hi, I have created a random binary noise using 2 methods. My main aim is to create a random binary noise whose auto power spectrum rolls of at 1Hz(cut off) and the attenuation should be sharp which is my spectrum pass band should end near 2Hz. first method: I used a random gaussian noise by a sampling frequency 40Hz and compared it with sinusoidal signal whose frequency is 0.3Hz with an amplitude of 2 so that if the reference is greater than the noise amplide then the resultant will be 1 and otherwise zero. When I did the auto power spectrum calculation for this it rolls of at 1Hz but the pass band ends near 3Hz which is not what i need. Second method: I used a random gaussian noise with a sampling frequency of 120Hz. I then filtered this one using a butter(5,0.0083,'low') an applied these coefficients to the filter. After that if the signal is greater than 0 then resultant 1 otherwise 0. The auto power spectrum here also shows a similar result as the previous one. My question here is whether the methods i am appreaching to get a random binary noise right and if not can anyone suggest me an another method. My next question would be if this is right then is there a method in order to make my attenuation sharper i.e., whether i can make the roll of to fall from 1Hz to 2Hz. I hope i am clear with my question. Any help on this would be great. Thanks in advance Pavan
Auto power spectrum
Started by ●September 14, 2007
Reply by ●September 15, 20072007-09-15
On Sep 15, 7:41 am, "pa1kumar" <pavan352...@yahoo.com> wrote:> hi, > > I have created a random binary noise using 2 methods. My main aim is to > create a random binary noise whose auto power spectrum rolls of at 1Hz(cut > off) and the attenuation should be sharp which is my spectrum pass band > should end near 2Hz. > > first method: > > I used a random gaussian noise by a sampling frequency 40Hz and compared > it with sinusoidal signal whose frequency is 0.3Hz with an amplitude of 2 > so that if the reference is greater than the noise amplide then the > resultant will be 1 and otherwise zero. When I did the auto power spectrum > calculation for this it rolls of at 1Hz but the pass band ends near 3Hz > which is not what i need. > > Second method: > > I used a random gaussian noise with a sampling frequency of 120Hz. I then > filtered this one using a butter(5,0.0083,'low') an applied these > coefficients to the filter. After that if the signal is greater than 0 > then resultant 1 otherwise 0. The auto power spectrum here also shows a > similar result as the previous one. > > My question here is whether the methods i am appreaching to get a random > binary noise right and if not can anyone suggest me an another method. > > My next question would be if this is right then is there a method in order > to make my attenuation sharper i.e., whether i can make the roll of to fall > from 1Hz to 2Hz. > > I hope i am clear with my question. Any help on this would be great. > > Thanks in advance > PavanThere won't be much coming out of your filter - it will look a bit like a random walk - integrated white noise. You can make the roll-off as sharp as you like with an FIR filter if you can stand a time-delay? Define the dB attenuation you require at 2Hz and you can work out the order of say a Butterworth to do it. We have dB = 10Log10(1+V^(2n) ) where V=2 and dB = say 100 then solve for n and ^ represents' to the power of' It's gonna be big! The phase shift will be nasty too. Hardy Hardy
HardySpicer wrote:> I ... The phase shift will be nasty too.With random phase going in, how could you tell? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
