some qustions about equalizers, timing and carrier recovery
Started by Pavel Schukin September 19, 2007
Hello, everybody!
My questions are short:
1)Can i apply equalizer before timing reovery? Or I should get timing
previously?
2) Are there equalizers which adjust timing?
3) I have signal with dramatic ISI. Can I apply timing recovery if the eye
opening is small?
4)Are there algorithms which get timing sinchronization of baseband GMSK
signal having just I and Q components?
5)Are there algorithms which removes frequency offset and phase shift of
baseband GMSK signal having just I and Q components?
Thank you.
Pavel Schukin.
Pavel Schukin wrote:
> Hello, everybody! > My questions are short: > 1)Can i apply equalizer before timing reovery? Or I should get timing > previously? > 2) Are there equalizers which adjust timing? > 3) I have signal with dramatic ISI. Can I apply timing recovery if the eye > opening is small? > 4)Are there algorithms which get timing sinchronization of baseband GMSK > signal having just I and Q components? > 5)Are there algorithms which removes frequency offset and phase shift of > baseband GMSK signal having just I and Q components?
Yes.
> Thank you. > Pavel Schukin.
You are welcome. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
