Hi: Is it rational to compress video/audio -- for storing in a device with limited capacity or transferring on the internet via low-bandwidth connection -- using QAM? Has this ever been done before? If so, what did the resulting artifacts look/sound like? Thanks, Radium
Using to QAM to compress video/audio -- practical or not?
Started by ●September 19, 2007
Reply by ●September 19, 20072007-09-19
On Sep 19, 1:50 am, "Green Xenon [Radium]" <gluceg...@excite.com> wrote:> Hi: > > Is it rational to compress video/audio -- for storing in a device with > limited capacity or transferring on the internet via low-bandwidth > connection -- using QAM? > > Has this ever been done before? If so, what did the resulting artifacts > look/sound like? > > Thanks, > > RadiumQAM is not a compression scheme. It is a modulation scheme that maps a group of input symbols to two quadrature amplitude values. In fact, you'll find that it does the opposite of compression; the storage for the two I/Q coefficients will likely take much more space than the source data. Sure, you could just store a "symbol index" value, but then you don't get any benefit over your original data size. Jason
Green Xenon [Radium] wrote:> Hi: > > Is it rational to compress video/audio -- for storing in a device with > limited capacity or transferring on the internet via low-bandwidth > connection -- using QAM? > > Has this ever been done before? If so, what did the resulting artifacts > look/sound like? > > > Thanks, > > RadiumDid you mean to say Vector Quantization instead of QAM? VQ has been used for audio and video codecs. John
John Sampson wrote:> Did you mean to say Vector Quantization instead of QAM? VQ has been used > for audio and video codecs.No
On Sep 18, 10:50 pm, "Green Xenon [Radium]" <gluceg...@excite.com>> Is it rational to compress video/audio -- for storing in a device with > limited capacity or transferring on the internet via low-bandwidth > connection -- using QAM? > > Has this ever been done before?Is it rational to XYZ for UVW using ABC? (for a random selection of three parameters/technologies.) Possibly. Especially if you don't mind sub-unity compression ratios.
On Sep 18, 10:50 pm, "Green Xenon [Radium]" <gluceg...@excite.com> wrote:> Hi: > > Is it rational to compress video/audio -- for storing in a device with > limited capacity or transferring on the internet via low-bandwidth > connection -- using QAM? > > Has this ever been done before?I think some early digital cable transmission schemes may have used QAM (Time-Warner's FSN over a decade ago). Of course the video/audio data was precompressed using an early form of MPEG to a low bit rate before, being transport packetized and modulated back up in bandwidth to fill one analog broadband channel.
Reply by ●September 20, 20072007-09-20
Green Xenon [Radium] wrote:> Hi: > > Is it rational to compress video/audio -- for storing in a device with > limited capacity or transferring on the internet via low-bandwidth > connection -- using QAM? > > Has this ever been done before? If so, what did the resulting artifacts > look/sound like?You know many words, but few concepts. It is rational to compress milk with comic books? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
