 10dB SNR at the input.It depends. What is BT, what is the encoding. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●September 6, 20072007-09-06
Vladimir Vassilevsky wrote:> > > Pavel Schukin wrote: > >> Hello, everybody. >> Who knows how to demodulate baseband GSM signal? > > I do. However it is going to be for money. > >> I know that it can be realized by >> 1)typical complex FM discriminator,timing recovery and slicer or by > > Suboptimal solution. However it works quite well up to BT ~ 1/2. For the > smaller BT, you will need a DFE after the discriminator.For GSM, BT is ~0.25. As you say, the FM demod needs to be followed something to deal with the ISI. This can be a DFE or a Viterbi decoder. In this situation the Viterbi decoder is not the same as the one used in Option 2. John
