Hi all, I'm a student and I've written a driver to allow me to communicate between my DSK C6711 and my AIC23EVM codec. All is working fine but I've noticed that when I output samples to my DAC and read the resulting analog signal back via my ADC, I'm not getting back the expected samples every time I execute my program - there is a varing phase difference between what I output and what I read back. I've spent a week now with this problem to no avail, so I'm hoping now that I've done something obvious that you guys will notice. The signal I'm outputting is cyclical over 5 samples - for(i=0;i<50;i++) demodulated[i] = 0.1*cos( (2*PI*1600.0*i)/(float)(SR)); where my sample rate is 8k. When I run my program, I watch the - 25600th 76800th 128000th 153600th and 179200th samples returned by the ADC. These sample should have roughly the same value, But this is not what I'm getting when I run the program multiple times. Heres what I am getting for 5 executions of my program - First Second Third Forth Fifth 25600 -0.1417649 -0.1395805 -0.2302676 -0.1459084 -0.2332552 76800 -0.1426323 -0.1460696 -0.2242603 -0.1463084 -0.2283723 128000 -0.1407369 -0.1437245 -0.2315847 -0.1436323 -0.2332552 153600 -0.1468084 -0.1434675 -0.2263806 -0.1417349 -0.2270552 179200 -0.1434996 -0.1417328 -0.2280189 -0.1427328 -0.2293681 Notice the -0.14 samples and the -0.23 samples. They are out of phase. When I watched the - 25600th 25601st 25602nd 25603rd and 25604th samples, I got - First Execution Third Execution 25600 -0.1417649 -0.2302676 25601 0.2298179 0.1561888 25602 0.2857464 0.3114138 25603 -0.04211507 0.05596068 25604 -0.3294998 -0.2970542 I'm getting back a consistent sine wave with respect to amplitude, but I'm not getting a consistent phase and it is important that I know the phase of the incoming signal - as I'm mixing it with a local oscillator. I must point out at this point that the ougoing signal is passing through an analog circuit so ignore the differene in amplitude between what is going out and what I'm reading in. I'm using EDMA to complete the transfer to and from the DAC and ADC. I've set the PIP frame size to 512 and the number of frames to 2 for the RX and TX pipes repectfully, for the results above. I then repeated the above experiment with a frame size of 256, and I got the following - First Second Third Forth Fifth 12800 0.05191301 -0.04208295 -0.04166533 -0.04108709 0.05663529 38400 0.0548042 -0.03784253 -0.03710367 -0.03832439 0.05377622 64000 0.05377622 -0.03835652 -0.03960937 -0.0404446 0.05310161 89600 0.05515757 -0.04079797 -0.04301455 -0.03999486 0.05323011 115200 0.05499695 -0.0417617 -0.04015549 -0.0398946 0.0578239 This time I'm getting samples of the order 0.05 or -0.04, while with a frame length of 512 I was getting -0.14 or -0.23. Any idea why this might be? Also, I've stripped down my original code in order to find this error. With my original code I was also losing (I think) the odd sample sometimes, for example I might have got back something like this - First 12800 0.05191301 38400 0.2298179 64000 0.2298179 89600 0.2298179 115200 0.2298179 Anyway, I'll post my stripped down code below with the hope that someone might spot what I'm doing wrong. Remember I'm a student and I don't have anyone experienced to help me so I've been working with the TI examples. I'll post this on c6x yahoo groups also. Cheers, Joseph. /* * Copyright 2001 by Texas Instruments Incorporated. * All rights reserved. Property of Texas Instruments Incorporated. * Restricted rights to use, duplicate or disclose this code are * granted through contract. * */ /* "@(#) DSP/BIOS 4.60.22 12-07-01 (barracuda-j15)" */ /* * ======== audio.c ======== */ #include <rtdx.h> #include <stdarg.h> /* var arg stuff */ #include <std.h> #include <pip.h> #include <trc.h> #include <hst.h> #include <time.h> #include <math.h> #include <dspf_sp_fircirc.h> #include <csl_cache.h> #include "dss.h" #include "audiocfg.h" #include "audio.h" #include "dss_priv.h" #include "audiocfg.h" #include "mcbsp.h" #include "edma.h" #define PI (3.141592653589793) #define SR (8000) #pragma DATA_SECTION(semaphore, "SEMAPHORE") Uns semaphore = 0; static Uns allocBuf(PIP_Obj *out, Uns **buf); static Void freeBuf(PIP_Obj *out); static Uns getBuf(PIP_Obj *in, Uns **buf); static Void putBuf(PIP_Obj *out, Uns size); static Void process(Uns *src, Int size, Uns *dst); static Float demodulated[50]; static float tempTBDetected[800]; static float div = (float)(0x7999); static Int i,j=0,j_2=0,l; static Uns t1; static Uns t2; static long count=0; static Int c1=0; static float f1,f2; static Int cc=0; Void main() { Int i; for(i=0;i<50;i++) demodulated[i] = 0.1*cos( (2*PI*1600.0*i)/(float)(SR) ); McBSP_Init(); EDMA_Init(); return; } Void audio(PIP_Obj *in, PIP_Obj *out) { Uns *src, *dst; Uns size; size = getBuf(in, &src); allocBuf(out, &dst); process(src, size, dst); putBuf(out, size); freeBuf(in); } static Void process(Uns *src, Int size, Uns *dst) { if(count==(long)(200*size/2)) // 200*size/2 = 51200 samples for a frame length of 512 { count=0; c1 = 0; } for (l=0; l < size/2; j++,l++) // size/2 -> 32-bit samples returned by Codec { if(j==50) j=0; t1 = src[l] &0xffff; // convert incoming ADC samples to floating point (f1 and f2) t2 = (src[l]>>16) & 0xffff; if(t1 & 0x8000) t1 |= 0xFFFF0000; if(t2 & 0x8000) t2 |= 0xFFFF0000; f1 = (((Float)((Int)(t1)))/div); f2 = (((Float)((Int)(t2)))/div); f1=-f1; f2=-f2; if(cc==0) if(count>=size/2*100 && count<size/2*100 +100) tempTBDetected[count-(size/2*100)] = f2; if(cc==1) if(count>=size/2*100 && count<size/2*100 +100) tempTBDetected[count-(size/2*100)+100] = f2; if(cc==2) if(count>=size/2*100 && count<size/2*100 +100) tempTBDetected[count-(size/2*100)+200] = f2; if(cc==3) if(count>=size/2*100 && count<size/2*100 +100) tempTBDetected[count-(size/2*100)+300] = f2; if(cc==4) if(count>=size/2*100 && count<size/2*100 +100) tempTBDetected[count-(size/2*100)+400] = f2; count++; f1 = demodulated[j]; //output to DAC f1 = f1; t1 = f1 * div; t1 &= 0xffff; t2 = f2 * div; t2 &= 0xffff; t2 <<= 16; t1 = t1 | t2; dst[l]=t1; } if(count==size/2*200) { if(cc==5) { cc=10; semaphore++; //SET BREAKPOINT HERE (RUN TO HERE)! } cc++; } } static Uns allocBuf(PIP_Obj *out, Uns **buf) { PIP_alloc(out); *buf = PIP_getWriterAddr(out);; return (PIP_getWriterSize(out)); } static Void freeBuf(PIP_Obj *out) { PIP_free(out); } static Uns getBuf(PIP_Obj *in, Uns **buf) { PIP_get(in); *buf = PIP_getReaderAddr(in);; return (PIP_getReaderSize(in)); } static Void putBuf(PIP_Obj *out, Uns size) { PIP_setWriterSize(out, size); PIP_put(out); } /////////////////////////////////////////////////////////////// ///////////////////////// DSS.c /////////////////////////////////////////////////////////////// #include <std.h> #include <pip.h> #include <log.h> #include <trc.h> #include <clk.h> #include "dss.h" #include "dss_priv.h" #include "audiocfg.h" #include "audio.h" #include <csl_cache.h> Int DSS_error = 0; Int DSS_rxCnt = 0; Int DSS_txCnt = 0; Int *DSS_rxPtr = NULL; Int *DSS_txPtr = NULL; DSS_Obj DSS_config = { 0 /* enable tracing */ }; /* * ======= DSS_txPrime ======== * Called when DSS_txPipe has a full buffer to be transmitted * (i.e., when notifyReader() is called) and when the DSS ISR * is ready for more data. */ void DSS_txPrime(Bool calledByISR) { PIP_Obj *txPipe = &DSS_txPipe; static Int nested = 0; if(nested) return; nested = 1; if (DSS_txCnt == 0 && PIP_getReaderNumFrames(txPipe) > 0) { PIP_get(txPipe); /* must set 'Ptr' before 'Cnt' to synchronize with isr() */ DSS_txPtr = PIP_getReaderAddr(txPipe); DSS_txCnt = PIP_getReaderSize(txPipe)/2; DSS_dmaTxStart(DSS_txPtr, DSS_txCnt); } else if (calledByISR && (DSS_error & DSS_TXERR) == 0) { if (DSS_config.enable) TRC_disable(TRC_GBLTARG); DSS_error |= DSS_TXERR; } nested = 0; } /* * ======= DSS_rxPrime ======== * Called when DSS_rxPipe has an empty buffer to be filled; * e.g., when notifyWriter() is called) and when the DSS ISR * is ready to fill another buffer. */ void DSS_rxPrime(Bool calledByISR) { PIP_Obj *rxPipe = &DSS_rxPipe; static Int nested = 0; if(nested) return; nested = 1; if (DSS_rxCnt == 0 && PIP_getWriterNumFrames(rxPipe) > 0) { PIP_alloc(rxPipe); DSS_rxPtr = PIP_getWriterAddr(rxPipe); DSS_rxCnt = PIP_getWriterSize(rxPipe)/2; DSS_dmaRxStart(DSS_rxPtr, DSS_rxCnt); } else if(calledByISR && (DSS_error & DSS_RXERR) == 0) { if(DSS_config.enable) TRC_disable(TRC_GBLTARG); DSS_error |= DSS_RXERR; } nested = 0; } /* * ======== DSS_dmaInit ======== * Initialise EDMA Controller */ Void DSS_dmaInit(Void) { /* General EDMA Initialization */ EDMA_RSET(EER, 0x0000); /* Disable all events */ EDMA_RSET(ECR, 0xffff); /* Clear all pending events */ EDMA_RSET(CIER, 0x0000); /* Disable all events to Interrupt */ EDMA_RSET(CIPR, 0xffff); /* Clear all pending Queued EDMA ints */ /* Enable Rx/Tx DMA Complete Interrupts to the CPU */ EDMA_RSET(CIER, DSS_RXDONE | DSS_TXDONE); } /* * ======= DSS_dmaRxStart ======== */ Void DSS_dmaRxStart(Void *dst, Int nsamps) { CACHE_clean(CACHE_L2, dst, nsamps); /* Reconfig EDMA channel for next receive buffer */ EDMA_RSETH(DSS_hEdmaRint0, CNT, (Uns) nsamps); EDMA_RSETH(DSS_hEdmaRint0, DST, (Uns) dst); EDMA_RSET(EER, 0x3000); /* Enable McBSP0 Rx/Tx Events to the DMA */ } /* * ======= DSS_dmaTxStart ======== */ Void DSS_dmaTxStart(Void *src, Int nsamps) { static Int startup = 1; /* Uns temp[32]; static Uns t1; static Uns t2; static Float f1; static Float f2; static Float div = (float)(0x7fff); temp[0] = *(Uns *)(src); temp[1] = *((Uns *)(src)+1); temp[2] = *((Uns *)(src)+2); temp[3] = *((Uns *)(src)+3); t1 = temp[0] &0xffff; t2 = (temp[0]>>16) & 0xffff; if(t1 & 0x8000) t1 |= 0xFFFF0000; if(t2 & 0x8000) t2 |= 0xFFFF0000; f1 = (((Float)((Int)(t1)))/div); f2 = (((Float)((Int)(t2)))/div);*/ CACHE_flush(CACHE_L2, src, nsamps); if (startup) { startup = 0; EDMA_RSET(ECR, 0x3000); /*Clear any previous McBSP Events */ } /* Reconfig EDMA channel for next transmit buffer */ EDMA_RSETH(DSS_hEdmaXint0, SRC, (Uns) src); EDMA_RSETH(DSS_hEdmaXint0, CNT, (Uns) nsamps); EDMA_RSET(EER, 0x3000); /* Enable McBSP0 Rx/Tx Events to the DMA */ } /////////////////////////////////////////////////////////////// ///////////////////////// DSSEDMA_IRC.c /////////////////////////////////////////////////////////////// #include <std.h> #include <log.h> #include <pip.h> #include "audiocfg.h" #include "audio.h" #include "dss.h" #include "dss_priv.h" /* * ======== DSS_edmaIsr ======== * * This ISR is called under 2 conditions. Either when EDMA has received a * complete buffer of samples from Serial Port (Codec) or when a EDMA has * completed transmission of a buffer to the Serial Port (Codec). This * ISR must configure the next buffer to be filled by the EDMA in each * case. */ Void DSS_edmaIsr(Void) { Int channel = EDMA_RGET(CIPR); /* get Channel Interrupt Pending bits */ if (channel & DSS_TXDONE) { /* Channel = McBSP Buffer Tx'ed */ PIP_free(&DSS_txPipe); DSS_txCnt = 0; /* Reset Buffer Count for sync */ EDMA_RSET(CIPR, DSS_TXDONE); /* Reset EDMA Channel Flag */ DSS_txPrime(TRUE); } if (channel & DSS_RXDONE) { /* Channel = McBSP Buffer Rx'ed */ PIP_put(&DSS_rxPipe); DSS_rxCnt = 0; /* Reset Buffer Count for sync */ EDMA_RSET(CIPR, DSS_RXDONE); /* Reset EDMA Channel Flag */ DSS_rxPrime(TRUE); } } /////////////////////////////////////////////////////////////// ///////////////////////// EDMA.c /////////////////////////////////////////////////////////////// #include <std.h> #include "dss_priv.h" #include "edma.h" Void EDMA_Init(Void) { EDMA_RSET(EER, 0x0000); /* Disable all events */ EDMA_RSET(ECR, 0xffff); /* Clear all pending events */ EDMA_RSET(CIER, 0x0000); /* Disable all events to Interrupt */ EDMA_RSET(CIPR, 0xffff); /* Clear all pending Queued EDMA ints */ /* Enable Rx/Tx DMA Complete Interrupts to the CPU */ EDMA_RSET(CIER, DSS_RXDONE | DSS_TXDONE); /* Enable EDMA interrupt */ IER |= DSS_IERDMABIT; } /////////////////////////////////////////////////////////////// ///////////////////////// Mc_BSP.c /////////////////////////////////////////////////////////////// #include <std.h> #include <log.h> #include "dss_priv.h" #include "audiocfg.h" #include "mcbsp.h" /* function prototypes ... */ Void spWrite(MCBSP_Handle hMcBsp, Uns data); Void aic23_write_reg(Uns uiAddress, Uns uiData); /* * ======== DSS_init ======== */ Void McBSP_Init(Void) { MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02001000); MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02C01000); MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02C11000); MCBSP_RSETH(DSS_hMcbsp0, SPCR, 0x02010001); spWrite(DSS_hMcbsp1, 0); aic23_write_reg(0x0F, 0x00); aic23_write_reg(0x06, 0x00); aic23_write_reg(0x00, 0x17); aic23_write_reg(0x01, 0x17); aic23_write_reg(0x02, 0xF9); aic23_write_reg(0x03, 0xF9); aic23_write_reg(0x04, 0x10); aic23_write_reg(0x05, 0x00); aic23_write_reg(0x07, 0x53); // aic23_write_reg(0x08, 0x2c); //2 aic23_write_reg(0x08, 0x2c); //2 // aic23_write_reg(0x08, 0x2c); //2 aic23_write_reg(0x09, 0x01); /* Enable EDMA interrupt */ IER |= DSS_IERDMABIT; } // Write from McBsp to AIC23 Void spWrite(MCBSP_Handle hMcBsp, Uns data) { // Poll until ready to transmit while (( (MCBSP_RGETH(hMcBsp, SPCR)) & 0x20000) == 0); MCBSP_write(hMcBsp,data); } // Write to Control Reg on AIC23 Void aic23_write_reg(Uns uiAddress, Uns uiData) { spWrite(DSS_hMcbsp1, ((uiAddress << 9) | uiData) ); }
Phase Irregularities with DSKC6711 and AIC23EVM Codec
Started by ●October 19, 2004
Reply by ●October 20, 20042004-10-20
Hi again all, I've now removed the EDMA and PIPing from my code and the problem still exists! I'm simply polling now. There EDMA is therefore not the issue. I've included the much shorter code below. Remember I'm simply outputting a sine to my DAC on my AIC23EVM, and reading back this analog sine via the ADC on the same device. The signal I'm outputting is a sine, periodic over 5 samples. I'd expect that the signal I read back, would have the same phase difference relative to the outgoing signal, each time I run the program. Instead, I get one of 2 phase differences. So if I output the samples - 0 0.951056516 0.587785252 -0.587785252 -0.951056516 I might get back the following, at my ADC, the first, second and fifth time I run the program - 0.099833417 0.977155417 0.504081844 -0.665615705 -0.915454973 and this the third and fourth time - -0.198669331 0.870706506 0.736795546 -0.415341816 -0.993490905 This is what I got for 8 executions of the code below (remember these samples are multiples of 5, so they should have the same value each time) - First Second Third Fourth Fifth Sixth Seventh Eighth 49000 0.044621 -0.05516 -0.05548 0.0434 0.040894 0.040135 0.040541 -0.05692 49049 0.040509 -0.05249 -0.05635 0.042565 0.042083 0.040284 0.040316 -0.05538 49098 0.041565 -0.05397 -0.05744 0.041216 0.041151 0.03871 0.041151 -0.05574 49147 0.041316 -0.05432 -0.05709 0.042436 0.039898 0.039513 0.040959 -0.05644 49196 0.041353 -0.05506 -0.05529 0.040959 0.040316 0.037939 0.041344 -0.05577 Again, the values are either in the order of 0.04 or -0.05, depending on which execution were talking about. I would expect to get the same value - either 0.04 or -0.05, every time I run the program. Instead, I get either 0.04 or -0.05 - 0.04 seems to occur 70% of the time. Here are 5 continuos sample, (49000, 49001 etc.), for reference - -0.05304 0.297086 0.224325 -0.15593 -0.31289 clearly a sine. Do you think that this is an issue which can be solved easily? Thank you, Joseph. /* * Copyright 2001 by Texas Instruments Incorporated. * All rights reserved. Property of Texas Instruments Incorporated. * Restricted rights to use, duplicate or disclose this code are * granted through contract. * */ /* "@(#) DSP/BIOS 4.60.22 12-07-01 (barracuda-j15)" */ /* * ======== audio.c ======== */ #include <rtdx.h> #include <stdarg.h> /* var arg stuff */ #include <std.h> #include <pip.h> #include <trc.h> #include <log.h> #include <hst.h> #include <time.h> #include <math.h> #include <dspf_sp_fircirc.h> #include <csl_cache.h> #include "dss.h" #include "audiocfg.h" #include "audio.h" #include "dss_priv.h" #include "audiocfg.h" #include "mcbsp.h" #include "edma.h" #define PI (3.141592653589793) #define SR (8000) #pragma DATA_SECTION(semaphore, "SEMAPHORE") Uns semaphore = 0; static Uns allocBuf(PIP_Obj *out, Uns **buf); static Void freeBuf(PIP_Obj *out); static Uns getBuf(PIP_Obj *in, Uns **buf); static Void putBuf(PIP_Obj *out, Uns size); static Void process(Uns *src, Int size, Uns *dst); static Float demodulated[50]; static float tempTBDetected[1800]; static float div = (float)(0x7999); static Int i,j=0,j_2=0,l; static Uns t1; static Uns t2; //Int index = 0; static long count=0; static Int c1=0; static float f1,f2; static Int cc=0; Void main() { Int i,j; for(i=0;i<50;i++) demodulated[i] = 0.1*cos( (2*PI*1600.0*i)/(float)(SR) ); MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02001000); MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02C01000); MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02C11000); MCBSP_RSETH(DSS_hMcbsp0, SPCR, 0x02010001); McBSP_Init(); EDMA_RSET(EER, 0x0000); /* Disable all events */ EDMA_RSET(ECR, 0xffff); /* Clear all pending events */ EDMA_RSET(CIER, 0x0000); /* Disable all events to Interrupt */ EDMA_RSET(CIPR, 0xffff); /* Clear all pending Queued EDMA ints */ for(j=0;j<1100;j++) { for(i=0;i<50;i++) { f1=demodulated[i]; f2=demodulated[i]; t1 = f1 * div; t1 &= 0xffff; t2 = f2 * div; t2 &= 0xffff; t2 <<= 16; t1 = t1 | t2; //spWrite(DSS_hMcbsp0, t1); while (( (MCBSP_RGETH(DSS_hMcbsp0, SPCR)) & 0x20000) == 0); MCBSP_write(DSS_hMcbsp0,t1); while (((MCBSP_RGETH(DSS_hMcbsp0, SPCR)) & 0x2) == 0); t1 = MCBSP_read(DSS_hMcbsp0); t2 = (t1>>16) & 0xffff; t1 = t1 &0xffff; if(t1 & 0x8000) t1 |= 0xFFFF0000; if(t2 & 0x8000) t2 |= 0xFFFF0000; f1 = (((Float)((Int)(t1)))/div); f2 = (((Float)((Int)(t2)))/div); if(j>=1000&&j<1100) tempTBDetected[j-1000] = f2; } } semaphore++; // set watch here return; }
Reply by ●October 21, 20042004-10-21
Is the Codec the master - this might mean there is a timing issue perhaps? joseph_lyons_79@yahoo.com (Joseph Lyons) wrote in message news:<5a7aee1d.0410201007.44678982@posting.google.com>...> Hi again all, > > I've now removed the EDMA and PIPing from my code and the problem > still exists! I'm simply polling now. There EDMA is therefore not the > issue. > > I've included the much shorter code below. > > Remember I'm simply outputting a sine to my DAC on my AIC23EVM, and > reading back this analog sine via the ADC on the same device. The > signal I'm outputting is a sine, periodic over 5 samples. I'd expect > that the signal I read back, would have the same phase difference > relative to the outgoing signal, each time I run the program. Instead, > I get one of 2 phase differences. > > So if I output the samples - > > 0 > 0.951056516 > 0.587785252 > -0.587785252 > -0.951056516 > > I might get back the following, at my ADC, the first, second and fifth > time I run the program - > > 0.099833417 > 0.977155417 > 0.504081844 > -0.665615705 > -0.915454973 > > and this the third and fourth time - > > -0.198669331 > 0.870706506 > 0.736795546 > -0.415341816 > -0.993490905 > > > This is what I got for 8 executions of the code below (remember these > samples are multiples of 5, so they should have the same value each > time) - > > First Second Third Fourth Fifth Sixth Seventh Eighth > 49000 0.044621 -0.05516 -0.05548 0.0434 0.040894 0.040135 0.040541 > -0.05692 > 49049 0.040509 -0.05249 -0.05635 0.042565 0.042083 0.040284 0.040316 > -0.05538 > 49098 0.041565 -0.05397 -0.05744 0.041216 0.041151 0.03871 0.041151 > -0.05574 > 49147 0.041316 -0.05432 -0.05709 0.042436 0.039898 0.039513 0.040959 > -0.05644 > 49196 0.041353 -0.05506 -0.05529 0.040959 0.040316 0.037939 0.041344 > -0.05577 > > Again, the values are either in the order of 0.04 or -0.05, depending > on which execution were talking about. I would expect to get the same > value - either 0.04 or -0.05, every time I run the program. Instead, I > get either 0.04 or -0.05 - 0.04 seems to occur 70% of the time. > > Here are 5 continuos sample, (49000, 49001 etc.), for reference - > > -0.05304 > 0.297086 > 0.224325 > -0.15593 > -0.31289 > > > clearly a sine. > > Do you think that this is an issue which can be solved easily? > > Thank you, > > Joseph. > > /* > * Copyright 2001 by Texas Instruments Incorporated. > * All rights reserved. Property of Texas Instruments Incorporated. > * Restricted rights to use, duplicate or disclose this code are > * granted through contract. > * > */ > /* "@(#) DSP/BIOS 4.60.22 12-07-01 (barracuda-j15)" */ > /* > * ======== audio.c ======== > */ > #include <rtdx.h> > #include <stdarg.h> /* var arg stuff */ > #include <std.h> > #include <pip.h> > #include <trc.h> > #include <log.h> > #include <hst.h> > #include <time.h> > #include <math.h> > #include <dspf_sp_fircirc.h> > #include <csl_cache.h> > #include "dss.h" > #include "audiocfg.h" > #include "audio.h" > #include "dss_priv.h" > #include "audiocfg.h" > #include "mcbsp.h" > #include "edma.h" > #define PI (3.141592653589793) > #define SR (8000) > #pragma DATA_SECTION(semaphore, "SEMAPHORE") > Uns semaphore = 0; > static Uns allocBuf(PIP_Obj *out, Uns **buf); > static Void freeBuf(PIP_Obj *out); > static Uns getBuf(PIP_Obj *in, Uns **buf); > static Void putBuf(PIP_Obj *out, Uns size); > static Void process(Uns *src, Int size, Uns *dst); > static Float demodulated[50]; > static float tempTBDetected[1800]; > static float div = (float)(0x7999); > static Int i,j=0,j_2=0,l; > > static Uns t1; > static Uns t2; > //Int index = 0; > static long count=0; > > static Int c1=0; > > static float f1,f2; > > static Int cc=0; > > Void main() > { > Int i,j; > for(i=0;i<50;i++) > demodulated[i] = 0.1*cos( (2*PI*1600.0*i)/(float)(SR) ); > > MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02001000); > MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02C01000); > MCBSP_RSETH(DSS_hMcbsp1, SPCR, 0x02C11000); > MCBSP_RSETH(DSS_hMcbsp0, SPCR, 0x02010001); > > McBSP_Init(); > > EDMA_RSET(EER, 0x0000); /* Disable all events */ > EDMA_RSET(ECR, 0xffff); /* Clear all pending events */ > EDMA_RSET(CIER, 0x0000); /* Disable all events to Interrupt */ > EDMA_RSET(CIPR, 0xffff); /* Clear all pending Queued EDMA ints > */ > > for(j=0;j<1100;j++) > { > > for(i=0;i<50;i++) > { > f1=demodulated[i]; > f2=demodulated[i]; > > t1 = f1 * div; > t1 &= 0xffff; > > t2 = f2 * div; > t2 &= 0xffff; > > t2 <<= 16; > t1 = t1 | t2; > > //spWrite(DSS_hMcbsp0, t1); > > while (( (MCBSP_RGETH(DSS_hMcbsp0, SPCR)) & 0x20000) == 0); > MCBSP_write(DSS_hMcbsp0,t1); > > while (((MCBSP_RGETH(DSS_hMcbsp0, SPCR)) & 0x2) == 0); > t1 = MCBSP_read(DSS_hMcbsp0); > > t2 = (t1>>16) & 0xffff; > t1 = t1 &0xffff; > > if(t1 & 0x8000) > t1 |= 0xFFFF0000; > if(t2 & 0x8000) > t2 |= 0xFFFF0000; > > f1 = (((Float)((Int)(t1)))/div); > f2 = (((Float)((Int)(t2)))/div); > > if(j>=1000&&j<1100) > tempTBDetected[j-1000] = f2; > } > } > semaphore++; // set watch here > return; > }
