Wikipedia states the Walsh-Hadamard transform is an example of a generalized class of Fourier transforms. Loosely paraphrased it also seems to say the Fourier transform is a/(any???) linear operator which maps functions to other functions (a basis set???). The picture at Wikipedia's entry for Walsh functions is intriguing but not illuminating. College physics led to understanding previous semester's calculus, not vice versa as intended. Pointers please ;)
For math challenged - what is the Walsh-Hadamard transform?
Started by ●September 14, 2007
Reply by ●September 14, 20072007-09-14
On Sep 14, 7:54 am, Richard Owlett <rowl...@atlascomm.net> wrote:> Wikipedia states the Walsh-Hadamard transform is an example of a > generalized class of Fourier transforms. Loosely paraphrased it also > seems to say the Fourier transform is a/(any???) linear operator which > maps functions to other functions (a basis set???). > > The picture at Wikipedia's entry for Walsh functions is intriguing but > not illuminating. > > College physics led to understanding previous semester's calculus, not > vice versa as intended. > > Pointers please ;)By a "generalized class of Fourier transforms," I think they are just referring to the fact that the transform is an orthogonal decomposition. In that, it is similar to the DFT, except its set of basis functions is different. Instead of sinusoidal basis functions of varying frequency, the Hadamard transform uses mutually orthogonal trains of +1/-1 values. The Wikipedia article also points out that the transform is equivalent to a combination of size-2 DFTs, so I suppose you could combine the results FFT-style to get the full DFT of your signal, but I doubt that would be useful for anyone. The "function-to-function mapping" refers to the fact that the input to the transform is a function (i.e. in the time domain), and the output is another function (in another domain). The output function is composed of coefficients that can be used to linearly combine the basis functions to get the original function back, just like in a Fourier transform or any other orthogonal decomposition. Jason
On 2007-09-14 08:54:11 -0300, Richard Owlett <rowlett@atlascomm.net> said:> Wikipedia states the Walsh-Hadamard transform is an example of a > generalized class of Fourier transforms. Loosely paraphrased it also > seems to say the Fourier transform is a/(any???) linear operator which > maps functions to other functions (a basis set???). > > The picture at Wikipedia's entry for Walsh functions is intriguing but > not illuminating. > > College physics led to understanding previous semester's calculus, not > vice versa as intended. > > Pointers please ;)It is a Fourier Transform but the index group (the time) is not the one you are used to. It is for n-dimensional space where each dimension is of extent 2. So the addition for time is by what is commonly called logical exclusive or. The convolution that results from that form of addition of time is not the usual one either. No surprise there. The usual Fourier transforms that you may be used to have time that is either continuous or discrete and may either be unbounded or periodic. So there are four of them. Continuous time matches with unbounded frequencies and discrete time matches with periodic frequencies. Unbounded time matches with continuous frequencies and periodic time matches with discrete frequencies. There is a convenient operational calculus which ties the four together. Start with the continuous unbounded time case which is commonly taught. You can now either multiply by, convolve with or both multiply and convolve with an infinite comb of delta functions to get the others. It is easy to make a fool of oneself if you forget that the word was operational calculus which means that you get a very good hint as to what the answer is but you still need to do the proofs to verify the results. There is a correct rigourous theory of distrubutions but you loose the forest for the details of the viruses of the fungus on the scale on the leaves of the trees. But that never stopped anyone on the internet.
cincydsp@gmail.com wrote:> On Sep 14, 7:54 am, Richard Owlett <rowl...@atlascomm.net> wrote: >> Wikipedia states the Walsh-Hadamard transform is an example of a >> generalized class of Fourier transforms. Loosely paraphrased it also >> seems to say the Fourier transform is a/(any???) linear operator which >> maps functions to other functions (a basis set???). >> >> The picture at Wikipedia's entry for Walsh functions is intriguing but >> not illuminating. >> >> College physics led to understanding previous semester's calculus, not >> vice versa as intended. >> >> Pointers please ;) > > By a "generalized class of Fourier transforms," I think they are just > referring to the fact that the transform is an orthogonal > decomposition. In that, it is similar to the DFT, except its set of > basis functions is different. Instead of sinusoidal basis functions of > varying frequency, the Hadamard transform uses mutually orthogonal > trains of +1/-1 values. The Wikipedia article also points out that the > transform is equivalent to a combination of size-2 DFTs, so I suppose > you could combine the results FFT-style to get the full DFT of your > signal, but I doubt that would be useful for anyone. > > The "function-to-function mapping" refers to the fact that the input > to the transform is a function (i.e. in the time domain), and the > output is another function (in another domain). The output function is > composed of coefficients that can be used to linearly combine the > basis functions to get the original function back, just like in a > Fourier transform or any other orthogonal decomposition. > > Jason >This is my understanding. I want to add that there is an infinite number of such orthogonal decomposition schemes, the first element of which can be arbitrarily chosen -- it just constrains the rest of the elements*. The Fourier transform is a useful decomposition because it has a definite relationship to the real world -- linear systems can be easily and completely characterized by their response to an ensemble of sinusoidal signals. Thus, the Fourier transform is the best known one by far. * See Van Trees, "Detection, Estimation and Modulation Theory", part I. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Gordon Sande wrote:> ... you loose the forest for the details > of the viruses of the fungus on the scale on the leaves of the trees. But > that never stopped anyone on the internet.That's precious! Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Reply by ●September 15, 20072007-09-15
Gordon Sande wrote:> On 2007-09-14 08:54:11 -0300, Richard Owlett <rowlett@atlascomm.net> said: > >> Wikipedia states the Walsh-Hadamard transform is an example of a >> generalized class of Fourier transforms. Loosely paraphrased it also >> seems to say the Fourier transform is a/(any???) linear operator which >> maps functions to other functions (a basis set???). >> >> The picture at Wikipedia's entry for Walsh functions is intriguing but >> not illuminating. >> >> College physics led to understanding previous semester's calculus, not >> vice versa as intended. >> >> Pointers please ;) > > > It is a Fourier Transform but the index group (the time) is not the one > you are used to. It is for n-dimensional space where each dimension is > of extent 2. So the addition for time is by what is commonly called > logical exclusive or. The convolution that results from that form of > addition of time is not the usual one either. No surprise there. > > The usual Fourier transforms that you may be used to have time that is > either > continuous or discrete and may either be unbounded or periodic. So there > are four of them. Continuous time matches with unbounded frequencies and > discrete time matches with periodic frequencies. Unbounded time matches > with > continuous frequencies and periodic time matches with discrete frequencies. > There is a convenient operational calculus which ties the four together. > Start with the continuous unbounded time case which is commonly taught. > You can now either multiply by, convolve with or both multiply and convolve > with an infinite comb of delta functions to get the others. It is easy to > make a fool of oneself if you forget that the word was operational calculus > which means that you get a very good hint as to what the answer is but you > still need to do the proofs to verify the results. There is a correct > rigourous theory of distrubutions but you loose the forest for the details > of the viruses of the fungus on the scale on the leaves of the trees. But > that never stopped anyone on the internet. >Is it fair to say that a mathematician would see similarities between Fourier and Walsh-Hadamard transforms because they follow similar rules? Are there physical systems that are naturally described by Walsh-Hadamard transforms [as a Fourier transform relates an impulse response to a transfer function]?
> Are there physical systems that are naturally described by > Walsh-Hadamard transforms ... ?Unlikely. Rader put it nicely in his bookreview ( IEEE ASP August 1984 ) on the book by Elliott, Rao " Fast Transforms ..." Academic Press 1982: "With the next chapter begins the description of the more exotic species of transform. The first of these is the Walsh transform. As with real biological species it is well to beware. New species are often named by biologists, unaware that they have renamed existing species. Thus we have the Walsh transform, the Hadamard transform and the BIFORE transform which are all identical. This reviewer prefers to think of all these transforms as a special case of the multidimensional DFT. With log2N dimensions and two points per dimension the DFT is a Walsh transform. With four points per dimension we find the generalized transforms of the following chapter. The authors prefer to introduce all these transforms as discretized versions of continous transforms using some rather contrived basic functions. The principal deficiency of all these transforms has been their poor fit to the real-world application areas. All the transforms avoid multiplications but the price paid is that such natural waveform properties as bandwidth, time invariance and frequency are replaced by analogous but unnatural properties appropriate to the contrived basis functions. In spite of the dearth of ready applications the books extensive bibliographie should permit the reader to locate Walsh transform applications in his own interest area." MfG JRD
Jerry Avins wrote:> Gordon Sande wrote: > > >> ... you loose the forest for the details >> of the viruses of the fungus on the scale on the leaves of the trees. But >> that never stopped anyone on the internet. > > > That's precious! > > JerryI like the intended metaphor. But it may also be true in another way. Might you not be able to infer some characteristics of the forest from looking at the viruses. A certain virus would affect only a certain fungus which requires certain temperature and moisture to thrive and only grows on certain scales which requires certain conditions and certain trees which usually do/don't grow with specie such and such.
On 2007-09-15 07:43:08 -0300, Richard Owlett <rowlett@atlascomm.net> said:> Gordon Sande wrote: >> On 2007-09-14 08:54:11 -0300, Richard Owlett <rowlett@atlascomm.net> said: >> >>> Wikipedia states the Walsh-Hadamard transform is an example of a >>> generalized class of Fourier transforms. Loosely paraphrased it also >>> seems to say the Fourier transform is a/(any???) linear operator which >>> maps functions to other functions (a basis set???). >>> >>> The picture at Wikipedia's entry for Walsh functions is intriguing but >>> not illuminating. >>> >>> College physics led to understanding previous semester's calculus, not >>> vice versa as intended. >>> >>> Pointers please ;) >> >> >> It is a Fourier Transform but the index group (the time) is not the one >> you are used to. It is for n-dimensional space where each dimension is >> of extent 2. So the addition for time is by what is commonly called >> logical exclusive or. The convolution that results from that form of >> addition of time is not the usual one either. No surprise there. >> >> The usual Fourier transforms that you may be used to have time that is either >> continuous or discrete and may either be unbounded or periodic. So there >> are four of them. Continuous time matches with unbounded frequencies and >> discrete time matches with periodic frequencies. Unbounded time matches with >> continuous frequencies and periodic time matches with discrete frequencies. >> There is a convenient operational calculus which ties the four together. >> Start with the continuous unbounded time case which is commonly taught. >> You can now either multiply by, convolve with or both multiply and convolve >> with an infinite comb of delta functions to get the others. It is easy to >> make a fool of oneself if you forget that the word was operational calculus >> which means that you get a very good hint as to what the answer is but you >> still need to do the proofs to verify the results. There is a correct >> rigourous theory of distrubutions but you loose the forest for the details >> of the viruses of the fungus on the scale on the leaves of the trees. But >> that never stopped anyone on the internet. >> > > Is it fair to say that a mathematician would see similarities between > Fourier and Walsh-Hadamard transforms because they follow similar rules?Walsh-Hadamard is just the common name for the Fourier transform on a particular group (that many do do usually think of as a group).> Are there physical systems that are naturally described by > Walsh-Hadamard transforms [as a Fourier transform relates an impulse > response to a transfer function]?There are but the structure of the time is so different you would probably say it is only in the wildest dreams of crazy mathematicians. They go under quite different names. If I understand the technology I bellieve it is called Code Division in communications. The systems concerned are not "physical" in some common usages but are only "logical" in a more specialized sense. The fact that the methods are useful is well indicated by their having been "discovered" from first principles long ago and given common names by folks who did not know that it was just a rather technical special case of even older mathematics.
Richard Owlett <rowlett@atlascomm.net> writes:> [...]Richard, Take what you read in this thread with a grain of salt. You are treading on ivory-tower feet. Everything that's being said can be broken down into common sense, but I see few people here doing so. Granted, it may take a bit of explaining as well. -- % Randy Yates % "...the answer lies within your soul %% Fuquay-Varina, NC % 'cause no one knows which side %%% 919-577-9882 % the coin will fall." %%%% <yates@ieee.org> % 'Big Wheels', *Out of the Blue*, ELO http://home.earthlink.net/~yatescr
