1. Though dummy bits are assumed before and after tail bits, they are not actually transmitted on the air, are they? Then since the gaussian pulse is assumed to last 4 bits, will the dummy bits lag into the tail bits in real signal? 2. If dummy bits are not transmitted, then how does the equalizer handle it if there are more taps than the number of tail bits? Thanks a lot!
questions about gmsk and equalizer
Started by ●September 24, 2007
Reply by ●September 24, 20072007-09-24
A random version of some random GSM specs, in case you haven't seen this: http://ucesp.ws.binghamton.edu/~xli/eece542/std/3gpp/GSM0504-830.doc Section 2.2 answers at least whether or not they are transmitted over the air. -mn
