I am happy with everything in a SD modulator except the decimation part. You filter then decimate (down-convert the sample rate) and I can see how this gives a bit stream. How to get the other bits though for say a 16 bit word? Or does it not matter ie the bitstream can be taken into a processor in serial form. I always imagine an ADC output as say a 12 bit or more word and not a bitstream which is read into the processor. Am I missing something here? Hardy
Sigma Delta Question
Started by ●September 12, 2007
Reply by ●September 12, 20072007-09-12
HardySpicer <gyansorova@gmail.com> writes:> I am happy with everything in a SD modulator except the decimation > part. You filter then decimate (down-convert the sample rate) and I > can see how this gives a bit stream. How to get the other bits though > for say a 16 bit word? Or does it not matter ie the bitstream can be > taken into a processor in serial form. I always imagine an ADC output > as say a 12 bit or more word and not a bitstream which is read into > the processor. Am I missing something here?You seem to be confusing transport mechanism with the digital signal. For example, assume you have a 16-bit 48000 Hz digital signal. That can be transported 16 bits at a time at 48000 transports per second, or 8 bits at a time at 96000 transports per seond, or one bit at a time at 768000 transports per second. No matter how you transport it, it's still a 16-bit 48000 digital signal. In your situation you can either transport the delta sigma modulator output or the decimated filter output. The transport mechanism is irrelevent. The digital signal, however, will be different between those two cases. -- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://home.earthlink.net/~yatescr
On Sep 13, 9:45 am, Randy Yates <ya...@ieee.org> wrote:> HardySpicer <gyansor...@gmail.com> writes: > > I am happy with everything in a SD modulator except the decimation > > part. You filter then decimate (down-convert the sample rate) and I > > can see how this gives a bit stream. How to get the other bits though > > for say a 16 bit word? Or does it not matter ie the bitstream can be > > taken into a processor in serial form. I always imagine an ADC output > > as say a 12 bit or more word and not a bitstream which is read into > > the processor. Am I missing something here? > > You seem to be confusing transport mechanism with the digital signal. > For example, assume you have a 16-bit 48000 Hz digital signal. That > can be transported 16 bits at a time at 48000 transports per second, > or 8 bits at a time at 96000 transports per seond, or one bit at a > time at 768000 transports per second. > > No matter how you transport it, it's still a 16-bit 48000 digital signal. > > In your situation you can either transport the delta sigma modulator > output or the decimated filter output. The transport mechanism is > irrelevent. The digital signal, however, will be different between > those two cases. > -- > % Randy Yates % "Bird, on the wing, > %% Fuquay-Varina, NC % goes floating by > %%% 919-577-9882 % but there's a teardrop in his eye..." > %%%% <ya...@ieee.org> % 'One Summer Dream', *Face The Music*, ELOhttp://home.earthlink.net/~yatescrok so you are saying that the port of the computer only has a digital in so to speak like a serial connection? Hardy
Reply by ●September 13, 20072007-09-13
Hi, the sigma delta -MODULATOR- gives a high-rate stream of ones and zero. It's like a pulse-width modulated version of the signal. The output stage of the -CONVERTER- is a counter, that averages the bits (or numbers) over a longer time. For example, the first four paragraphs in http://en.wikipedia.org/wiki/Sigma-delta_modulation discuss this in more detail. -mn
Reply by ●September 16, 20072007-09-16
The high data rate bit stream created by a one bit DSM can be filtered, decimated and turned into a wider bit width with a simple counter. This illustrates, I think, all the principles about which you are confused. Just count the number of "1" bits over a fixed period of time. The period of time represents the output frequency, and the number of bits counted represent the data value for that sample. The filter is convolution with a simple rectangular window, the counter width is the bit width, and the ratio of the bit rate to the counter period is the decimation rate. Better filters will yield better results (the rectangular window is pretty sucky) Bear in mind that multi-bit DSM outputs are also possible, so just sum the up for the period. Same thing.. Hope that helps "HardySpicer" <gyansorova@gmail.com> wrote in message news:1189631543.939690.61160@k79g2000hse.googlegroups.com...> I am happy with everything in a SD modulator except the decimation > part. You filter then decimate (down-convert the sample rate) and I > can see how this gives a bit stream. How to get the other bits though > for say a 16 bit word? Or does it not matter ie the bitstream can be > taken into a processor in serial form. I always imagine an ADC output > as say a 12 bit or more word and not a bitstream which is read into > the processor. Am I missing something here? > > Hardy >
On Sep 16, 2:21 am, "doh ..." <so...@nospam.com> wrote:> The high data rate bit stream created by a one bit DSM can be filtered, decimated > and turned into a wider bit width with a simple counter. This illustrates, I think, all > the principles about which you are confused.i think the OP needs to understand that when decimating, the word width *must* increase (from 1 bit wide), just so that there is no loss of information.> Just count the number of "1" bits over a fixed period of time. The period > of time represents the output frequency, ...i would not express it this way. the DSM stream of zeros and ones (i'll call a[n] where "n" is discrete time) can be thought of as representing this signal (after biasing and scaling): x[n] = -2*a[n] + 1 since a[n] is always 0 or 1, x[n] is always -1 or 1. another way to look at it, which is useful for applying autocorrelation or cross- correlation operations: x[n] = (-1)^a[n] comes out to be the same relationship but the latter means that when multiplying two signals, you just add the exponents and since the exponents are 0 and 1, your addition can be modulo 2 addition (a.k.a. "exclusive-OR") and then all sorts of logical theorems are available to you. to the OP: you said you were satisfied with the sigma-delta theory. what about the gain of the quantizer in the closed loop system? do you understand what that is about and what you need to do to model the system. r b-j
